Hi
I have a p3767+p3768 orin nx development kit. I want to enable 4K HDMI output. The flash command i used was: JetPack: 5.1.2
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --erase-all --external-device sda1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 jetson-orin-nano-devkit internal
orin nano does not support 4k display
so i tried changing jetson-orin-nano.conf to the below
source "${LDK_DIR}/p3767.conf.common";
# update_flash_args_common:
update_flash_args_common()
local emcfuse_bin="${1}";
local emcpredefvalue="${2}"
if [ ${EMC_OPT_DISABLE_FUSE_OVERRIDE} -eq 0 ]; then
return;
fi
# EMCFUSE_VALUE can be passed by user
emc_opt_disable_fuse="${DEFAULT_EMC_FUSE}";
if [ -n "${emcpredefvalue}" ]; then
emc_opt_disable_fuse="${emcpredefvalue}";
elif [ -f "${emcfuse_bin}" ]; then
emc_opt_disable_fuse=`xxd -ps "${emcfuse_bin}" | xxd -p -r | grep "OptEmcDisable" | awk '{print $2}' | sed 's/.*\(.\)/\1/'`;
fi
echo "emc_opt_disable_fuse:(${emc_opt_disable_fuse})"
if [ "${board_sku}" = "0000" ] || [ "${board_sku}" = "0002" ]; then
# use default DTB and CFG files except for TS1 & EB1 revisions
if [ "${board_FAB}" = "TS1" ] || [ "${board_FAB}" = "EB1" ]; then
PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-dp-a01.dtsi";
PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-dp-a01.dtsi";
BPFDTB_FILE="tegra234-bpmp-3767-0000-a00-3509-a02.dtb";
fi
elif [ "${board_sku}" = "0001" ]; then
BPFDTB_FILE="tegra234-bpmp-3767-0001-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0001-p3768-0000-a0.dtb";
elif [ "${board_sku}" = "0003" ] || [ "${board_sku}" = "0005" ]; then
BPFDTB_FILE="tegra234-bpmp-3767-0003-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0003-p3768-0000-a0.dtb";
elif [ "${board_sku}" = "0004" ]; then
BPFDTB_FILE="tegra234-bpmp-3767-0004-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0004-p3768-0000-a0.dtb";
fi
TBCDTB_FILE="${DTB_FILE}";
# update_flash_args:
update_flash_args()
# All updates should go into update_flash_args_common to allow
# for other files to include this file and override variables.
# update_emmc_cfg_for_bup:
update_emmc_cfg_for_bup()
local bup_type="${1}"
if [ "${bup_blob}" -ne 0 ] && [ "${bup_type}" == "bl" ]; then
EMMC_CFG="flash_t234_qspi.xml";
fi
DEFAULT_EMC_FUSE="0";
PINMUX_CONFIG="tegra234-mb1-bct-pinmux-p3767-hdmi-a03.dtsi";
PMC_CONFIG="tegra234-mb1-bct-padvoltage-p3767-hdmi-a03.dtsi";
BPFDTB_FILE="tegra234-bpmp-3767-0000-a02-3509-a02.dtb";
DTB_FILE="tegra234-p3767-0000-p3509-a02.dtb";
EMMC_CFG="flash_t234_qspi_sd.xml";
OVERLAY_DTB_FILE="${OVERLAY_DTB_FILE},tegra234-p3768-overlay.dtbo";
# Rootfs A/B:
if [[ "${ROOTFS_AB}" == 1 && "${ROOTFS_ENC}" == "" ]]; then
EMMC_CFG=flash_t234_qspi_sd_rootfs_ab.xml;
# Disk encryption support:
elif [[ "${ROOTFS_AB}" == "" && "${ROOTFS_ENC}" == 1 ]]; then
EMMC_CFG=flash_t234_qspi_sd_enc_rfs.xml;
# Rootfs A/B + Disk encryption support:
elif [[ "${ROOTFS_AB}" == 1 && "${ROOTFS_ENC}" == 1 ]]; then
EMMC_CFG=flash_t234_qspi_sd_enc_rootfs_ab.xml;
fi;
i also tried flashing p3768-0000+p3767-0000.conf
sudo ADDITIONAL_DTB_OVERLAY_OPT="BootOrderNvme.dtbo" ./tools/kernel_flash/l4t_initrd_flash.sh --erase-all --external-device sda1 -c tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3768-0000+p3767-0000 internal
but the board did not boot up completely.
i tried using the p3509-a02+p3767-0000.conf file to flash but the Orin NX fails to boot
Enter to continue boot.
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
L4TLauncher: Unable to process extlinux config: Not Found
L4TLauncher: Attempting Kernel Boot
��I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
��[ 0.627598] tegra_dc_assign_hw_data: no matching compatible node
[ 0.633613] tegradccommon module_init failed
[ 0.637881] tegradc module_init failed
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 6.007880] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 6.018619] CPU: 2 PID: 1 Comm: chroot Not tainted 5.10.120-tegra #1
[ 6.027700] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 202210.3-8444db34-dirty 03/18/2024
[ 6.040269] Call trace:
[ 6.042788] dump_backtrace+0x0/0x1d0
[ 6.046543] show_stack+0x30/0x40
[ 6.049949] dump_stack+0xd8/0x138
[ 6.053436] panic+0x17c/0x384
[ 6.056568] do_exit+0xaa8/0xab0
[ 6.059886] do_group_exit+0x4c/0xb0
[ 6.063561] __arm64_sys_exit_group+0x28/0x30
[ 6.068037] el0_svc_common.constprop.0+0x80/0x1d0
[ 6.072958] do_el0_svc+0x38/0xb0
[ 6.076354] el0_svc+0x1c/0x30
[ 6.079487] el0_sync_handler+0xa8/0xb0
[ 6.083424] el0_sync+0x16c/0x180
[ 6.086834] SMP: stopping secondary CPUs
[ 6.091065] Kernel Offset: 0x4584a5c00000 from 0xffff800010000000
[ 6.097313] PHYS_OFFSET: 0xfffff65e80000000
[ 6.101598] CPU features: 0x08040006,4a80aa38
[ 6.106075] Memory Limit: none
[ 6.109208] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
