I have a problem: Since I installed the driver nvidia 384.130 I have a loop login. How to solve the problem knowing that I absolutely need to run my graphics car wich is Quadro M3000M on Ubuntu 16.04 with kernel 4.4.0-142.
My laptop is a HP-ZBook-17-G3
Attachement nvidia-bug-report, nvidia-installer.log
nvidia-bug-report.log (519 KB)
nvidia-installer.log (26.5 KB)
config_pc.txt (115 Bytes)
second_nvidia-bug-report.log (1.56 MB)
Please delete the files
/usr/share/X11/xorg.conf.d/10-nvidia-375-system76-0-bonw11.conf
/usr/share/X11/xorg.conf.d/10-nvidia-375-system76-0-serw10.conf
/usr/share/X11/xorg.conf.d/10-nvidia-375-system76-pc.conf
and reboot. If it still doesn’t work, create a new nvidia-bug-report.log.
Furthermore, you seem to have run the .run installer on an Optimus system. Please uninstall it using the --uninstall option. Afterwards, please add the ubuntu graphics ppa :
[url]https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa[/url]
and install the driver from there (sudo apt install nvidia-driver-415)
Make sure the package nvidia-prime is installed (sudo apt install nvidia-prime)
Then delete your /etc/X11/xorg.conf and switch to nvidia gpu
sudo prime-select nvidia
Afterwards, reboot.
…aaand you need to upgrade your HWE stack to get the needed supplemetary drivers for your system:
sudo apt-get install --install-recommends linux-generic-hwe-16.04 xserver-xorg-hwe-16.04
Package not found : nvidia-driver-415
My command :
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
But no find package
Sorry, for Ubuntu 16.04 the package is called nvidia-415
sudo apt install nvidia-415
Ok, it is done but my problem is already there.
Attachement : nvidia-bug-report
Please remove the kernel parameter ‘nomodeset’.
Also, please reinstall the driver using
apt install --reinstall nvidia-415
There’s a config file missing that’s included in that package.
You are very helpful.
Thanks you very much, my graphic card is now activate !!!
Thanks you very much generix !!!
Looks like a known problem:
[url]https://bugs.launchpad.net/ubuntu/+source/indicator-datetime/+bug/1553696[/url]
Please do a full system update using
sudo apt update && sudo apt upgrade
Please provide a new nvidia-bug-report.log.
You’re welcome. The driver will now be updated along with your system, so please don’t use any nvidia .run installers anymore as those would break your system.
