I want to run SSD-Mobilenetv2 on AGX Xavier for 50 cctv live camera streams each running at a minimum 15fps. Is it possible?
Looking at the mlperf 0.5 multistream results, it states that the AGX Xavier can run 102 streams.
https://blogs.nvidia.com/blog/2019/11/06/ai-inference-mlperf-benchmarks/ .
Running source source30_1080p_dec_infer-resnet_tiled_display_int8.txt, I was able to get only 30 sources. Increasing the number of sources beyond 30 results in decrease in fps.
kayccc
December 8, 2019, 11:19pm
2
Hi sivaishere96,
I will suggest to use DeepStream SDK, please refer to https://developer.nvidia.com/deepstream-sdk
As i have mentioned above, I am using the source30_1080p_dec_infer-resnet_tiled_display_int8.txt config file which is a part of deepstream. I am facing this problem while using deepstream. Without deepstream I am getting much worse results.
DaneLLL
December 10, 2019, 1:49am
4
You may try in running Xavier in max performance. Please refer to
https://devtalk.nvidia.com/default/topic/1049168/
source30_1080p_dec_infer-resnet_tiled_display_int8.txt is what we have verified. Your usecase is more aggressive. Please give it a try.
I am running the device in maximum performance mode.
In the mlperf results, it stated that the age Xavier can process almost 2500 images in offline mode and 102 batches in multi-stream mode for ssd mobilenet v2. Shouldn’t the multi stream results mean that the Xavier can process 102 streams running ssd mobilenet v2 at 20 FPS.
Hence I thought running 40 streams shouldn’t be an issue.
DaneLLL
December 10, 2019, 6:45am
6
By default source30_1080p_dec_infer-resnet_tiled_display_int8.txt runs ResNet. Do you also hit performance bottleneck in running ResNet? Would like to know if it is specific to mobilenetv2.
Yes. The issue was with both Resnet and mobilenetv2.
DaneLLL
December 11, 2019, 2:47am
8
Please share your config file for reference. You may put it in
or zip and attach it/
Also please run tegrastats to check if GPU runs at max clocks and reaches 100% loading.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2FAppendixTegraStats.html%23
source30_1080p_dec_infer-resnet_tiled_display_int8.txt is the config file that we have used. Everything is the same except that the number of sources have been changed to 50.
Will update you with the log in a while as I am travelling right now.
Hi DaneLLL,
I have an update. I am trying to run only 30 sources. However the performace does not seem to be consistent. During one run all the sources seem to run at 30 fps without any problem.
god@jetson-xavier:~/deepstream_sdk_v4.0.1_jetson$ deepstream-app -c samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
** WARN: <create_pipeline:930>: Num of Tiles less than number of sources, readjusting to 6 rows, 6 columns
0:00:00.568724475 10867 0x3e122000 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:49.209637762 10867 0x3e122000 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/god/deepstream_sdk_v4.0.1_jetson/samples/models/Primary_Detector/resnet18_detector.etlt_b30_int8.engine
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg) FPS 23 (Avg) FPS 24 (Avg) FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg) FPS 30 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
**PERF: 29.99 (29.99) 30.02 (30.02) 30.41 (30.41) 29.53 (29.53) 28.65 (28.65) 29.79 (29.79) 29.94 (29.94) 28.67 (28.67) 29.15 (29.15) 28.18 (28.18) 29.79 (29.79) 30.72 (30.72) 29.94 (29.94) 30.41 (30.41) 28.18 (28.18) 30.18 (30.18) 29.97 (29.97) 30.48 (30.48) 29.76 (29.76) 30.22 (30.22) 29.38 (29.38) 29.39 (29.39) 30.17 (30.17) 30.72 (30.72) 29.46 (29.46) 29.48 (29.48) 30.48 (30.48) 30.13 (30.13) 30.18 (30.18) 28.91 (28.91) 29.32 (29.32)
**PERF: 29.60 (29.78) 29.80 (29.90) 29.40 (29.87) 29.40 (29.46) 29.60 (29.15) 29.00 (29.36) 27.62 (28.68) 28.80 (28.74) 29.00 (29.07) 27.22 (27.65) 29.20 (29.47) 29.59 (30.11) 28.40 (29.10) 29.60 (29.97) 28.40 (28.30) 29.60 (29.87) 28.98 (29.43) 29.80 (30.11) 29.40 (29.57) 30.00 (30.10) 29.20 (29.28) 28.38 (28.84) 29.18 (29.63) 29.21 (29.90) 29.01 (29.22) 28.60 (29.00) 29.60 (30.01) 28.81 (29.41) 28.20 (29.11) 27.37 (28.08) 29.20 (29.26)
**PERF: 28.60 (29.37) 28.59 (29.44) 29.80 (29.84) 30.20 (29.72) 28.60 (28.96) 29.20 (29.30) 27.80 (28.37) 29.00 (28.83) 28.80 (28.97) 28.60 (27.99) 28.20 (29.02) 29.60 (29.93) 28.81 (29.00) 29.00 (29.63) 28.21 (28.27) 28.60 (29.43) 28.40 (29.07) 29.00 (29.72) 29.60 (29.58) 29.20 (29.79) 28.81 (29.11) 28.21 (28.62) 30.01 (29.76) 29.40 (29.73) 28.60 (29.00) 30.00 (29.35) 30.20 (30.07) 29.79 (29.55) 29.79 (29.35) 29.00 (28.40) 28.59 (29.03)
**PERF: 30.41 (29.64) 28.81 (29.28) 29.61 (29.78) 29.61 (29.69) 29.40 (29.07) 27.41 (28.81) 28.79 (28.48) 26.98 (28.35) 30.01 (29.24) 27.61 (27.89) 30.01 (29.28) 29.61 (29.85) 29.41 (29.11) 27.81 (29.16) 29.60 (28.61) 27.41 (28.90) 29.60 (29.21) 27.41 (29.12) 29.41 (29.53) 30.01 (29.84) 30.40 (29.45) 29.81 (28.93) 29.20 (29.61) 28.01 (29.28) 26.21 (28.28) 30.41 (29.62) 30.00 (30.05) 29.01 (29.41) 26.43 (28.59) 29.81 (28.77) 28.42 (28.87)
**PERF: 28.59 (29.42) 29.99 (29.43) 28.78 (29.58) 28.99 (29.55) 29.60 (29.18) 28.99 (28.85) 28.80 (28.55) 28.01 (28.28) 29.39 (29.27) 28.59 (28.03) 29.39 (29.30) 29.19 (29.71) 28.39 (28.96) 28.99 (29.13) 28.60 (28.61) 28.79 (28.88) 29.20 (29.21) 29.39 (29.18) 29.99 (29.63) 29.59 (29.79) 30.20 (29.60) 29.17 (28.98) 28.79 (29.44) 28.79 (29.18) 29.19 (28.46) 29.39 (29.58) 29.20 (29.88) 28.59 (29.24) 28.19 (28.51) 28.59 (28.74) 28.19 (28.73)
^C** ERROR: <_intr_handler:140>: User Interrupted..
Quitting
App run successful
However in an another run the fps displayed is 0.
0:00:00.578794163 11299 0x12116000 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:49.228657332 11299 0x12116000 INFO nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /home/god/deepstream_sdk_v4.0.1_jetson/samples/models/Primary_Detector/resnet18_detector.etlt_b30_int8.engine
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: 37.06 (37.06) 1.59 (1.59) 27.37 (27.37) 0.00 (0.00) 28.08 (28.08) 0.00 (0.00) 31.07 (31.07) 32.61 (32.61) 9.23 (9.23) 31.30 (31.30) 2.98 (2.98) 11.44 (11.44) 36.40 (36.40) 0.00 (0.00) 3.11 (3.11) 7.94 (7.94) 0.00 (0.00) 6.82 (6.82) 32.06 (32.06) 0.00 (0.00) 35.22 (35.22) 3.97 (3.97) 0.00 (0.00) 44.73 (44.73) 35.84 (35.84) 44.72 (44.72) 29.00 (29.00) 29.78 (29.78) 31.20 (31.20) 11.77 (11.77) 1048576.00 (1048576.00)
**PERF: 0.00 (37.06) 0.00 (1.59) 0.00 (27.37) 0.00 (0.00) 0.00 (28.08) 0.00 (0.00) 2.13 (18.44) 0.00 (32.61) 0.00 (9.23) 0.00 (31.30) 0.00 (2.98) 0.00 (11.44) 0.61 (24.18) 0.00 (0.00) 0.00 (3.11) 0.00 (7.94) 0.00 (0.00) 0.00 (6.82) 0.00 (32.06) 0.00 (0.00) 0.00 (35.22) 0.00 (3.97) 0.00 (0.00) 0.00 (44.73) 0.00 (35.84) 0.00 (44.72) 0.00 (29.00) 2.74 (17.96) 2.74 (18.75) 0.00 (11.77) 0.00 (1048576.00)
Quitting
App run successful
And this seems to happen randomly for different runs. There is no pattern.I am monitoring the temperatures and the utilization; they seem to be fine and within limits. I even tried running the code for 4 hours straight and it ran without any problems with all the sources running at a stable 30 fps.
FYI: I have set the interval parameter to be 2 here in the experiments.
And the performace is starking to me because it is claimed by nvidia that the AGX Xavier can process around 2500 images/sec for ssd-mobilenetv2 and it is not even remotely close to the number I am getting here. Although I am running detectnetv2-Resnet-10 I should expect atleast half the number of images/sec.
DaneLLL
December 24, 2019, 4:48am
11
