Hello, I have updated the linux system to 24.04, update the NVIDIA-SMI 560.35.03, Driver Version: 560.35.03, CUDA Version: 12.6. However, when I run the dump or other code that use multiple gpu, it will occur errors “Unable to determine the device handle for GPU0000:17:00.0: Unknown Error”. When I type nvidia-smi, this error will occur. At this time, only 3 gpu can be detected, gpu 0 is not in the bus. Thing is that, after reboot, 4 gpu occur again. The error log is after I rebooting. Thanks
nvidia-bug-report.log.gz (2.0 MB)
What would this even accompolish? This wouldn’t fix multi monitor VRR right? I think we are stuck waiting for 570 beta.
I just replicated my results on latest git HEAD swaywm/wlroots. The performance issue is exactly the same. I’m currently still on 560.35.03.
I took a perf profile, and here is what i’m getting:
CPU goes 100% active on htop, and GPU is chilling.
Suspend / Resume fails with multiple monitors connected with the 560-35-03 drivers installed. This has been verified on two different systems, both System76 machines running PopOS 24 (still in development). Disconnecting additional monitors before booting avoids the issue.
I originally posted about it on Reddit (r/PopOS) this morning:
https://www.reddit.com/r/pop_os/comments/1gmkt0c/2404_system76_thelio_mira_nv_rtx_4090_fails_to
The dmesg output on failures looks the same on both systems:
Everything else has been working fine for me so far that I’ve seen.
I managed to fix the problem, but I tried many things at once, so I can’t tell which one fixed it. I did:
- install egl-x11
- install egl-gbm
- compile and install GitHub - NVIDIA/egl-wayland: The EGLStream-based Wayland external platform
Finally, after doing this, it still didn’t work, but after restarting Sway, it got fixed! Can someone without problems check whether they have egl-x11 and/or egl-gbm installed?
I installed 560 last week and have ran into nothing but issues since. The main issue which may be solveable, since I have some terminal output for it, has to do with video playback. Previously I could open multiple instances of MPV to view projects I’m working on, but now I’m getting a “OpenGL error OUT_OF_MEMORY.” error if more than 2-3 are opened, dependent upon resolution apparently. If I check nvidia-smi though, there’s well over 6.5 GB of vram available, and my system has 128, so that isn’t the issue. Here’s the terminal output itself in case anyone has some ideas on what to try.
(+) Video --vid=1 (*) (h264 1920x1080 29.970fps)
(+) Audio --aid=1 (*) (aac 2ch 44100Hz)
[vo/gpu/opengl] Error: framebuffer completeness check failed (error=36061).
[vo/gpu] Error: texture could not be created.
[vo/gpu] Force-disabling compute shaders as an FBO format was not available! See your FBO format configuration!
[vaapi] libva: vaGetDriverNames() failed with unknown libva error
[vo/gpu/opengl] mapping buffer: OpenGL error OUT_OF_MEMORY.
AO: [pulse] 44100Hz stereo 2ch float
VO: [gpu] 1920x1080 yuv420p
The other main issue I’m having which I don’t have any real clues at a cause for has to do with Steam and Lutris. The two refuse to be open at the same time on 560, and Lutris is frequently fully locking my system now (hence the lack of terminal output). I’ll probably just roll back to the last stable driver for 22.04 in a few days, but Dragon Age’s complaint about driver version when launching started me down this rabbit hole, so it would be nicer to find what is causing the issues instead.
Hello, I can’t install the proprietary drivers on my Solus Budgie system. Installing the 560 drivers and rebooting the system prevents me from booting, with these errors before the grub.
Error preparing initrd : Device Error
star_image() returned Device Error
StartImage failed : Device Error
The computer shuts down and restarts with this error in a loop.
My system is unusable…
graphics card: 1050ti mobile
laptop model: Asus FX553VE
At least for me, the driver version 535 was the last release where S3 sleep worked correctly. Every release after that has had at minimum the failure to restore the system into state where my X11 compositor (picom) would continue working correctly if multiple seats have been logged in.
And yes, I do have the kernel flag nvidia.NVreg_PreserveVideoMemoryAllocations=1
and the related service running. This has been enough to make version 550 somewhat usable.
Version 560 didn’t work even with all the allocations preserved.
Why not downgrade to version 550 and keep using the Wayland instead? Is there any reason to prefer version 560+ if those are too buggy?
Its the same for me. I’m on the 535 drivers because any newer drivers suspend doesn’t work. Or suspend works but resume doesn’t. Locks up on resume and have to reboot.
try suspend on latest nvidia 565 with kernel 6.12. seems to have resolved all of the suspend issues for me, my wallpaper daemon, discord client, etc all stay open every time and I can successfully wake every time.
Thanks for your reply/suggestion! I did try the latest kernel 6.12 / nvidia drivers 565 on arch. It did seem to help suspend (the few times I tried it). However, with these new drivers I’m also getting frequent random reboots. So it’s back to the 535 drivers for me…again. Thanks anyway, i appreciate your help. In the event that its the kernel update and not the latest nvidia drivers, i’ll update. But i’m pretty sure it’s going to be nvidia drivers causing instability, as has been the case for many months now.
Fallout 76 is unplayable with NVIDIA 560.35 on Fedora 40 KDE running Wayland. With the 555 drivers, I was getting between 45-55 fps at medium-high settings at native resolution. With 560, I get 2-6 fps, at the lowest settings, non-native resolution. There is also occasional smearing and artifacts during gameplay. It even stutters horribly at the menu.
Hi, what are steps to fix this?
fedora 40 kernel 6.12.5 dkms build fails:
similar issue for 560.35.05 and kernel 6.12.5 (reproduce also with fedora 41 kernel 6.12.5/4.12.4 and 560.35.05)
CC [M] /var/lib/dkms/nvidia/560.35.03/build/nvidia-modeset/nv-kthread-q.o
/var/lib/dkms/nvidia/560.35.03/build/nvidia-modeset/nvidia-modeset-linux.c:1087:24: warning: no previous prototype for ‘nvkms_open_common’ [-Wmissing-prototypes]
1087 | struct nvkms_per_open *nvkms_open_common(enum NvKmsClientType type,
/var/lib/dkms/nvidia/560.35.03/build/nvidia-modeset/nvidia-modeset-linux.c:1139:6: warning: no previous prototype for ‘nvkms_close_pm_locked’ [-Wmissing-prototypes]
1139 | void nvkms_close_pm_locked(struct nvkms_per_open popen)
/var/lib/dkms/nvidia/560.35.03/build/nvidia-modeset/nvidia-modeset-linux.c:1202:5: warning: no previous prototype for ‘nvkms_ioctl_common’ [-Wmissing-prototypes]
1202 | int nvkms_ioctl_common
CC [M] /var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm.o
CC [M] /var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-drv.o
CC [M] /var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-utils.o
/var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-drv.c:207:6: error: ‘const struct drm_mode_config_funcs’ has no member named ‘output_poll_changed’
207 | .output_poll_changed = nv_drm_output_poll_changed,
/var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-drv.c:207:28: error: initialization of ‘struct drm_atomic_state * ()(struct drm_device )’ from incompatible pointer type ‘void ()(struct drm_device *)’ [-Wincompatible-pointer-types]
/var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-drv.c:207:28: note: (near initialization for ‘nv_mode_config_funcs.atomic_state_alloc’)
make[3]: *** [scripts/Makefile.build:229: /var/lib/dkms/nvidia/560.35.03/build/nvidia-drm/nvidia-drm-drv.o] Error 1
make[3]: *** Waiting for unfinished jobs…
make[2]: *** [/usr/src/kernels/6.12.5-100.fc40.x86_64/Makefile:1977: /var/lib/dkms/nvidia/560.35.03/build] Error 2
make[1]: *** [Makefile:236: __sub-make] Error 2
make[1]: Leaving directory ‘/usr/src/kernels/6.12.5-100.fc40.x86_64’
make: *** [Makefile:89: modules] Error 2
You should use 565.77. There are some unofficial patches for 560 that works too, for most people.
Looks like this old bug has come to haunt us still. It was not fully fixed. Hyprland recently implemented fading of these CTMs (including the night light filter from hyprsunset) and the issue is back. On my multi monitor setup (not a PRIME setup) toggling the night light causes one of my monitors to freeze literally EVERY time. Can bring my stuff back by going to tty2 and back to tty1.
here is the bug from the repro state, and running on nvidia open kernel modules version 565.77: nvidia-bug-report.log.gz (535.1 KB)
Repro steps:
launch hyprland on latest master and ensure you have hyprsunset latest master also installed / executable. Ensure you’re using a multi monitor setup. Simply run hyprsunset with the simple command hyprsunset -t 2000
you will notice at least one of the screens freeze, maybe both.
Hopefully this issue is observable on your end.
I want to use TuxedoOS4 but every offloaded application starts to crash after a while.
I can start an application just fine but then it will crash like this
[ 486.920950] NVRM: GPU at PCI:0000:01:00: GPU-f6cd1b06-0e50-622e-08d9-5b44281bcb65
[ 486.920954] NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 2028bf5e 2028b2a4 2028ee22 202a6438 202a5aba 202a63c4 00000000 00000000
[ 540.130493] QSGRenderThread[29525]: segfault at 927d ip 00007d9838aabf35 sp 00007d981cfff020 error 4 in libnvidia-glcore.so.560.35.03[6abf35,7d9838400000+1eab000] likely on CPU 5 (core 20, socket 0)
[ 540.130500] Code: 5d e9 0f 9f 18 00 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 48 8b 05 c9 40 96 01 55 64 48 8b 28 83 ff 0f 0f 87 52 8b bb ff <0f> b6 46 01 48 8d 15 c0 1f 9d 01 44 8b 4c 82 34 0f b6 46 02 44 8b
OS is TuxedoOS which is based on ubuntu 24.04 and runs kernel 6.11,
CPU: Intel i9-13900HX
GPU: GeForce RTX 4080 Max-Q / Mobile
nvidia-bug-report.log.gz (2.2 MB)
Issue still persists on 570.86.10 in Cachyos.
Can you tell me if at least someone is looking into it ?
I am facing this issue for 5 months now.
Maybe I posted it in the wrong thread before:
Random system freezes on Ubuntu 24 LTS
Distro: TUXEDO OS 4 24.04.1 LTS noble
OS Version: Linux 6.11.0-108013-tuxedo #14tuxnoble1 SMP PREEMPT_DYNAMIC Mon Dec 16 18:07:37 UTC 2024 x86_64
CPU: AMD Ryzen 7 7800X3D 8-Core Processor
Memory: 63932 MB
Graphics:
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ASUSTeK driver: nvidia
v: 560.35.03 arch: Lovelace bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 24.1.2 driver: X:
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: nvidia,nvidia-nvswitch resolution: 2560x1440
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 560.35.03
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib devices: 2
I had another screen freeze.
In the background I had just started journalctl -f
in a terminal and when this familiar screen flicker happened I switched to the terminal window with journalctl and not long the screen was already frozen.
After restarting, I queried journalctl as follows:
journalctl --since “2025-01-30 13:40:00” --until “2025-01-30 14:10:00” > log_2025-01-30.txt
The screen freeze was around 13:57:00.
Before the screen freeze, of which I had taken a photo and subsequently marked the area in the journal extract below, there were no nvidia-related error messages.
Some journal entries (around 17 minutes before the screen freeze) that show errors or similar are as follows:
Jan 30 13:41:19 ANDROMEDA kernel: audit: type=1400 audit(1738240879.142:293): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Jan 30 13:42:48 ANDROMEDA kwin_x11[3174]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
Jan 30 13:42:49 ANDROMEDA kwin_x11[3174]: <Unknown File>:97: TypeError: Cannot read property 'translucencyWindowTypeAnimation' of undefined
Jan 30 13:54:58 ANDROMEDA kernel: audit: type=1400 audit(1738241698.476:295): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
After the screen freeze before I switched off the pc via power switch I found the following in the journal:
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (3 suppressed)
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79138994031445 a:79138994139786 f:79138994147416 waiting:108341 process:7630 status:triggered
Jan 30 13:56:55 ANDROMEDA pipewire[2859]: pw.node: (Strawberry-190) xrun state:0x7282e1e02008 pending:0/1 s:79139036679335 a:79138994037885 f:79138994059615 waiting:18446744073666910166 process:21730 status:triggered
>>> photo screen freeze
Jan 30 13:56:59 ANDROMEDA kernel: audit: type=1400 audit(1738241819.049:296): apparmor="DENIED" operation="open" class="file" info="Failed name lookup - disconnected path" error=-13 profile="plasmashell" name=".flatpak-info" pid=195163 comm="plasmashell" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.073 ERROR LyricFindLyricsProvider:204 LyricFind: "Empty reply received from server."
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.292 ERROR OVHLyricsProvider:114 OVHLyrics: "Error transferring https://api.lyrics.ovh/v1/Heilung/Othan LIVE - server replied: Not Found (203)"
Jan 30 13:56:59 ANDROMEDA flatpak[198739]: 13:56:59.292 ERROR OVHLyricsProvider:114 OVHLyrics: "No lyrics found"
Jan 30 13:56:59 ANDROMEDA kdeconnectd[3404]: 2025-01-30T13:56:59 kdeconnect.core: CompositeUploadJob::startListening() - Error opening a port in range 1739 - 1764
Jan 30 13:57:18 ANDROMEDA plasmashell[195163]: qt.qml.context: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/FullRepresentation.qml:99:25 Parameter "model" is not declared. Injection of parameters into signal handlers is deprecated. Use JavaScript functions with formal parameters instead.
Jan 30 13:57:26 ANDROMEDA plasmashell[195163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:284:9: QML Image: Cannot open: file:///tmp/strawberry-cover-ktx8rz.jpg
Jan 30 13:57:28 ANDROMEDA systemd[2847]: Started app-org.kde.konsole@4512deef22994f2aa6c251c934dacab7.service - Konsole - Terminal.
Jan 30 13:57:28 ANDROMEDA systemd[2847]: Started app-org.kde.konsole-221879.scope.
Jan 30 13:57:29 ANDROMEDA plasmashell[195163]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/FullRepresentation.qml:53:13: QML PlasmoidHeading: Binding loop detected for property "leftInset":
qrc:/qt/qml/org/kde/plasma/extras/PlasmoidHeading.qml:33:5
Jan 30 13:57:55 ANDROMEDA rtkit-daemon[2251]: Supervising 8 threads of 5 processes of 1 users.
<<< photo screen freeze
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU at PCI:0000:01:00: GPU-607aa084-1cf9-f43c-65b1-4be9d9db92f3
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=3342, name=nvidia-smi, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 76 (GSP_RM_CONTROL) (0x20808513 0x598).
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 GSP RPC buffer contains function 4128 (GSP_POST_NOCAT_RECORD) and data 0x0000000000000005 0x000000c70170b43e.
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 RPC history (CPU -> GSP):
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: entry function data0 data1 ts_start ts_end duration actively_polling
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: 0 76 GSP_RM_CONTROL 0x0000000020808513 0x0000000000000598 0x00062cebfb2aed29 0x0000000000000000 y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -1 76 GSP_RM_CONTROL 0x0000000020800a4c 0x0000000000000004 0x00062cebfb0c59c9 0x00062cebfb0c5af2 297us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -2 76 GSP_RM_CONTROL 0x0000000020808513 0x0000000000000598 0x00062cebfb0c541a 0x00062cebfb0c599f 1413us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -3 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0ae2c1 0x00062cebfb0ae5a7 742us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -4 76 GSP_RM_CONTROL 0x0000000020808530 0x0000000000000390 0x00062cebfb0ae1cb 0x00062cebfb0ae2b7 236us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -5 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0adefa 0x00062cebfb0ae177 637us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -6 76 GSP_RM_CONTROL 0x0000000020808530 0x0000000000000390 0x00062cebfb0add2f 0x00062cebfb0adef4 453us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -7 76 GSP_RM_CONTROL 0x000000002080852f 0x0000000000000308 0x00062cebfb0ad89c 0x00062cebfb0adcb7 1051us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: GPU0 RPC event history (CPU <- GSP):
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: entry function data0 data1 ts_start ts_end duration during_incomplete_rpc
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: 0 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x000000c70170b43e 0x00062cebfb52444d 0x00062cebfb52444e 1us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -1 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x00000000016f9800 0x00062cebfb5242c7 0x00062cebfb5242c8 1us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -2 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x000002ab0109691a 0x00062cebfb5242a2 0x00062cebfb5242a5 3us y
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -3 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf75d71d2 0x00062cebf75d71d4 2us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -4 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001277c78 0x00062cebf3b97bbb 0x00062cebf3b97bbc 1us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -5 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf3b962f9 0x00062cebf3b962fb 2us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -6 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001277c78 0x00062cebf2a90c83 0x00062cebf2a90c84 1us
Jan 30 13:58:29 ANDROMEDA kernel: NVRM: -7 4128 GSP_POST_NOCAT_RECORD 0x0000000000000005 0x0000000001257b84 0x00062cebf2a8d844 0x00062cebf2a8d846 2us
Jan 30 13:58:29 ANDROMEDA kernel: CPU: 1 UID: 1000 PID: 3355 Comm: nvidia-smi Tainted: P OE 6.11.0-108013-tuxedo #14tuxnoble1
Jan 30 13:58:29 ANDROMEDA kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jan 30 13:58:29 ANDROMEDA kernel: Hardware name: ASUS System Product Name/ROG STRIX X670E-A GAMING WIFI, BIOS 2704 01/17/2025
Jan 30 13:58:29 ANDROMEDA kernel: Call Trace:
Jan 30 13:58:29 ANDROMEDA kernel: <TASK>
Jan 30 13:58:29 ANDROMEDA kernel: dump_stack_lvl+0x76/0xa0
Jan 30 13:58:29 ANDROMEDA kernel: dump_stack+0x10/0x20
Jan 30 13:58:29 ANDROMEDA kernel: os_dump_stack+0xe/0x20 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: _nv012948rm+0x4ee/0x590 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: WARNING: kernel stack frame pointer at 00000000b90e9197 in nvidia-smi:3355 has bad value 00000000988c5c06
Jan 30 13:58:29 ANDROMEDA kernel: unwind stack type:0 next_sp:0000000000000000 mask:0x2 graph_idx:0
Jan 30 13:58:29 ANDROMEDA kernel: 000000006620c9da: ffffb1e3c5437a78 (0xffffb1e3c5437a78)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a4d89584: ffffffffb3861519 (show_trace_log_lvl+0x269/0x420)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000014e7343a: ffffffffb53a94f0 (kallsyms_seqs_of_names+0x98f80/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000082fd9e72: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000594352c8: ffffffffb53d42dc (kallsyms_seqs_of_names+0xc3d6c/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fbcfc342: ffffb1e3c5437ad0 (0xffffb1e3c5437ad0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002e341212: 00000000c54379b8 (0xc54379b8)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000ceb3b5b: 0000000000000002 (0x2)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005833386f: 0000000000000001 (0x1)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007a0e2404: ffffb1e3c5434000 (0xffffb1e3c5434000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b0d6595d: ffffb1e3c5438000 (0xffffb1e3c5438000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000749faff7: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000004fd1935f: ffffb1e3c5434000 (0xffffb1e3c5434000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009291302e: ffffb1e3c5438000 (0xffffb1e3c5438000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a4ca3f95: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a76570b: 0000000000000002 (0x2)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006c41e0c8: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ee333a65: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000026acba86: 0000000000000001 (0x1)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005ef62400: ffffb1e3c5437ac8 (0xffffb1e3c5437ac8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000018cab3b2: ffffb1e3c5437978 (0xffffb1e3c5437978)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000a25070b: ffffffffc1a60fee (_nv012948rm+0x4ee/0x590 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e58cbce5: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000005d440137: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b91d4ae0: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000aac8ffa5: ffffffffb53d42dc (kallsyms_seqs_of_names+0xc3d6c/0x20a960)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000474dfe61: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000583bf4f1: 000000000000004c (0x4c)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000070954ffc: 0000000000000006 (0x6)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008094bbc3: ffffb1e3c5437a88 (0xffffb1e3c5437a88)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c1c9bb8f: ffffffffb38617f0 (show_stack+0x20/0x70)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000014441908: ffffb1e3c5437aa8 (0xffffb1e3c5437aa8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d2ab1fd4: ffffffffb49c3cf6 (dump_stack_lvl+0x76/0xa0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a567510: ffff8cf362bc0008 (0xffff8cf362bc0008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b8564687: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000137edbf: ffffb1e3c5437ab8 (0xffffb1e3c5437ab8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000039f40aad: ffffffffb49c3d40 (dump_stack+0x10/0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007b79c529: ffffb1e3c5437ac8 (0xffffb1e3c5437ac8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ee50f20f: ffffffffc140eb2e (os_dump_stack+0xe/0x20 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b90e9197: ffff8cfec2c95d70 (0xffff8cfec2c95d70)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000072f56b76: ffffffffc1a60fee (_nv012948rm+0x4ee/0x590 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e0150637: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000089e6e5dd: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000009d95bfea: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000dd6fce84: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a535c429: 000000000000004c (0x4c)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000090b2d1ff: ffffffffc1d83787 (_nv012865rm+0x77/0x330 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 0000000018f8488d: ffff8cf362be1050 (0xffff8cf362be1050)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000525363f: ffff8cfec2c95df0 (0xffff8cfec2c95df0)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000033ef5441: ffff8cf362b40008 (0xffff8cf362b40008)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008537fc1b: 0000000020808513 (0x20808513)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003d7f47c8: ffff8cf362b78008 (0xffff8cf362b78008)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000aa417aa0: ffffffffc1d9f8ff (_nv048628rm+0x49f/0x7f0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000137cc031: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000e4bfe54: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000003a21e10c: ffffb1e3c5437bb8 (0xffffb1e3c5437bb8)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000057f3a58d: ffff8cf408104808 (0xffff8cf408104808)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000029ffca1d: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d9c7a916: ffffffffc14ff063 (_nv000720rm+0x173/0x320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000004f317ff0: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b253e6ee: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f5147316: ffffffffc14feef0 (_nv000691rm+0x1a0/0x1a0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e1ba0dda: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000075c5bfc1: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000cc43a289: ffffffffc14b1ddd (_nv013137rm+0x3d/0xa0 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000003ab25a4c: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000eff2b648: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001fed6283: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005a82fe68: ffffffffc1fc1382 (_nv000745rm+0x8d2/0xe00 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000005c695930: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000099d6719b: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003cfb4489: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d06f0402: ffff8cfec2c93000 (0xffff8cfec2c93000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002b5eb443: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006ec988e9: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c51bedaa: ffffb1e3c5437d60 (0xffffb1e3c5437d60)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fc342073: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ae49bc03: ffffffffc1fc7edf (rm_ioctl+0x7f/0x400 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000009520b887: ffffffffb4a7387e (syscall_exit_to_user_mode+0x4e/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005eebe536: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000000de3cc5d: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000824e2a14: 0000000000000027 (0x27)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000099dc24a3: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000267195d7: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d8759f42: 0000000000000d1b (0xd1b)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000448fefe6: 0000000109338d14 (0x109338d14)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000386805a0: 000f8a086dbaf400 (0xf8a086dbaf400)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e14b5c03: 000f8a095c261c00 (0xf8a095c261c00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000645e289b: 000f8a095c261c00 (0xf8a095c261c00)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000fad08db: 000f8a09d3a7fb40 (0xf8a09d3a7fb40)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004ffec656: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000008a57d5e0: 0000012000000002 (0x12000000002)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c2456ae2: 0000000000000d1b (0xd1b)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000031d3f076: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fca401db: fffffff000000000 (0xfffffff000000000)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000042e1e0cb: ffffffffc21f6490 (_nv046641rm+0x90/0xffffffffffeddc00 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 00000000063207a9: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000011fe7e0d: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000994596e3: ffff8cf426bc79c0 (0xffff8cf426bc79c0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c4595f53: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000004949c7db: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004009de7b: ffff8cf3478c9800 (0xffff8cf3478c9800)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ebdf1675: ffffffffc13febcb (nvidia_unlocked_ioctl+0x7db/0x920 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000007efaac90: ffffffffc21bdd20 (nv_kthread_q+0x40/0xfffffffffff16320 [nvidia])
Jan 30 13:58:29 ANDROMEDA kernel: 000000007bbe9f0c: ffff8cfec2c93000 (0xffff8cfec2c93000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002b10e2d2: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000026586442: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 000000008859ab1e: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000997e4b67: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009551b0a9: ffff8cf3d7683700 (0xffff8cf3d7683700)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000624beeb1: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000082f01e55: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c6e4c253: ffff8cf3d7683701 (0xffff8cf3d7683701)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000234bff0c: ffffb1e3c5437d98 (0xffffb1e3c5437d98)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c9a9044b: ffffffffb3d305c0 (__x64_sys_ioctl+0xa0/0xf0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005bd0254f: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d6e48ffa: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000638f4f3e: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000004bebd84: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 0000000002e3c922: ffffb1e3c5437da8 (0xffffb1e3c5437da8)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f08006ca: ffffffffb380adbd (x64_sys_call+0x11ad/0x25f0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ae828af2: ffffb1e3c5437f38 (0xffffb1e3c5437f38)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000bb9398e6: ffffffffb4a6b96e (do_syscall_64+0x7e/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001bfd42a2: ffffffffb3a157c6 (hrtimer_nanosleep+0xb6/0x1a0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000fd95bf37: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000b3cdf821: ffffffffb3bd7522 (rseq_get_rseq_cs+0x22/0x260)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000004f8038a: ffff8d027daa6118 (0xffff8d027daa6118)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000385b4e54: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f96c0726: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a62343b5: 00007a37df6ecadf (0x7a37df6ecadf)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000088d868c1: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006959dc50: ffffffffb3bd77ff (rseq_ip_fixup+0x8f/0x1f0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000390efaa0: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000c16169c8: ffffffffb4e2ad80 (clock_monotonic+0x80/0x80)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e35ce1df: 4888022691342e00 (0x4888022691342e00)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000961ee85d: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008ca26f37: ffffffffb38713ed (restore_fpregs_from_fpstate+0x3d/0xd0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000389e6f44: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d794c460: ffff8cf3e6a6a500 (0xffff8cf3e6a6a500)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000cc41573c: 0000000000000005 (0x5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d10c9a42: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d841e9be: ffffffffb38714e0 (switch_fpu_return+0x50/0xe0)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f2377d42: 0000000000004000 (0x4000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000174fb206: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000db945f5a: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007903c87e: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000036b947a4: ffffffffb4a739bd (syscall_exit_to_user_mode+0x18d/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000036e1c41c: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000017edc095: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000012e9eadb: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000daba9323: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d7a010f5: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000000c79197f: 0000000000004000 (0x4000)
Jan 30 13:58:29 ANDROMEDA kernel: 000000006f5266b5: ffff8cf3e6a68000 (0xffff8cf3e6a68000)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f410eb14: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000dedd8cfd: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000032e03216: ffffffffb4a739bd (syscall_exit_to_user_mode+0x18d/0x250)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007a106138: ffffb1e3c5437f48 (0xffffb1e3c5437f48)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000378e1504: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000299e1b76: 00000000000000e6 (0xe6)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d6eadf82: ffffffffb4d04110 (srso_alias_return_thunk+0x5/0xfbef5)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008c1f2aa6: ffffffffb4a6b97a (do_syscall_64+0x8a/0x170)
Jan 30 13:58:29 ANDROMEDA kernel: 000000005160b7e5: ffffffffb4a72ae7 (sysvec_apic_timer_interrupt+0x57/0xc0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000001272556d: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000614ab03a: ffffffffb4c0012b (entry_SYSCALL_64_after_hwframe+0x76/0x7e)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e4e646f5: 000000000000002a (0x2a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000004a638160: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000d64c34e2: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000033dc1997: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000056040a9e: 00007a37ddffeae0 (0x7a37ddffeae0)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008e262093: 0000000000000020 (0x20)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000015ee9c87: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 000000009dc1ec3b: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: 00000000a94842be: 00007a37ddffec4c (0x7a37ddffec4c)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000e73d1580: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000011b74d8b: ffffffffffffffda (0xffffffffffffffda)
Jan 30 13:58:29 ANDROMEDA kernel: 000000002bedb5b6: 00007a37df724ded (0x7a37df724ded)
Jan 30 13:58:29 ANDROMEDA kernel: 000000008e1718ad: 00007a37ddffec30 (0x7a37ddffec30)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000518d948f: 00000000c020462a (0xc020462a)
Jan 30 13:58:29 ANDROMEDA kernel: 000000003e7e75dc: 0000000000000003 (0x3)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000047e05805: 0000000000000010 (0x10)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007c0bc7eb: 00007a37df724ded (0x7a37df724ded)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000ca74d8cd: 0000000000000033 (0x33)
Jan 30 13:58:29 ANDROMEDA kernel: 000000007625735b: 0000000000000246 (0x246)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000063a57bc8: 00007a37ddffea90 (0x7a37ddffea90)
Jan 30 13:58:29 ANDROMEDA kernel: 0000000091898b98: 000000000000002b (0x2b)
Jan 30 13:58:29 ANDROMEDA kernel: 00000000f1b85bd3: 0000000000000000 ...
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv012865rm+0x77/0x330 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv048628rm+0x49f/0x7f0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000720rm+0x173/0x320 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000691rm+0x1a0/0x1a0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv013137rm+0x3d/0xa0 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? _nv000745rm+0x8d2/0xe00 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? rm_ioctl+0x7f/0x400 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x4e/0x250
Jan 30 13:58:29 ANDROMEDA kernel: ? srso_alias_return_thunk+0x5/0xfbef5
Jan 30 13:58:29 ANDROMEDA kernel: ? do_syscall_64+0x8a/0x170
Jan 30 13:58:29 ANDROMEDA kernel: ? nvidia_unlocked_ioctl+0x7db/0x920 [nvidia]
Jan 30 13:58:29 ANDROMEDA kernel: ? __x64_sys_ioctl+0xa0/0xf0
Jan 30 13:58:29 ANDROMEDA kernel: ? x64_sys_call+0x11ad/0x25f0
Jan 30 13:58:29 ANDROMEDA kernel: ? do_syscall_64+0x7e/0x170
Jan 30 13:58:29 ANDROMEDA kernel: ? hrtimer_nanosleep+0xb6/0x1a0
Jan 30 13:58:29 ANDROMEDA kernel: ? rseq_get_rseq_cs+0x22/0x260
Jan 30 13:58:29 ANDROMEDA kernel: ? rseq_ip_fixup+0x8f/0x1f0
Jan 30 13:58:29 ANDROMEDA kernel: ? restore_fpregs_from_fpstate+0x3d/0xd0
Jan 30 13:58:29 ANDROMEDA kernel: ? switch_fpu_return+0x50/0xe0
Jan 30 13:58:29 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x18d/0x250
Jan 30 13:58:29 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x57/0xc0
Jan 30 13:58:29 ANDROMEDA kernel: ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jan 30 13:58:29 ANDROMEDA kernel: </TASK>
Jan 30 13:58:35 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=3342, name=nvidia-smi, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 76 (GSP_RM_CONTROL) (0x20808513 0x598).
Jan 30 13:58:41 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 119, pid=195163, name=QSGRenderThread, Timeout after 6s of waiting for RPC response from GPU0 GSP! Expected function 10 (FREE) (0xbeee0403 0x0).
Jan 30 13:58:47 ANDROMEDA kernel: NVRM: Rate limiting GSP RPC error prints for GPU at PCI:0000:01:00 (printing 1 of every 30). The GPU likely needs to be reset.
Jan 30 13:58:58 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 13:58:58 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79260909014530 a:79260909194850 f:79260909203880 waiting:180320 process:9030 status:triggered
Jan 30 13:59:28 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 13:59:28 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79290946014043 a:79290946047783 f:79290946055633 waiting:33740 process:7850 status:triggered
Jan 30 13:59:49 ANDROMEDA wpa_supplicant[1401]: wlp9s0: WPA: Group rekeying completed with 38:10:d5:69:87:df [GTK=CCMP]
Jan 30 13:59:57 ANDROMEDA kernel: watchdog: BUG: soft lockup - CPU#4 stuck for 22s! [QSGRenderThread:195198]
Jan 30 13:59:57 ANDROMEDA kernel: Modules linked in: ntfs3 udp_diag tcp_diag inet_diag rfcomm cmac algif_hash algif_skcipher af_alg snd_seq_dummy snd_hrtimer ccm dummy ib_core vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) qrtr bnep nvidia_uvm(POE) sunrpc binfmt_misc input_leds nvidia_drm(POE) nvidia_modeset(POE) amd_atl intel_rapl_msr intel_rapl_common nvidia(POE) snd_hda_codec_hdmi edac_mce_amd mt7921e btusb mt7921_common snd_hda_intel btrtl mt792x_lib kvm_amd btintel snd_intel_dspcfg mt76_connac_lib snd_intel_sdw_acpi btbcm btmtk tuxedo_compatibility_check(OE) spd5118 snd_hda_codec mt76 led_class_multicolor snd_usb_audio bluetooth kvm snd_hda_core snd_usbmidi_lib snd_hwdep snd_ump mac80211 snd_seq_midi snd_seq_midi_event snd_rawmidi nls_iso8859_1 rapl eeepc_wmi mfd_aaeon asus_nb_wmi mc snd_seq asus_wmi i2c_piix4 sparse_keymap snd_pcm platform_profile wmi_bmof snd_seq_device k10temp ccp i2c_smbus cfg80211 snd_timer snd drm_ttm_helper libarc4 ttm soundcore joydev razerkbd(OE) gpio_amdpt mac_hid sch_fq_codel msr parport_pc ppdev lp parport
Jan 30 13:59:57 ANDROMEDA kernel: dm_crypt nvme_fabrics efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 btrfs blake2b_generic raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c raid1 raid0 hid_generic usbhid uas hid usb_storage crct10dif_pclmul crc32_pclmul polyval_clmulni polyval_generic ghash_clmulni_intel sha256_ssse3 sha1_ssse3 nvme ahci libahci igc xhci_pci nvme_core xhci_pci_renesas nvme_auth video wmi aesni_intel crypto_simd cryptd
Jan 30 13:59:57 ANDROMEDA kernel: CPU: 4 UID: 1000 PID: 195198 Comm: QSGRenderThread Tainted: P OE 6.11.0-108013-tuxedo #14tuxnoble1
Jan 30 13:59:57 ANDROMEDA kernel: Tainted: [P]=PROPRIETARY_MODULE, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jan 30 13:59:57 ANDROMEDA kernel: Hardware name: ASUS System Product Name/ROG STRIX X670E-A GAMING WIFI, BIOS 2704 01/17/2025
Jan 30 13:59:57 ANDROMEDA kernel: RIP: 0010:_nv043727rm+0x3b/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: Code: d3 89 de 48 8d 55 0f c6 45 0f 00 e8 3f 6d 4c ff 80 7d 0f 00 41 89 c4 75 11 41 39 5d 10 76 20 49 8b 45 00 c1 eb 02 44 8b 24 98 <5b> 44 89 e0 41 5c 41 5d 48 83 c5 10 c3 0f 1f 84 00 00 00 00 00 be
Jan 30 13:59:57 ANDROMEDA kernel: RSP: 0018:ffffb1e3c51e37e8 EFLAGS: 00000212
Jan 30 13:59:57 ANDROMEDA kernel: RAX: ffffb1e3c3000000 RBX: 00000000002e0c2c RCX: 0000000000b830b0
Jan 30 13:59:57 ANDROMEDA kernel: RDX: ffff8cf3e500295f RSI: 0000000000b830b0 RDI: ffff8cf362b40008
Jan 30 13:59:57 ANDROMEDA kernel: RBP: ffff8cf3e5002950 R08: 0000000000000020 R09: 0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: R10: 0000000000b830b0 R11: 0000000000000000 R12: 0000000080010005
Jan 30 13:59:57 ANDROMEDA kernel: R13: ffff8cf362b40ca0 R14: 0000000000000000 R15: 0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: FS: 00007999b4c006c0(0000) GS:ffff8d027da00000(0000) knlGS:0000000000000000
Jan 30 13:59:57 ANDROMEDA kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jan 30 13:59:57 ANDROMEDA kernel: CR2: 00000184a2120000 CR3: 00000001266a0000 CR4: 0000000000f50ef0
Jan 30 13:59:57 ANDROMEDA kernel: PKRU: 55555554
Jan 30 13:59:57 ANDROMEDA kernel: Call Trace:
Jan 30 13:59:57 ANDROMEDA kernel: <IRQ>
Jan 30 13:59:57 ANDROMEDA kernel: ? show_regs+0x6c/0x80
Jan 30 13:59:57 ANDROMEDA kernel: ? watchdog_timer_fn+0x218/0x2a0
Jan 30 13:59:57 ANDROMEDA kernel: ? __pfx_watchdog_timer_fn+0x10/0x10
Jan 30 13:59:57 ANDROMEDA kernel: ? __hrtimer_run_queues+0x10f/0x2a0
Jan 30 13:59:57 ANDROMEDA kernel: ? rcu_core+0x1d6/0x370
Jan 30 13:59:57 ANDROMEDA kernel: ? hrtimer_interrupt+0xf8/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? __sysvec_apic_timer_interrupt+0x56/0x130
Jan 30 13:59:57 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x9b/0xc0
Jan 30 13:59:57 ANDROMEDA kernel: </IRQ>
Jan 30 13:59:57 ANDROMEDA kernel: <TASK>
Jan 30 13:59:57 ANDROMEDA kernel: ? asm_sysvec_apic_timer_interrupt+0x1b/0x20
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv043727rm+0x3b/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv043727rm+0x21/0x80 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv014687rm+0x10f/0x170 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv035969rm+0xcb/0x110 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036175rm+0x10d/0x360 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv030736rm+0xf0/0x1f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv030736rm+0xc0/0x1f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv012623rm+0x4f8/0x5c0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036399rm+0xb0/0x130 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036481rm+0x75/0xc0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036482rm+0xd7/0x140 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036473rm+0x12a/0x320 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv036474rm+0x98/0xe0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv050276rm+0x114/0x460 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv035412rm+0x3a5/0x5f0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv004243rm+0xd/0x30 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv006122rm+0x1e/0xb0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv018080rm+0x59c/0x680 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048181rm+0xb3/0xe0 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv049956rm+0xb3/0x180 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv049955rm+0x50b/0x660 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048073rm+0xdd/0x190 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv048074rm+0x41/0x70 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv000587rm+0x4d/0x60 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? _nv000745rm+0x20f/0xe00 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? rm_ioctl+0x7f/0x400 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? srso_alias_return_thunk+0x5/0xfbef5
Jan 30 13:59:57 ANDROMEDA kernel: ? restore_fpregs_from_fpstate+0x3d/0xd0
Jan 30 13:59:57 ANDROMEDA kernel: ? nvidia_unlocked_ioctl+0x7db/0x920 [nvidia]
Jan 30 13:59:57 ANDROMEDA kernel: ? __x64_sys_ioctl+0xa0/0xf0
Jan 30 13:59:57 ANDROMEDA kernel: ? x64_sys_call+0x11ad/0x25f0
Jan 30 13:59:57 ANDROMEDA kernel: ? do_syscall_64+0x7e/0x170
Jan 30 13:59:57 ANDROMEDA kernel: ? switch_fpu_return+0x50/0xe0
Jan 30 13:59:57 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x18d/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? do_syscall_64+0x8a/0x170
Jan 30 13:59:57 ANDROMEDA kernel: ? syscall_exit_to_user_mode+0x4e/0x250
Jan 30 13:59:57 ANDROMEDA kernel: ? sysvec_apic_timer_interrupt+0x57/0xc0
Jan 30 13:59:57 ANDROMEDA kernel: ? entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jan 30 13:59:57 ANDROMEDA kernel: </TASK>
Jan 30 14:00:01 ANDROMEDA CRON[222202]: pam_unix(cron:session): session opened for user root(uid=0) by root(uid=0)
Jan 30 14:00:01 ANDROMEDA CRON[222203]: (root) CMD (timeshift --check --scripted)
Jan 30 14:00:01 ANDROMEDA crontab[222231]: (root) LIST (root)
Jan 30 14:00:01 ANDROMEDA crontab[222232]: (root) LIST (root)
Jan 30 14:00:01 ANDROMEDA systemd[1]: run-timeshift-222203-backup.mount: Deactivated successfully.
Jan 30 14:00:01 ANDROMEDA CRON[222202]: pam_unix(cron:session): session closed for user root
Jan 30 14:00:19 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (2 suppressed)
Jan 30 14:00:19 ANDROMEDA kernel: NVRM: Xid (PCI:0000:01:00): 16, pid='<unknown>', name=<unknown>, Head 00000003 Count 00803b49
Jan 30 14:00:19 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79338898778794 a:79338898815374 f:79338898825964 waiting:36580 process:10590 status:triggered
Jan 30 14:00:27 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (2 suppressed)
Jan 30 14:00:27 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:0/3 s:79348931062168 a:79348931091848 f:79348931100798 waiting:29680 process:8950 status:triggered
Jan 30 14:00:29 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 14:00:29 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79350945136329 a:79350945172549 f:79350945181529 waiting:36220 process:8980 status:triggered
Jan 30 14:00:59 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:01 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:03 ANDROMEDA kernel: NVRM: os_schedule: Attempted to yield the CPU while in atomic or interrupt context
Jan 30 14:01:03 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) graph xrun not-triggered (1 suppressed)
Jan 30 14:01:03 ANDROMEDA pipewire[2859]: pw.node: (alsa_output.usb-Logitech_A50-00.pro-output-1-46) xrun state:0x7282e1e11008 pending:1/3 s:79385356694691 a:79386825035293 f:79386825076193 waiting:1468340602 process:40900 status:triggered
Jan 30 14:01:03 ANDROMEDA kernel: clocksource: Long readout interval, skipping watchdog check: cs_nsec: 2697992225 wd_nsec: 2697991224
Jan 30 14:01:09 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=585000
Jan 30 14:01:12 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-66 noise=9999 txrate=585000
Jan 30 14:01:15 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=9999 txrate=585000
Jan 30 14:01:24 ANDROMEDA wpa_supplicant[1401]: wlp9s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-67 noise=9999 txrate=585000
>>> switched off the pc via power button <<<
-- Boot 94b2f3930af148bb92c56249d8d182e0 --
Jan 30 14:02:10 ANDROMEDA kernel: Linux version 6.11.0-108013-tuxedo (root@runner-47n-egjk-project-32919825-concurrent-0) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.2.0-23ubuntu4) 13.2.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #14tuxnoble1 SMP PREEMPT_DYNAMIC Mon Dec 16 18:07:37 UTC 2024 (Ubuntu 6.11.0-108013.14tuxnoble1-tuxedo 6.11.0)
Jan 30 14:02:10 ANDROMEDA kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.11.0-108013-tuxedo root=UUID=dd2d00e8-5c62-4ca8-bedd-e15faea4695f ro quiet splash intel_iommu=igfx_off loglevel=3 udev.log_level=3 vt.handoff=7
Jan 30 14:02:10 ANDROMEDA kernel: KERNEL supported cpus:
Jan 30 14:02:10 ANDROMEDA kernel: Intel GenuineIntel
Jan 30 14:02:10 ANDROMEDA kernel: AMD AuthenticAMD
Jan 30 14:02:10 ANDROMEDA kernel: Hygon HygonGenuine
Jan 30 14:02:10 ANDROMEDA kernel: Centaur CentaurHauls
Jan 30 14:02:10 ANDROMEDA kernel: zhaoxin Shanghai
nvidia-bug-report.log.gz (1.2 MB)
