3F function and MPI
one user reported a problem using 3F functions.
Using the normal pgi comipler everything is fine.
using mpif90 (from pgi) the 3F functions are NOT working.
Whats wrong ?
mpif90 -o read_test read_test.f90
./read_test
0
0
Aber mit pgf90 compiliert funktioniert es richtig:
pgf90 -o read_test read_test.f90
./read_test
0
40
code:
program read_test
implicit none
integer :: ftell
integer :: ihead(8)
open(11, FILE=“landsea.srv”, STATUS=‘old’, FORM=‘unformatted’)
write(,) ftell(11)
read(11) ihead
write(,) ftell(11)
close(11)
end
Hi pekompi,
It looks like a library ordering issue. The mpif90 driver is adding the F77 runtime before the F90 runtime library so ftell is pick-up up the F77 I/O. Since the F77 and F90 I/O are completely separate, ftell shows that the file hasn’t moved.
The workaround is to add “-lpgf90rtl” to the mpif90 link so that the ftell uses the F90 I/O.
% mpif90 mp.f90 ; a.out
            0
            0
% mpif90 mp.f90 -lpgf90rtl ; a.out
            0
           24
I have submitted a problem report (TPR#18598) requesting the mpif90 that we ship be updated.
  • Mat
This TPR was fixed in our 12.5 release.
Sorry about the late word.
dave
