Issues with Flashing New JETSON NANO production SoM's
Hi due to DRAM change we are following the below procedure to Flash NVIDIA Jetson SOMs with JetPack 4.6.5 and considering PCN211181 Overlay:
# 1. Prerequisites
# Create a directory to store the necessary files
mkdir -p ~/nvidia/jetson_nano_new_som
cd ~/nvidia/jetson_nano_new_som
# Download the required files from NVIDIA’s website
wget https://developer.nvidia.com/downloads/embedded/l4t/r32_release_v7.5/t210/jetson-210_linux_r32.7.5_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/l4t/r32_release_v7.5/t210/tegra_linux_sample-root-filesystem_r32.7.5_aarch64.tbz2
wget https://developer.nvidia.com/downloads/embedded/L4T/r32_Release_v7.5/overlay_32.7.5_PCN211181.tbz2
# 2. Setup on Linux Host
# Ensure all downloaded files (three tarballs) are in the correct directory
# Extract the BSP package
sudo tar xf jetson-210_linux_r32.7.5_aarch64.tbz2
# Navigate to the root filesystem directory
cd Linux_for_Tegra/rootfs/
# Extract the Sample Root Filesystem
sudo tar xpf ../../tegra_linux_sample-root-filesystem_r32.7.5_aarch64.tbz2
# Apply binaries
cd ..
sudo ./apply_binaries.sh
# Extract and apply the PCN211181 overlay
cd ..
sudo tar xpf overlay_32.7.5_PCN211181.tbz2
# 3. Preparing Jetson SOM for Flashing
# Ensure the Jetson developer kit is connected to the Linux host
# Put the Jetson SOM into Force Recovery Mode by following NVIDIA’s official guide
# Link: https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/IN/QuickStart.html#to-determine-whether-the-developer-kit-is-in-force-recovery-mode
Flashing jetson can be done in 2 different ways depending on the number of Jetson devices to be flashed.
  1. To Flash a single device:
    3A. If the target board has already been flashed, reflash the clone image to the APP partition. Enter this command:
sudo ./flash.sh -r -k APP jetson-nano-emmc mmcblk0p1
3B. If the target board has never been flashed, flash all of the board’s partitions. Enter this command:
sudo ./flash.sh -r jetson-nano-emmc mmcblk0p1
Following was tested by me in different scenarios:
  1. Above steps were done after SDK manager downloaded 4.6.5 Jetpack
  2. Above steps were done without anything being present in ~/nvidia folder
And following are my observations and issues for which I am posting this post:
  1. After running the commands :
apt-get update
sudo reboot
The system works
  • But after running
apt-get upgrade -y
sudo reboot
The system doesnt boot up and gets stuck on the NVIDIA logo screen . Please find the logs mentioned below
2. System over all is quite unstable with images getting unresponsive very frequently.
3. In the Host system we cannot get any device in /dev/ttyACM0 neither do we get any USB-OVER-IP feature i.e. in ifconfig the IP 192.168.55.100 is not seen
Kindly help in confirming the issues mentioned in 1,2,3 and the resolution
BELOW ARE THE BOOT LOGS
 minicom
Welcome to minicom 2.9
OPTIONS:
Compiled on Sep 22 2023, 21:10:41.
Port /dev/cu.usbmodem554F0115641, 16:24:37
Press Meta-Z for help on special keys
[0000.220] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.225] Processing in cold boot mode Bootloader 2
[0000.230por
[0000.237] No Battery Present
[0000.239] pmic max77620 reset reason
[0000.243] pmic max77620 NVERC : 0x40
[0000.246] RamCode = 1
[0000.249] Platform has DDR4 type RAM
[0000.252] max77620 disabling SD1 Remote Sense
[0000.256] Setting DDR voltage to 1125mv
t = 0x0
[0000.274] RamDumpCarveOut=0x0,  RamDumperFlag=0xe59ff3f8
[0000.279] Last reboot was clean, booting normally!
[0000.284] Sdram initialization is successful
[0000.288] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.294] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.300] BpmpF7] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.[0000.345] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.351] Platform-DebugCarveout: 0
[0000.354] Nck Carveo.367] Initialize FailControl
[0000.370] Read PT from (0:3)
[0000.424] PT crc32 and magic check passed.
[0000.428] Using BF[0000.432] PT: Partition LNX NOT found !
[0000.436] *** Booting KFS0.
[0000.438] NvTbootFailControlDoFailover: No failover; C[0000.473] Loading Tboot-CPU binary
[0000.478] Verifying TBC in OdmNonSecureSBK mode
[0000.506] MAX77620_GPIO5 configured
[0000.509] CPU power rail is up
[0000.512] CPU clock enabled
[0000.516] Performing RAM repair
[0000.519] Updating A64 Warmre
[0000.539] Loading NvTbootBootloaderDTB
e
check GPT table first ...
[0000.641] Loading NvTbootKernelDTB
[0000.729] Kernel DTB Load Address: 0x83100000
[0000.733] Board[0000.760] Verifying EBT in OdmNonSecureSBK mode
0000.813] BoardID = 3448, SKU = 0x2
[0000.816] Not Nano-SD or ![0000.829] PT: Partition NCT NOT found !
[0000.832] Warning: Find Partition via PT Failed
[0000.837] Next binary entry address: 0x92c00258
[0000.841] BoardId: 3448
[0000.846] Overriding pmu board id with proc board id
[0000.8510000.855] BoardID = 3448, SKU = 0x2
[0000.858] Not Nano-SD or ![0000.864] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.877] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.967] /bpmp deleted
[0000.969] SC7EntryFw header found loaded at 0xff700000
SPI-ONLY, check GPT table first ...
[0001.392] NvTbootFailControlDoFailover: No failover; Continuing[0001.399] WB0 init successfully at 0xff780000
[0001.403] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.408] Set NvDecSticky Bits
= 0x2
[0001.424] Not Nano-SD or !QSPI-ONLY, check GPT table fir0
[0001.437]  OS size 0
ion of Secure OS Successful
[0001.467] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.471] NvTbootPackSdramParams: start.
3682 KB
[0001.494] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.499] Next stage binary read took 7379 us
[0001.5
[0001.515] Starting CPU & Halting co-processor
6ind emc-table node
[0001.645] LPDDR4 Training: Can't find emc-table node
acheable
[0001.699] Bootloader DTB loaded at 0x83000000
[0001.704] Marked DTB cacheable
[0001.707] Kernel DTB loaded at 0x83100000
[0001.711] DeviceTree Init done
[0001.730] gicd_base: 0x50041000
[0001.734] gicc_base: 0x50042000
[0001.737] Interrupts Init done
.746] Using base:0x60005098 for delay-timer
[0001.751] platformling constructors
[0001.776] initializing heap
[0001.778] initating bootstrap completion thread
[0001.788] top of bootstrap2()
[0001.791] CPU: ARM Cortex A57
[0001.794] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.799] initializing platform
[0001.854] Config for emmc ddr50 mode completed
[0001.858] sdmmc bdev is already initialized
[0001.862] Enable APE clock
[000ds1015-driver to of_hal
[0001.884] of_register: registering lp8557-bl-driver to of_hal
[0001.890] of_register: registering bq2egistering tca9539_gpio to of_hal
[0001.917] of_register: registering tca9539_gpio to of_hal
[0001.923] of_register: registering i2c_bus_driver to of_hal
[0001.928] of_register: registering i2c_bus_driver to of_hal
[0001.934] of_register: registering i[0001.943] of_register: registering max77620_pmic to of_hal
[00 registering tps65132_bl_driver to of_hal
[0001.958] initializing target
iver
[0001.974] board ID = D78, board SKU = 2
[0001.980] fixed regulator driver initialized
[0002.012] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.031] I2C Bus Init done
[0002.034] of_children_init: Ops f[0002.044] I2C Bus Init done
[0002.047] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.086] I2C Bus Init done
[0002.088] of_children_init: Ops f[0002.104] register 'maxim,max77620' pmic
[0002.109] gpio_driver_register: register 'max77620-gpio' driver
[0002.115] of_children_init: Ops found for compatible string nvi[0002.130] NCK carveout not present
[0002.141] Find /i2c@7000c000's alias i2c0
[0002.145] get eeprom at 1-a0, size 256, type 0
[0002.155] Find /i2c@7000c500's alias i2c2
[0002.159] get eeprom at 3-a0, size 256, type 0
[0002.163] get eeprom at 3-ae, sizeed
[0002.190] pm_ids_update: Updating 3,a0, size 256, type 0
:module@0x50
_ids_update: Updating 3,ae, size 256, type 0
.275] pm_ids_update: eeprom init failed
address in DTB
[0002.325] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.334] updating /chosen/nvidia,ethernet-mac node 3c:<MAC MASKED BY AUTHOR>
[0002.340] Plugin Manager: Parse ODM data 0x000a4000
[0002.369] Find /i2c@7000c000's alias i2c0
[0002.373] get eeprom at 1-a0, size 256, type 0
 256, type 0
[0002.395] pm_ids_update: Updating 1,a0, size 256,[0002.448] pm_ids_update: The pm board id is 3448-0002-402
[0002.454] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0002.496] eeprom_init: EEPROM incompatible version found
[0002.501] pm_ids_update: eeprom init failed
[0002.547] platform-init is not present. Skipping
[0002.551] calling apps_init()
 init
[0002.597] could not find regulator
[0002.628] DT entry for leds-pwm not found
23] is_hdmi_needed: HDMI not connected, returning false
[0002.637] hdmi is not connected
[0002.640] sor0 is not supported
[0002.643] display_console_init: no valid display out_type
oard init success
k_clear: 747
[0002.812] se_aes_verify_sbk_clear: Error
[0002.816] SE operation failed
[0002.819] bl_battery_charging: connected to external power supply
[0002.829] display_console_ioctl: No display init
[0002.833] switch_backlight failed
[0002.860] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.867] USP partition read failed!
[00026] android_boot Unable to update recovery partition
[0002.882] [0002.986] decompressor handler not found
ded and initialized
[0003.044] Failed to display boot-logo
[0003.047] NCK carveout not present
[0003.050] Skipping dts_overrides
[0003.054] NCK carveout not present
ed
[0003.113] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.150] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500:module@0x50
[0003.194] eeprom_init: EEPROM incompatible version found
[0003[0003.229] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.249] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
:05:b9
[0003.264] Plugin Manager: Parse ODM data 0x000a4000
[0003.285] Add serial number:1424624333301 as DT property
[0003.315] Updated board info to DTB
[0003.319] "pmu-board" doesn't exist, creating
[0003.334] Updated board info to DTB
[0003.337] "reset" doesn't exist, creating
[0003.342] Updated reset info to DTB
[0003.345] display_consolesplay init
[0003.354] display_console_ioctl: No display init
[art8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
.ifnames=0 sdhci_tegra.en_boot_part_access=1
[0003.415] Updated bootarg info to DTB
[0003.419] Adding uuid 07
[0003.437] Updated memory info to DTB
ure-pmc; disable BPMP
U-Boot 2020.04-g904285e3a7 (Nov 04 2024 - 23:37:42 -0800)
NVIDIA P3450-0000
DRAM:  2 GiB
*** Warning - bad CRC, using default environment
found.
Hit any key to stop autoboot:  0
MMC: no card present
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extli34707464 bytes read in 788 ms (42 MiB/s)
append: tegraid=21.1.2video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait
d (addr=0 size=0)
ERROR: reserving fdt memory region failed (addr=0 size=0)
   Using Device Tree in place at 0000000083100000,rveout for /host1x@50000000/dc@54240000...
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] SMP PREEMPT Mon Nov 4 23:41:41 PST 2024
[    0.000000] Boot CP- 80000000 ,  3f200000
[    0.000000] OF: fdt: - c0000000 ,  3ee00000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
0000.233] Platform has DDR4 type RAM] enabl[0000.204] [L4T TegraBoot] (version 00.00.2018.01-l4t-b1625959)
[0000.236] max77620 disabling SD1 Remote Sense
[0000.240] Setting DDR voltage to 1125mv
[0000.244] Serial Number of Pmic Max77663: 0x12126b
f8
[0000.263] Last reboot was clean, booting normally!
[0000.268] Sdram initialization is successful
[0000.272] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.278] Lp0 Caw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.290] G1] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.307] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.419] PT: Partition LNX NOT found ! o failover; Continuing ...
[0000.423] *** Booting KFS0.
[0000.426] NvTbootFailControlDoFailover: No failover; Continuing ...
[0000.432] BoardID = 3448, SKU = 0x2
[0000.435] [0000.454] NvTbootFailControlDoFailover: No failover; Continuing[0000.477] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.484] Bootloader downloaded successfully.
[is up
[0000.499] CPU clock enabled
[0000.526] Loading NvTbootBootloaderDTB
[0000.543] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mod[0000.615] Bootloader DTB Load Address: 0x83000000
[0000.619] B[0000.645] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.724] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.737] Loading cboot binary
[0000.747] Verifying EBT in OdmNonSecureSBK mode
0000.800] BoardID = 3448, SKU = 0x2
[0000.804] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0000.824] Next binary entry address: 0x92c00258
[0000.828] BoardId: 3448
[0000.833] Overriding pmu board id with proc board id
[0000.838QSPI-ONLY, check GPT table first ...
[0000.851] NvTbootFailControlDoFailover: No failover; Continuing[0000.954] /bpmp deleted
[0000.956] SC7EntryFw header found loaded at 0xff700000
001.370] BoardID = 3448, SKU = 0x2
[0001.373] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[0001.379] NvTbootFailControlDoFailover: No failover; Continuing ...
cky Bits
[0001.399] GSC2 address ff53fffc value c0edbbcc
st ...
[0001.418] TOS Image length 53680
[0001.421]  Monitor size 53680
[0001.424]  OS size 0
[0001.429] Secure Os AES-CMAC Verification Success!
[0001.434] [0001.454] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.458] NvTbootPackSdramParams: start.
96 us
[0001.475] Sec Bootdevice Read Time = 53 ms, Read Size = 3682 KB
[0001.481] Sec Bootdevice Write Time = 0 ms, Write Size651741 us
[0001.498] Total time taken by TegraBoot 1370147 us
[0001.503] Starting CPU & Halting co-processor
643:37:38, Nov  4 2024
ERROR:   Error initializing runtime service trusty_fast
[0001.625] RamCode = 1
[0001.627] get_emc_table_offset: Can't find emc-table node
[0001.632] LPDDR4 Training: Can't find emc-t[0001.679]
[0001.680] Debug Init done
[0001.683] Marked DTB cacheable
[0001.686] Bootloader DTB loaded at 0x83000000
[0001.691] Marked DTB cacheable
[0001.694] Kernel DTB loaded at 0x83100000
[0001.698] DeviceTree Init done
[0001.728] Using base:0x60005090 & irq:208 for tick-timer
[0001.733] Using base:0x60005098 for delay-timer
[0001.738] platform.755] Cboot Version: 00.00.2018.01-t210-acb23272
[0001.759] calling constructors
[0001.762] initializing heap
[0001.765] initializing threads
[0001.768] initializing timers
[0001.771] creating bootstrap completion thread
[0001.775] top of bootstrap2()
[0001.778] CPU: ARM Cortex A57
[0001.781] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.786] initializing platform
1.852] Un-powergate APE partition
[0001.855] of_register: regisinv20628-driver to of_hal
[0001.866] of_register: registering ads1015-driver to of_hal
[0001.871] of_register: registering lp8441_fuel_gauge to of_hal
[0001.952] gpio_driver_register: register 'tegra_gpio_driver' dr[0001.967] fixed regulator driver initialized
esent
[0001.994] Skipping dts_overrides
[0001.999] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.045] I2C Bus Init done
[0002.048] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0002.072] I2C Bus Init done
[0002.075] of_children_init: Ops fdia,tegra210-i2c
[0002.113] I2C Bus Init done
 256, type 0
[0002.154] pm_ids_update: Updating 1,a0, size 256,ed
[0002.176] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.222] pm_ids_update: pm id update successful
[0002.226] pm_ids_update: Updating 3,ae, size 256, type 0
.262] pm_ids_update: eeprom init failed
[0002.292] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.312] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.320] updating /chosen/nvidia,ethernet-mac node 3c<MAC MASKED BY AUTHOR>:158250,mmio32,0x70006000
[0002.356] Find /i2c@7000c000's alias i2c0
[0002.360] get eeprom at 1-a0, size 256, type 0
[0002.434] pm_ids_update: The pm board id is 3448-0002-402
[0002.441] Adding plugin-manager/ids/3448-0002-402=/i2c@7000c500[0002.518] Add serial number:1424624333301 as DT property
Proceeding to Cold Boot
[0002.567] starting app android_boot_app
[0002.571] Device state: unlocked
[0002.574] display console init
[0002.607] hdmi cable not connected
[0002.6HDMI not connected, returning false
[0002.624] hdmi is not connected
[0002.627] sor0 is not supported
[0002.630] display_console_init: no valid display out_type
oard init success
[0002.715] decompressing blob (type 1)...
d to retrieve display resolution
[0002.789] Could not load/init02] SE operation failed
[0002.805] bl_battery_charging: connected to external power supply
[0002.829] device_query_partition_size: failed to open partition[0002.846] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[0002.854] USP partition read failed!
[0002.857] blob_init: blob-partition USP header read failed
[0002.863] android_boot Unable to update recovery partition
[0002.868] kfs_getpartname: name = LNX
[0002.964] load kernel from storage
[0002.973] decompressor handler not found
[0003.007] Successfully loaded kernel and ramdisk images
[0003.[0003.017] display_resolution: No display init
[0003.021] Faile03.034] NCK carveout not present
[0003.037] Skipping dts_overri[0003.052] Find /i2c@7000c000's alias i2c0
[0003.055] get eepro[0003.065] Find /i2c@7000c500's alias i2c2
[0003.069] get eepro 256, type 0
[0003.078] pm_ids_update: Updating 1,a0, size 256,ed
[0003.100] pm_ids_update: Updating 3,a0, size 256, type 0
[0003.130] pm_ids_update: The pm board id is 3448-0002-402
[0003.180] eeprom_init: EEPROM incompatible version found
[0003[0003.216] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0003.222] shim_eeprom_update_mac:267: Failed to update 0 MAC :05:b9
[0003.251] Plugin Manager: Parse ODM data 0x000a4000
[0003.272] Add serial number:1424624333301 as DT property
[0003.282] "bpmp" doesn't exist, creating
[0003.293] Updated initrd info to DTB
[0003.296] "proc-board" d[0003.302] Updated board info to DTB
[0003.305] "pmu-board" doesn't exist, creating
[0003.321] Updated board info to DTB
[0003.324] "reset" doesn't_ioctl: No display init
[0003.337] display_console_ioctl: No did=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1125 core_edp_ma=4000 gpt
[0003.402] Updated bootarg info to DTB
[0003.406] Adding uuid 000000016440b705080000000bff8200 to DT
[0003.412] Adding eks info 0 to DT
[0003.433] set vdd_core voltage to 1125 mv
[0003.437] setting 'vdd-core' regulator to 1125000 micro volts
[0003.443] Found sec
                    SoC: tegra210
Model: NVIDIA Jetson Nano Developer Kit
Board: MMC:   sdhci@700b0000: 1, sdhci@700b0600: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
 0
Scanning mmc 0:1...
Retrieving file: /boot/extlinux/extlinux.conf
879 bytes read in 44 ms (18.6 KiB/s)
1:      primary kernel
Retrieving file: /boot/initrd
append: tegraid=21.1.2.0.0 ddr_die=2048M@2048M section=256M memtype=0 vpr_resize usb_p,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstfdt blob at 0x83100000
ERROR: reserving fdt memory region faile end 000000008317ce8d
copying carveout for /host1x@50000000/dc@54200000...
copying ca Linux version 4.9.337-tegra (buildbrain@mobile-u64-5499-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120acan node memory@80000000, reg size 32,
[    0.000000] OF: fdt: - 80000000 ,  3f200000
[    0.000000] OF: fdt: - c0000000 ,  3eed
Below is the output for apt-get upgrade command
sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0
  kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
  libkdecorations2private5v5 libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data
  libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5 libkf5idletime5
  libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
  libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5
  libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
  libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkscreenlocker5
  libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5
  libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5 libqt5quickwidgets5
  libqt5sql5 libqt5test5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 python3-dbus.mainloop.pyqt5 python3-icu python3-pam
  python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit qml-module-org-kde-kquickcontrolsaddons qml-module-qtmultimedia
  qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  nvidia-l4t-3d-core nvidia-l4t-apt-source nvidia-l4t-bootloader nvidia-l4t-camera nvidia-l4t-configs nvidia-l4t-core nvidia-l4t-cuda
  nvidia-l4t-firmware nvidia-l4t-gputools nvidia-l4t-graphics-demos nvidia-l4t-gstreamer nvidia-l4t-init nvidia-l4t-initrd
  nvidia-l4t-jetson-io nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers nvidia-l4t-libvulkan nvidia-l4t-multimedia
  nvidia-l4t-multimedia-utils nvidia-l4t-oem-config nvidia-l4t-tools nvidia-l4t-wayland nvidia-l4t-weston nvidia-l4t-x11
  nvidia-l4t-xusb-firmware python3-update-manager ubuntu-advantage-desktop-daemon ubuntu-advantage-tools ubuntu-pro-client
  update-manager update-manager-core wireless-regdb wpasupplicant
34 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 134 MB of archives.
After this operation, 191 kB of additional disk space will be used.
Do you want to continue? [Y/n] n
Hi pranaynhbpn,
Are you using the devkit or custom board for Jetson Nano?
If you are using the custom carrier board, please also help to verify if you can reproduce the same behavior on the devkit.
Do you mean that you would hit the boot issue even if you’ve selected n to prevent update nvidia-l4t-* packages?
We dont have a dev kit. But I checked on two boards:
  1. Waveshare JETSON-NANO-LITE-DEV-KIT-A
  2. Stackfusion Jetson nano board(Which already is a production baord with ~500-600 boards deployed on field)
The system works normally incase I dont do an apt-get upgrade. So if I hit 'n' to prevent the upgrade the system works fine.
Could you try to run the following command before run apt upgrade to check it can help for your case?
$ sudo apt-mark hold nvidia-l4t-display-kernel nvidia-l4t-kernel nvidia-l4t-kernel-dtbs nvidia-l4t-kernel-headers nvidia-l4t-kernel-oot-headers nvidia-l4t-kernel-oot-modules
