Installed Zoom 5.14.x from here. Using nVidia Linux software v530.41.03
Having laptop with dual GPU - Intel HD Graphics 530 and NVIDIA GM107GLM [Quadro M2000M] with xorg-server 21.1.8-1
Error message, while trying to start Zoom:
Client: Breakpad is using Single Client Mode! client fd = -1
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Linux Client Version is 5.14.2 (2046)
QSG_RENDER_LOOP is
XDG_CURRENT_DESKTOP = KDE; GDMSESSION = ; XDG_SESSION_TYPE = x11
Graphics Card Info:: 00:02.0 VGA compatible controller: Intel Corporation HD Graphics 530 (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation GM107GLM [Quadro M2000M] (rev a2)
Zoom package arch is 64bit, runing OS arch is x86_64, snap package 0
AppIconMgr::systemDesktopName log Desktop Name: plasma
zoom was exited due to a handled signal: 11
ZoomLauncher exit.
Counterpart issue and my post in Zoom forum.
GPUs:
inxi -xxxzG
Graphics:
Device-1: Intel HD Graphics 530 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107GLM [Quadro M2000M] vendor: Lenovo driver: nvidia
v: 530.41.03 arch: Maxwell pcie: speed: 8 GT/s lanes: 16 ports: active: none
empty: DP-3,DP-4,DP-5 bus-ID: 01:00.0 chip-ID: 10de:13b0 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04f2:b52c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 mapped: eDP-1-1 model: Sharp 0x143b res: 1920x1080
dpi: 141 size: 346x194mm (13.62x7.64") diag: 397mm (15.6") modes: 3840x2160
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: Quadro M2000M/PCIe/SSE2
direct-render: Yes
Another, desktop PC has following GPU:
inxi -xxxzG
Graphics:
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-9
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1912
class-ID: 0300
Display: x11 server: X.org v: 1.21.1.8 compositor: kwin_x11 driver: X: loaded: intel dri: i965
gpu: i915 tty: 157x26
Monitor-1: HDMI-A-1 model: HP E232 serial: <filter> res: 1920x1080 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (23") modes: max: 1920x1080 min: 640x480
… and on that desktop PC I added SUID to chrome-sandbox - then I could start Zoom.
Quick workaround on the dual GPU laptop was to use flatpak (older) version of zoom until nVidia software with Zoom works again.
