Nouveau driver disable in ubuntu 16
while installing nvidia its asking to disable nouveau
One or more modprobe configuration files to disable Nouveau are
already present at:
/etc/modprobe.d/nvidia-installer-disable-nouveau.conf. Please be
sure you have rebooted your system since these files were written.
If you have rebooted, then Nouveau may be enabled for other
reasons, such as being included in the system initial ramdisk or in
your X configuration file. Please consult the NVIDIA driver README
and your Linux distribution’s documentation for details on how to
correctly disable the Nouveau kernel driver.
its already disabled from /etc/modprobe.d/nvidia-installer-disable-nouveau.conf.
hi
can anyone please help for this issue
I, for an instance, have no idea what the actual problem is?
hi,
We are using Ubuntu16.04 LTS physical machine,using nvidia card quadro k2200
we tried to installed recommeded driver 384 but getting login loop issue,so we have downloaded driver from nvidia site for linux and tried to install
above error getting while installing package
Please add the graphics driver ppa
https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa
and then install the driver using the Software&Updates application.
Please give me details commands what should i run,i am new to ubuntu
we have added
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
tried installing again but getting same error
Start the “Software&Updates” application on the desktop, go to “additional drivers” and select the latest nvidia driver.
we tried samething,tried from softwares& updates,but still getting same error.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
we are trying to install in customized os which provided by our organization,wil it effect that
hi,
i have run that commamd but getting
root@ozd2084u:/home/uidn1541/Downloads# sudo nvidia-bug-report.sh
sudo: nvidia-bug-report.sh: command not found
please check this
So nothing got installed at all.
Please post the output of
sudo lspci
and
sudo dmesg |grep -i secure
root@ozd2084u:~# sudo lspci
00:00.0 Host bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DMI2 (rev 01)
00:01.0 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 (rev 01)
00:02.0 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 2 (rev 01)
00:03.0 PCI bridge: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 3 (rev 01)
00:05.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Map/VTd_Misc/System Management (rev 01)
00:05.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO Hot Plug (rev 01)
00:05.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors (rev 01)
00:05.4 PIC: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D I/O APIC (rev 01)
00:11.0 Unassigned class [ff00]: Intel Corporation C610/X99 series chipset SPSR (rev 05)
00:11.4 RAID bus controller: Intel Corporation C610/X99 series chipset sSATA Controller [RAID mode] (rev 05)
00:14.0 USB controller: Intel Corporation C610/X99 series chipset USB xHCI Host Controller (rev 05)
00:16.0 Communication controller: Intel Corporation C610/X99 series chipset MEI Controller #1 (rev 05)
00:16.3 Serial controller: Intel Corporation C610/X99 series chipset KT Controller (rev 05)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection (2) I218-LM (rev 05)
00:1a.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation C610/X99 series chipset HD Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #1 (rev d5)
00:1c.1 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #2 (rev d5)
00:1c.3 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation C610/X99 series chipset PCI Express Root Port #5 (rev d5)
00:1d.0 USB controller: Intel Corporation C610/X99 series chipset USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation C610/X99 series chipset LPC Controller (rev 05)
00:1f.2 RAID bus controller: Intel Corporation C600/X79 series chipset SATA RAID Controller (rev 05)
00:1f.3 SMBus: Intel Corporation C610/X99 series chipset SMBus Controller (rev 05)
02:00.0 VGA compatible controller: NVIDIA Corporation GM107GL [Quadro K2200] (rev a2)
02:00.1 Audio device: NVIDIA Corporation Device 0fbc (rev a1)
06:00.0 PCI bridge: Integrated Technology Express, Inc. IT8893E PCIe to PCI Bridge (rev 52)
ff:0b.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 (rev 01)
ff:0b.1 Performance counters: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 (rev 01)
ff:0b.2 Performance counters: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 (rev 01)
ff:0b.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link Debug (rev 01)
ff:0c.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0c.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0c.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0c.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0f.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0f.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0f.4 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0f.5 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:0f.6 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent (rev 01)
ff:10.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent (rev 01)
ff:10.1 Performance counters: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent (rev 01)
ff:10.5 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox (rev 01)
ff:10.6 Performance counters: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox (rev 01)
ff:10.7 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox (rev 01)
ff:12.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 (rev 01)
ff:12.1 Performance counters: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 (rev 01)
ff:13.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS (rev 01)
ff:13.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS (rev 01)
ff:13.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder (rev 01)
ff:13.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder (rev 01)
ff:13.4 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder (rev 01)
ff:13.5 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder (rev 01)
ff:13.6 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Broadcast (rev 01)
ff:13.7 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast (rev 01)
ff:14.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Thermal Control (rev 01)
ff:14.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Thermal Control (rev 01)
ff:14.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Error (rev 01)
ff:14.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Error (rev 01)
ff:14.4 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface (rev 01)
ff:14.5 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface (rev 01)
ff:14.6 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface (rev 01)
ff:14.7 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface (rev 01)
ff:15.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Thermal Control (rev 01)
ff:15.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Thermal Control (rev 01)
ff:15.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Error (rev 01)
ff:15.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Error (rev 01)
ff:16.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Target Address/Thermal/RAS (rev 01)
ff:16.6 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Broadcast (rev 01)
ff:16.7 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast (rev 01)
ff:17.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 1 - Channel 0 Thermal Control (rev 01)
ff:17.4 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface (rev 01)
ff:17.5 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface (rev 01)
ff:17.6 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface (rev 01)
ff:17.7 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface (rev 01)
ff:1e.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1e.1 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1e.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1e.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1e.4 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1f.0 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
ff:1f.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit (rev 01)
root@ozd2084u:~# sudo dmesg |grep -i secure
root@ozd2084u:~#
Please try installing the driver by running
sudo apt-get install nvidia-430
Please post the output you’re getting.
root@ozd2084u:~# sudo apt-get install nvidia-430
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
libcuda1-430 nvidia-opencl-icd-430 nvidia-prime nvidia-settings
The following NEW packages will be installed:
libcuda1-430 nvidia-430 nvidia-opencl-icd-430 nvidia-prime nvidia-settings
0 upgraded, 5 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/84.0 MB of archives.
After this operation, 405 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Selecting previously unselected package nvidia-430.
(Reading database … 234814 files and directories currently installed.)
Preparing to unpack …/nvidia-430_430.64-0ubuntu0~gpu16.04.6_amd64.deb …
Unpacking nvidia-430 (430.64-0ubuntu0~gpu16.04.6) …
Selecting previously unselected package libcuda1-430.
Preparing to unpack …/libcuda1-430_430.64-0ubuntu0~gpu16.04.6_amd64.deb …
Unpacking libcuda1-430 (430.64-0ubuntu0~gpu16.04.6) …
Selecting previously unselected package nvidia-opencl-icd-430.
Preparing to unpack …/nvidia-opencl-icd-430_430.64-0ubuntu0~gpu16.04.6_amd64.deb …
Unpacking nvidia-opencl-icd-430 (430.64-0ubuntu0~gpu16.04.6) …
Selecting previously unselected package nvidia-prime.
Preparing to unpack …/nvidia-prime_0.8.2_amd64.deb …
Unpacking nvidia-prime (0.8.2) …
Selecting previously unselected package nvidia-settings.
Preparing to unpack …/nvidia-settings_418.56-0ubuntu0~gpu16.04.1_amd64.deb …
Unpacking nvidia-settings (418.56-0ubuntu0~gpu16.04.1) …
Processing triggers for libc-bin (2.23-0ubuntu11.2) …
Processing triggers for man-db (2.7.5-1) …
Processing triggers for ureadahead (0.100.0-19.1) …
ureadahead will be reprofiled on next reboot
Processing triggers for desktop-file-utils (0.22-1ubuntu5.2) …
Processing triggers for gnome-menus (3.13.3-6ubuntu3.1) …
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20180209-0ubuntu1) …
Rebuilding /usr/share/applications/bamf-2.index…
Processing triggers for mime-support (3.59ubuntu1) …
Setting up nvidia-430 (430.64-0ubuntu0~gpu16.04.6) …
update-alternatives: using /usr/lib/nvidia-430/alt-ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) in auto mode
update-alternatives: using /usr/lib/nvidia-430/alt-ld.so.conf to provide /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) in auto mode
update-alternatives: using /usr/share/nvidia-430/glamor.conf to provide /usr/share/X11/xorg.conf.d/glamoregl.conf (glamor_conf) in auto mode
update-initramfs: deferring update (trigger activated)
update-initramfs: Generating /boot/initrd.img-4.15.0-133-generic
INFO:Enable nvidia-430
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
Adding system user nvidia-persistenced' (UID 126) ... Adding new group nvidia-persistenced’ (GID 132) …
Adding new user nvidia-persistenced' (UID 126) with group nvidia-persistenced’ …
Not creating home directory `/'.
Removing old nvidia-430.64 DKMS files…
-------- Uninstall Beginning --------
Module: nvidia
Version: 430.64
Kernel: 4.15.0-133-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
  • Uninstallation
    • Deleting from: /lib/modules/4.15.0-133-generic/updates/dkms/
  • Original module
    • No original module was found for this module on this kernel.
    • Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
  • Uninstallation
  • Original module
nvidia-drm.ko:
  • Uninstallation
  • Original module
nvidia-uvm.ko:
  • Uninstallation
  • Original module
depmod…
DKMS: uninstall completed.
Deleting module version: 430.64
completely from the DKMS tree.
Done.
Loading new nvidia-430.64 DKMS files…
First Installation: checking all kernels…
It is likely that 4.15.0-133-generic belongs to a chroot’s host
Building for architecture x86_64
Building initial module for 4.15.0-133-generic
Done.
nvidia:
Running module version sanity check.
  • Original module
    • No original module exists within this kernel
  • Installation
    • Installing to /lib/modules/4.15.0-133-generic/updates/dkms/
nvidia-modeset.ko:
  • Original module
  • Installation
nvidia-drm.ko:
  • Original module
  • Installation
nvidia-uvm.ko:
  • Original module
  • Installation
depmod…
DKMS: install completed.
Setting up libcuda1-430 (430.64-0ubuntu0~gpu16.04.6) …
Setting up nvidia-opencl-icd-430 (430.64-0ubuntu0~gpu16.04.6) …
Setting up nvidia-prime (0.8.2) …
Setting up nvidia-settings (418.56-0ubuntu0~gpu16.04.1) …
Processing triggers for initramfs-tools (0.122ubuntu8.17) …
root@ozd2084u:~# sudo nvidia-smi
sudo: nvidia-smi: command not found
root@ozd2084u:~#
root@ozd2084u:~# sudo nvidia-bug-report.sh
nvidia-bug-report.sh will now collect information about your
system and create the file ‘nvidia-bug-report.log.gz’ in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
If nvidia-bug-report.sh hangs, consider running with the --safe-mode
and --extra-system-data command line arguments.
Please include the ‘nvidia-bug-report.log.gz’ log file when reporting
your bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
By delivering ‘nvidia-bug-report.log.gz’ to NVIDIA, you acknowledge
and agree that personal information may inadvertently be included in
the output. Notwithstanding the foregoing, NVIDIA will use the
output only for the purpose of investigating your reported issue.
Running nvidia-bug-report.sh…
complete.
we are getting login loop issue after installing this driver.
A file nvidia-bug-report.log.sh should have been created, please attach that to your post.
Please try this:
having the driver installed, booting to the login loop.
Switch to VT using ctrl+alt+f4
login on text console with your user
run:
sudo rm nvidia-bug-report.log.gz
sudo apt-get install pastebinit
gunzip nvidia-bug-report.log.gz
pastebinit -i nvidia-bug-report.log
  • note down and post the url you’re given
