Hi there,
My problem:
After Installation of the Nvidia-Driver I stuck at the Login-Screen (Login-Loop). What am I missing?
My environment:
OS: Ubuntu 16.04.4
Kernel: 4.8.0-36-generic (Downgraded from 4.13.0… because of errors in 384.99-Run-File-Installation)
Card: NVIDIA Tesla M60
Driver: NVIDIA-Linux-x86_64-384.99 (Run-File)
Installation-Procedure:
- nano /etc/modprobe.d/blacklist-nouveau.conf
blacklist nouveau
options nouveau modeset=0
- sudo update-initramfs -u
- sudo reboot
- service lightdm stop
- init 3
- sudo sh ./NVIDIA-Linux-x86_64-384.99-grid.run
- sudo reboot
nvidia-installer.log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Thu Mar 8 15:29:52 2018
installer version: 384.99
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
-> License accepted.
-> Installing NVIDIA driver version 384.99.
-> Running distribution scripts
executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: "libGL.so.384.99"
-> Skipping GLX non-GLVND file: "libGL.so.1"
-> Skipping GLX non-GLVND file: "libGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.384.99"
-> Skipping EGL non-GLVND file: "libEGL.so"
-> Skipping EGL non-GLVND file: "libEGL.so.1"
-> Skipping GLX non-GLVND file: "./32/libGL.so.384.99"
-> Skipping EGL non-GLVND file: "./32/libEGL.so.384.99"
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Checking for libglvnd installation.
Checking libGLdispatch...
Can't load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (384.99):
executing: '/sbin/ldconfig'...
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
executing: '/usr/lib/nvidia/post-install'...
nvidia-gridd systemd service successfully installed.
-> done.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: Yes)
-> Your X configuration file has been successfully updated. Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 384.99) is now complete.
nvidia-xconfig created following xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 384.99 (buildmeister@swio-display-x86-rhel47-06) Sun Oct 29 04:14:45 PDT 2017
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
nvidia-smi output:
Thu Mar 8 15:46:15 2018
| NVIDIA-SMI 384.99 Driver Version: 384.99 |
| 0 GRID M60-1Q Off | 00000000:02:00.0 Off | N/A |
| N/A N/A P8 N/A / N/A | 80MiB / 1023MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
nvidia-settings output:
Failed to connect to Mir: Failed to connect to server socket: Datei oder Verzeichnis nicht gefunden
Unable to init server: Verbindung ist gescheitert: Verbindungsaufbau abgelehnt
ERROR: The control display is undefined; please run `nvidia-settings --help` for usage information.
