How to Use API Key in a Way Compatible with OpenAI?
Hi @siyuan-l – take a look at one of the examples on build.nvidia.com, like the one here in the Python tab: llama-3.1-405b-instruct Model by Meta | NVIDIA NIM
Your code should look something like the following:
from openai import OpenAI
client = OpenAI(
base_url = "https://integrate.api.nvidia.com/v1",
api_key = "$API_KEY_REQUIRED_IF_EXECUTING_OUTSIDE_NGC"
completion = client.chat.completions.create(
model="meta/llama-3.1-405b-instruct",
messages=[{"role":"user","content":"Write a limerick about the wonders of GPU computing."}],
temperature=0.2,
top_p=0.7,
max_tokens=1024,
stream=True
for chunk in completion:
if chunk.choices[0].delta.content is not None:
print(chunk.choices[0].delta.content, end="")
If you’re seeing a 404 error, it might be because the base_url or model name aren’t correctly specified
Thanks for your help!
This method works with LLaMA-3.1-405B-Instruct, but it doesn’t work with LLaMA-3.2-90B-Instruct. Is it because the latter hasn’t been adapted yet?
I believe Nvidia API endpoint dosen’t support OpenAI ‘v1/reponses’ endpoint so that lead me 404 in some application which is fixed to referring to ‘v1/reponses’. Should anyone confirm this so I don’t like to try&error.
