I used the graphics-drivers/ppa repository to install 378.13 driver on Ubuntu 16.04LTS as this version is the recommended one for GTX 1080TI. However, the driver suggestion is not shown after sudo apt update.
$ sudo ubuntu-drivers list
intel-microcode
I instead installed with
$sudo apt install nvidia-378
and stuck in a Login Loop.
The error message in /var/log/Xorg.0.log is :
[ 11.238]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 11.238] X Protocol Version 11, Revision 0
[ 11.238] Build Operating System: Linux 4.4.0-59-generic x86_64 Ubuntu
[ 11.238] Current Operating System: Linux Heisenberg 4.8.0-41-generic #44~16.04.1-Ubuntu SMP Fri Mar 3 17:11:16 UTC 2017 x86_64
[ 11.238] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.8.0-41-generic.efi.signed root=UUID=8251434e-66ad-489d-a8ab-076c4d835cd9 ro quiet splash vt.handoff=7
[ 11.238] Build Date: 26 January 2017 12:26:18AM
[ 11.238] xorg-server 2:1.18.4-1ubuntu6.1~16.04.1 (For technical support please see http://www.ubuntu.com/support)
[ 11.238] Current version of pixman: 0.33.6
[ 11.238] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 11.238] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 11.238] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 18 18:43:54 2017
[ 11.239] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.239] (==) No Layout section. Using the first Screen section.
[ 11.239] (==) No screen section available. Using defaults.
[ 11.239] (**) |-->Screen "Default Screen Section" (0)
[ 11.239] (**) | |-->Monitor "<default monitor>"
[ 11.239] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 11.239] (==) Automatically adding devices
[ 11.239] (==) Automatically enabling devices
[ 11.239] (==) Automatically adding GPU devices
[ 11.239] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.239] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 11.239] Entry deleted from font path.
[ 11.239] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 11.239] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 11.239] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 11.239] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 11.239] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 11.239] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 11.239] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 11.239] (II) Loader magic: 0x561f77419dc0
[ 11.239] (II) Module ABI versions:
[ 11.239] X.Org ANSI C Emulation: 0.4
[ 11.239] X.Org Video Driver: 20.0
[ 11.239] X.Org XInput driver : 22.1
[ 11.239] X.Org Server Extension : 9.0
[ 11.240] (++) using VT number 7
[ 11.240] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.241] (--) PCI:*(0:6:0:0) 10de:1b06:10de:120f rev 161, Mem @ 0xfa000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 11.241] (II) LoadModule: "glx"
[ 11.242] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.248] (II) Module glx: vendor="X.Org Foundation"
[ 11.248] compiled for 1.18.4, module version = 1.0.0
[ 11.248] ABI class: X.Org Server Extension, version 9.0
[ 11.248] (==) AIGLX enabled
[ 11.248] (==) Matched nvidia as autoconfigured driver 0
[ 11.248] (==) Matched nouveau as autoconfigured driver 1
[ 11.248] (==) Matched modesetting as autoconfigured driver 2
[ 11.248] (==) Matched fbdev as autoconfigured driver 3
[ 11.248] (==) Matched vesa as autoconfigured driver 4
[ 11.248] (==) Assigned the driver to the xf86ConfigLayout
[ 11.248] (II) LoadModule: "nvidia"
[ 11.248] (WW) Warning, couldn't open module nvidia
[ 11.248] (II) UnloadModule: "nvidia"
[ 11.248] (II) Unloading nvidia
[ 11.248] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 11.248] (II) LoadModule: "nouveau"
[ 11.248] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 11.249] (II) Module nouveau: vendor="X.Org Foundation"
[ 11.249] compiled for 1.18.4, module version = 1.0.12
[ 11.249] Module class: X.Org Video Driver
[ 11.249] ABI class: X.Org Video Driver, version 20.0
[ 11.249] (II) LoadModule: "modesetting"
[ 11.249] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.249] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.249] compiled for 1.18.4, module version = 1.18.4
[ 11.249] (II) LoadModule: "fbdev"
[ 11.249] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 11.249] (II) Module fbdev: vendor="X.Org Foundation"
[ 11.249] compiled for 1.18.4, module version = 0.4.4
[ 11.249] (II) LoadModule: "vesa"
[ 11.249] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 11.249] (II) Module vesa: vendor="X.Org Foundation"
[ 11.249] compiled for 1.18.4, module version = 2.3.4
[ 11.249] (==) Matched nvidia as autoconfigured driver 0
[ 11.249] (==) Matched nouveau as autoconfigured driver 1
[ 11.249] (==) Matched modesetting as autoconfigured driver 2
[ 11.249] (==) Matched fbdev as autoconfigured driver 3
[ 11.249] (==) Matched vesa as autoconfigured driver 4
[ 11.249] (==) Assigned the driver to the xf86ConfigLayout
[ 11.249] (II) LoadModule: "nvidia"
[ 11.249] (WW) Warning, couldn't open module nvidia
[ 11.249] (II) UnloadModule: "nvidia"
[ 11.249] (II) Unloading nvidia
[ 11.249] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 11.249] (II) LoadModule: "nouveau"
[ 11.249] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 11.249] (II) UnloadModule: "nouveau"
[ 11.249] (II) Unloading nouveau
[ 11.249] (II) Failed to load module "nouveau" (already loaded, 0)
[ 11.250] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.250] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.250] compiled for 1.18.4, module version = 1.18.4
[ 11.250] Module class: X.Org Video Driver
[ 11.250] ABI class: X.Org Video Driver, version 20.0
[ 11.250] (II) UnloadModule: "modesetting"
[ 11.250] (II) Unloading modesetting
[ 11.250] (II) Failed to load module "modesetting" (already loaded, 0)
[ 11.250] (II) LoadModule: "fbdev"
[ 11.250] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 11.250] (II) Module fbdev: vendor="X.Org Foundation"
[ 11.250] compiled for 1.18.4, module version = 0.4.4
[ 11.250] (II) UnloadModule: "fbdev"
[ 11.250] (II) Unloading fbdev
[ 11.250] (II) Failed to load module "fbdev" (already loaded, 0)
[ 11.250] (II) LoadModule: "vesa"
[ 11.250] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 11.250] (II) Module vesa: vendor="X.Org Foundation"
[ 11.250] compiled for 1.18.4, module version = 2.3.4
[ 11.250] (II) UnloadModule: "vesa"
[ 11.250] (II) Unloading vesa
[ 11.250] (II) Failed to load module "vesa" (already loaded, 0)
[ 11.250] (II) NOUVEAU driver Date: Tue Dec 8 15:52:25 2015 +1000
[ 11.250] (II) NOUVEAU driver for NVIDIA chipset families :
[ 11.250] RIVA TNT (NV04)
[ 11.250] RIVA TNT2 (NV05)
[ 11.250] GeForce 256 (NV10)
[ 11.250] GeForce 2 (NV11, NV15)
[ 11.250] GeForce 4MX (NV17, NV18)
[ 11.250] GeForce 3 (NV20)
[ 11.250] GeForce 4Ti (NV25, NV28)
[ 11.250] GeForce FX (NV3x)
[ 11.250] GeForce 6 (NV4x)
[ 11.250] GeForce 7 (G7x)
[ 11.250] GeForce 8 (G8x)
[ 11.250] GeForce GTX 200 (NVA0)
[ 11.250] GeForce GTX 400 (NVC0)
[ 11.250] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.250] (II) FBDEV: driver for framebuffer: fbdev
[ 11.250] (II) VESA: driver for VESA chipsets: vesa
[ 11.250] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[ 11.371] (EE) [drm] Failed to open DRM device for pci:0000:06:00.0: -19
[ 11.495] (EE) [drm] Failed to open DRM device for pci:0000:06:00.0: -19
[ 11.495] (EE) open /dev/dri/card0: No such file or directory
[ 11.495] (WW) Falling back to old probe method for modesetting
[ 11.495] (II) Loading sub module "fbdevhw"
[ 11.495] (II) LoadModule: "fbdevhw"
[ 11.495] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 11.495] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 11.495] compiled for 1.18.4, module version = 0.0.2
[ 11.495] ABI class: X.Org Video Driver, version 20.0
[ 11.495] (**) FBDEV(2): claimed PCI slot 6@0:0:0
[ 11.495] (II) FBDEV(2): using default device
[ 11.495] (WW) Falling back to old probe method for vesa
[ 11.495] (EE) Screen 0 deleted because of no matching config section.
[ 11.495] (II) UnloadModule: "modesetting"
[ 11.495] (II) FBDEV(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
