I just tried to update from 384.90 to 384.98 on Ubuntu 16.04 and get
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
Here is the log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Nov 15 09:35:25 2017
installer version: 384.98
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/u
sr/local/games
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 8 CPUs online; setting concurrency level to 8.
→ License accepted.
→ Installing NVIDIA driver version 384.98.
→ There appears to already be a driver installed on your system (version: 384.9
0). As part of installing this driver (version: 384.98), the existing driver wi
ll be uninstalled. Are you sure you want to continue? (Answer: Continue install
ation)
→ Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
→ done.
→ The distribution-provided pre-install script failed! Are you sure you want t
o continue? (Answer: Continue installation)
→ Would you like to register the kernel module sources with DKMS? This will all
ow DKMS to automatically build a new module, if you install a different kernel l
ater. (Answer: Yes)
→ Installing both new and classic TLS OpenGL libraries.
→ Installing both new and classic TLS 32bit OpenGL libraries.
→ Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
→ Will install GLVND GLX client libraries.
→ Will install GLVND EGL client libraries.
→ Skipping GLX non-GLVND file: “libGL.so.384.98”
→ Skipping GLX non-GLVND file: “libGL.so.1”
→ Skipping GLX non-GLVND file: “libGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.384.98”
→ Skipping EGL non-GLVND file: “libEGL.so”
→ Skipping EGL non-GLVND file: “libEGL.so.1”
→ Skipping GLX non-GLVND file: “./32/libGL.so.384.98”
→ Skipping EGL non-GLVND file: “./32/libEGL.so.384.98”
→ Uninstalling the previous installation with /usr/bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-
install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Can’t load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared
object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (384.98):
executing: ‘/sbin/ldconfig’…
→ done.
→ Driver file installation is complete.
→ Installing DKMS kernel module:
→ done.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.
log’ for details. You may find suggestions on fixing installation problems in t
he README available on the Linux driver download page at www.nvidia.com.
