Looks like when installing driver 560 from Proprietary GPU Drivers : “Graphics Drivers” team all the Proton/Wine apps do not run.
My guess is that 560 packages lack 32 bit binaries, hence those don’t run.
I’ve compared side by side the packages/dependencies installed by 555 (which work perfectly) and 560 and I get the following packages as suggested:
libnvidia-compute-560:i386 libnvidia-decode-560:i386 libnvidia-encode-560:i386 libnvidia-fbc1-560:i386 libnvidia-gl-560:i386
Which are installed by default with 555.
Unfortunately, when trying to install the same directly one gets the messages along the lines of:
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Package libnvidia-gl-560:i386 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
libnvidia-common-560
E: Package ‘libnvidia-gl-560:i386’ has no installation candidate
There’s clearly some packaging issue going on with Ubuntu drivers.
I used an external SSD and installed a live Ubuntu 24 + drivers 560 from scratch, same issues.
Looks like the Ubuntu drivers team have botched this install?
Just for reference, the PPA has done 3 updates to the 560 driver, the 1st one had horrible crashes for most Steam games using Proton, the 2nd one had less crashes but still had crashes compared to 555 which were never happening. The 3rd one basically make google chrome crash segfault. Going back to 555 fixes all steam issues as well making google chrome stable again.
I will wait for 24.10 to test the 560 just in case.
Meteo
September 4, 2024, 10:00am
4
Consider that the 560 driver requires egl-wayland version 1.1.13.1 or higher to properly support EGL Wayland (Release 1.1.13.1 · NVIDIA/egl-wayland · GitHub ). In the Ubuntu repository, the latest version for Noble Numbat is 1.1.13, which is before the release of the patch for 560 drivers. You can download and install manually the version 1.1.15 (egl-wayland package : Ubuntu ) released for Oracular Oriole (24.10), or wait for an updated version for 24.04 (if it is released at all).
This is the answered. A specific dependency is creating all of these issues. I updated as you suggested and have not had gaming issues nor google chrome crashes. Although I don’t like to mix and match like this.
Meteo
September 9, 2024, 1:51pm
6
In my case, after installing the 560 driver and updating egl-wayland, the Google Chrome browser doesn’t work very well. All Graphics Feature are deactivated. When I open the browser, I see the loading animation all the time, and GPU-related errors in the console. Can you show the Graphics Feature Status from chrome://gpu/ for the Nvidia 560 driver under Ubuntu? What is your GPU?
Confirmed. This is also happening on Chrome. No wonder it has this slowness feeling. My GPU is a 4090 and if I do the chrome://gpu basically chrome says I have a Voodoo Banshee. I get the feeling this is more Google Chrome with their horrible updates as of late than an Nvidia issue (I am talking about the chrome://gpu output), but for the slowness it is only happening on 560. On 555 it runs correctly.
I created an account to thumbs you up
I should mention that I am running KDE Plasma 6.1 on 555 and so far so good.
I logged in to give you a thumbs up hehe. BTW I got https://www.youtube.com/@xtremelinux and it just so happens once Ubuntu 24.10 launches I will be literally testing KDE on it (I am a sponsored member of KDE, they do quality stuff).
This is a packaging issue in the PPA. See Launchpad bug #2081196 . The PPA is packaging nvidia_icd_vksc.json in /usr/share/vulkan/icd.d instead of /usr/share/vulkansc/icd.d. You can workaround it by moving that file to the correct directory.
It is fixed for 24.10 in the Ubuntu repo here .
Meteo
September 30, 2024, 7:55pm
12
I want to note that in the PPA Proprietary GPU Drivers : “Graphics Drivers” team , the 560.35.03 driver for Ubuntu 24.04 has been released with the fix mentioned by @conky_vs_julian . In addition, the egl-wayland package version 1:1.1.15 for Ubuntu 24.04 has been made available in this PPA, so the manual installation I mentioned earlier is no longer necessary. I installed the 560.35.03 driver on Ubuntu 24.04 and so far I haven’t observed any performance problems.
I updated to the 560 drivers yesterday and can confirm that Proton/Wine games are running fine now. Been playing a few different games today from various sources (Steam, Lutris and Heroic) and everything runs great without any performance issues or crashes.
Can confirm the same. Since the Sunday update all seems now working.
Thanks to Ubuntu maintainers!
I have updated to ubuntu 24.10 (wayland), added the ppa and installed 560.35.03 driver but I still have the issue.
nvidia-smi gives:
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I do not know what to do anymore.
Thanks in advance for your help
You either have multiple versions of the Nvidia software installed, or you’re missing the software tools to be able to build software drivers.
For the first, do “dpkg -l *nvidia*”, see if you have multiple versions installed, if so, purge the old versions. If you don’t, switch to your Intel video, reboot, and then purge anything that says nvidia on it and matches the nvidia driver version. Then reinstall the nvidia driver using “Additional Drivers”.
For the second, install gcc, make, build-essentials. Reinstall the nvidia driver using “Additional Drivers”.
Thanks heynema, I did clean everything and ‘dpkg -l nvidia ’ shows everywhere.
I have all the lastest gcc, make, build-essential.
When I try “Additional Drivers”, it says that ‘This device is using a manually-installed driver’ and suggest to “Continue using a manually installed driver”. I also checked all drivers with ‘sudo apt-mark auto’ and they are all not installed. I did use at some point the Nvidia driver from their website so maybe it messed up something…
Show me the complete output of the “dpkg -l *nvidia*” command, and a screenshot of your Additional Drivers window. See if this command still works… sudo prime-select intel. Do you also have dkms installed?
dpkg -l nvidia
BlockquoteDesired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un libgldispatch0-nvidia (no description available)
hn libnvidia-cfg1-390 amd64 (no description available)
hn libnvidia-cfg1-418 amd64 (no description available)
hn libnvidia-cfg1-418-server amd64 (no description available)
hn libnvidia-cfg1-430 amd64 (no description available)
hn libnvidia-cfg1-435 amd64 (no description available)
hn libnvidia-cfg1-440 amd64 (no description available)
hn libnvidia-cfg1-440-server amd64 (no description available)
hn libnvidia-cfg1-450 amd64 (no description available)
hn libnvidia-cfg1-450-server amd64 (no description available)
hn libnvidia-cfg1-455 amd64 (no description available)
hn libnvidia-cfg1-460 amd64 (no description available)
hn libnvidia-cfg1-460-server amd64 (no description available)
hn libnvidia-cfg1-465 amd64 (no description available)
hn libnvidia-cfg1-470 amd64 (no description available)
hn libnvidia-cfg1-470-server amd64 (no description available)
hn libnvidia-cfg1-495 amd64 (no description available)
hn libnvidia-cfg1-510 amd64 (no description available)
hn libnvidia-cfg1-510-server amd64 (no description available)
hn libnvidia-cfg1-515 amd64 (no description available)
hn libnvidia-cfg1-515-server amd64 (no description available)
hn libnvidia-cfg1-520 amd64 (no description available)
hn libnvidia-cfg1-525 amd64 (no description available)
hn libnvidia-cfg1-525-server amd64 (no description available)
hn libnvidia-cfg1-530 amd64 (no description available)
hn libnvidia-cfg1-535-server amd64 (no description available)
hn libnvidia-cfg1-545 amd64 (no description available)
hn libnvidia-cfg1-550-server amd64 (no description available)
hn libnvidia-common-390 all (no description available)
hn libnvidia-common-418 all (no description available)
hn libnvidia-common-418-server all (no description available)
hn libnvidia-common-430 all (no description available)
hn libnvidia-common-435 all (no description available)
hn libnvidia-common-440 all (no description available)
hn libnvidia-common-440-server all (no description available)
hn libnvidia-common-450 all (no description available)
hn libnvidia-common-450-server all (no description available)
hn libnvidia-common-455 all (no description available)
hn libnvidia-common-460 all (no description available)
hn libnvidia-common-460-server all (no description available)
hn libnvidia-common-465 all (no description available)
hn libnvidia-common-470 all (no description available)
hn libnvidia-common-470-server all (no description available)
hn libnvidia-common-495 all (no description available)
hn libnvidia-common-510 all (no description available)
hn libnvidia-common-510-server all (no description available)
hn libnvidia-common-515 all (no description available)
hn libnvidia-common-515-server all (no description available)
hn libnvidia-common-520 all (no description available)
hn libnvidia-common-525 all (no description available)
hn libnvidia-common-525-server all (no description available)
hn libnvidia-common-530 all (no description available)
hn libnvidia-common-535-server all (no description available)
hn libnvidia-common-545 all (no description available)
hn libnvidia-common-550-server all (no description available)
hn libnvidia-compute-390 amd64 (no description available)
hn libnvidia-compute-418 amd64 (no description available)
hn libnvidia-compute-418-server amd64 (no description available)
hn libnvidia-compute-430 amd64 (no description available)
hn libnvidia-compute-435 amd64 (no description available)
hn libnvidia-compute-440 amd64 (no description available)
hn libnvidia-compute-440-server amd64 (no description available)
hn libnvidia-compute-450 amd64 (no description available)
hn libnvidia-compute-450-server amd64 (no description available)
hn libnvidia-compute-455 amd64 (no description available)
hn libnvidia-compute-460 amd64 (no description available)
hn libnvidia-compute-460-server amd64 (no description available)
hn libnvidia-compute-465 amd64 (no description available)
hn libnvidia-compute-470 amd64 (no description available)
hn libnvidia-compute-470-server amd64 (no description available)
hn libnvidia-compute-495 amd64 (no description available)
hn libnvidia-compute-510 amd64 (no description available)
hn libnvidia-compute-510-server amd64 (no description available)
hn libnvidia-compute-515 amd64 (no description available)
hn libnvidia-compute-515-server amd64 (no description available)
hn libnvidia-compute-520 amd64 (no description available)
hn libnvidia-compute-525 amd64 (no description available)
hn libnvidia-compute-525-server amd64 (no description available)
hn libnvidia-compute-530 amd64 (no description available)
hn libnvidia-compute-535-server amd64 (no description available)
hn libnvidia-compute-545 amd64 (no description available)
hn libnvidia-compute-550-server amd64 (no description available)
hn libnvidia-container-dev amd64 (no description available)
hn libnvidia-container1-dbg amd64 (no description available)
hn libnvidia-decode-390 amd64 (no description available)
hn libnvidia-decode-418 amd64 (no description available)
hn libnvidia-decode-418-server amd64 (no description available)
hn libnvidia-decode-430 amd64 (no description available)
hn libnvidia-decode-435 amd64 (no description available)
hn libnvidia-decode-440 amd64 (no description available)
hn libnvidia-decode-440-server amd64 (no description available)
hn libnvidia-decode-450 amd64 (no description available)
hn libnvidia-decode-450-server amd64 (no description available)
hn libnvidia-decode-455 amd64 (no description available)
hn libnvidia-decode-460 amd64 (no description available)
hn libnvidia-decode-460-server amd64 (no description available)
hn libnvidia-decode-465 amd64 (no description available)
hn libnvidia-decode-470 amd64 (no description available)
hn libnvidia-decode-470-server amd64 (no description available)
hn libnvidia-decode-495 amd64 (no description available)
hn libnvidia-decode-510 amd64 (no description available)
hn libnvidia-decode-510-server amd64 (no description available)
hn libnvidia-decode-515 amd64 (no description available)
hn libnvidia-decode-515-server amd64 (no description available)
hn libnvidia-decode-520 amd64 (no description available)
hn libnvidia-decode-525 amd64 (no description available)
hn libnvidia-decode-525-server amd64 (no description available)
hn libnvidia-decode-530 amd64 (no description available)
hn libnvidia-decode-535-server amd64 (no description available)
hn libnvidia-decode-545 amd64 (no description available)
hn libnvidia-decode-550-server amd64 (no description available)
hn libnvidia-egl-gbm1 amd64 (no description available)
hn libnvidia-egl-wayland-dev amd64 (no description available)
hn libnvidia-encode-390 amd64 (no description available)
hn libnvidia-encode-418 amd64 (no description available)
hn libnvidia-encode-418-server amd64 (no description available)
hn libnvidia-encode-430 amd64 (no description available)
hn libnvidia-encode-435 amd64 (no description available)
hn libnvidia-encode-440 amd64 (no description available)
hn libnvidia-encode-440-server amd64 (no description available)
hn libnvidia-encode-450 amd64 (no description available)
hn libnvidia-encode-450-server amd64 (no description available)
hn libnvidia-encode-455 amd64 (no description available)
hn libnvidia-encode-460 amd64 (no description available)
hn libnvidia-encode-460-server amd64 (no description available)
hn libnvidia-encode-465 amd64 (no description available)
hn libnvidia-encode-470 amd64 (no description available)
hn libnvidia-encode-470-server amd64 (no description available)
hn libnvidia-encode-495 amd64 (no description available)
hn libnvidia-encode-510 amd64 (no description available)
hn libnvidia-encode-510-server amd64 (no description available)
hn libnvidia-encode-515 amd64 (no description available)
hn libnvidia-encode-515-server amd64 (no description available)
hn libnvidia-encode-520 amd64 (no description available)
hn libnvidia-encode-525 amd64 (no description available)
hn libnvidia-encode-525-server amd64 (no description available)
hn libnvidia-encode-530 amd64 (no description available)
hn libnvidia-encode-535-server amd64 (no description available)
hn libnvidia-encode-545 amd64 (no description available)
hn libnvidia-encode-550-server amd64 (no description available)
un libnvidia-encode1 (no description available)
hn libnvidia-extra-440 amd64 (no description available)
hn libnvidia-extra-440-server amd64 (no description available)
hn libnvidia-extra-450 amd64 (no description available)
hn libnvidia-extra-450-server amd64 (no description available)
hn libnvidia-extra-455 amd64 (no description available)
hn libnvidia-extra-460 amd64 (no description available)
hn libnvidia-extra-460-server amd64 (no description available)
hn libnvidia-extra-465 amd64 (no description available)
hn libnvidia-extra-470 amd64 (no description available)
hn libnvidia-extra-470-server amd64 (no description available)
hn libnvidia-extra-495 amd64 (no description available)
hn libnvidia-extra-510 amd64 (no description available)
hn libnvidia-extra-510-server amd64 (no description available)
hn libnvidia-extra-515 amd64 (no description available)
hn libnvidia-extra-515-server amd64 (no description available)
hn libnvidia-extra-520 amd64 (no description available)
hn libnvidia-extra-525 amd64 (no description available)
hn libnvidia-extra-525-server amd64 (no description available)
hn libnvidia-extra-530 amd64 (no description available)
hn libnvidia-extra-535-server amd64 (no description available)
hn libnvidia-extra-545 amd64 (no description available)
hn libnvidia-extra-550-server amd64 (no description available)
hn libnvidia-fbc1-390 amd64 (no description available)
hn libnvidia-fbc1-418 amd64 (no description available)
hn libnvidia-fbc1-418-server amd64 (no description available)
hn libnvidia-fbc1-430 amd64 (no description available)
hn libnvidia-fbc1-435 amd64 (no description available)
hn libnvidia-fbc1-440 amd64 (no description available)
hn libnvidia-fbc1-440-server amd64 (no description available)
hn libnvidia-fbc1-450 amd64 (no description available)
hn libnvidia-fbc1-450-server amd64 (no description available)
hn libnvidia-fbc1-455 amd64 (no description available)
hn libnvidia-fbc1-460 amd64 (no description available)
hn libnvidia-fbc1-460-server amd64 (no description available)
hn libnvidia-fbc1-465 amd64 (no description available)
hn libnvidia-fbc1-470 amd64 (no description available)
hn libnvidia-fbc1-470-server amd64 (no description available)
hn libnvidia-fbc1-495 amd64 (no description available)
hn libnvidia-fbc1-510 amd64 (no description available)
hn libnvidia-fbc1-510-server amd64 (no description available)
hn libnvidia-fbc1-515 amd64 (no description available)
hn libnvidia-fbc1-515-server amd64 (no description available)
hn libnvidia-fbc1-520 amd64 (no description available)
hn libnvidia-fbc1-525 amd64 (no description available)
hn libnvidia-fbc1-525-server amd64 (no description available)
hn libnvidia-fbc1-530 amd64 (no description available)
hn libnvidia-fbc1-535-server amd64 (no description available)
hn libnvidia-fbc1-545 amd64 (no description available)
hn libnvidia-fbc1-550-server amd64 (no description available)
hn libnvidia-gl-390 amd64 (no description available)
hn libnvidia-gl-418 amd64 (no description available)
hn libnvidia-gl-418-server amd64 (no description available)
hn libnvidia-gl-430 amd64 (no description available)
hn libnvidia-gl-435 amd64 (no description available)
hn libnvidia-gl-440 amd64 (no description available)
hn libnvidia-gl-440-server amd64 (no description available)
hn libnvidia-gl-450 amd64 (no description available)
hn libnvidia-gl-450-server amd64 (no description available)
hn libnvidia-gl-455 amd64 (no description available)
hn libnvidia-gl-460 amd64 (no description available)
hn libnvidia-gl-460-server amd64 (no description available)
hn libnvidia-gl-465 amd64 (no description available)
hn libnvidia-gl-470 amd64 (no description available)
hn libnvidia-gl-470-server amd64 (no description available)
hn libnvidia-gl-495 amd64 (no description available)
hn libnvidia-gl-510 amd64 (no description available)
hn libnvidia-gl-510-server amd64 (no description available)
hn libnvidia-gl-515 amd64 (no description available)
hn libnvidia-gl-515-server amd64 (no description available)
hn libnvidia-gl-520 amd64 (no description available)
hn libnvidia-gl-525 amd64 (no description available)
hn libnvidia-gl-525-server amd64 (no description available)
hn libnvidia-gl-530 amd64 (no description available)
hn libnvidia-gl-535-server amd64 (no description available)
hn libnvidia-gl-545 amd64 (no description available)
hn libnvidia-gl-550-server amd64 (no description available)
hn libnvidia-ifr1-390 amd64 (no description available)
hn libnvidia-ifr1-418 amd64 (no description available)
hn libnvidia-ifr1-418-server amd64 (no description available)
hn libnvidia-ifr1-430 amd64 (no description available)
hn libnvidia-ifr1-435 amd64 (no description available)
hn libnvidia-ifr1-440 amd64 (no description available)
hn libnvidia-ifr1-440-server amd64 (no description available)
hn libnvidia-ifr1-450 amd64 (no description available)
hn libnvidia-ifr1-450-server amd64 (no description available)
hn libnvidia-ifr1-455 amd64 (no description available)
hn libnvidia-ifr1-460 amd64 (no description available)
hn libnvidia-ifr1-460-server amd64 (no description available)
hn libnvidia-ifr1-465 amd64 (no description available)
hn libnvidia-ifr1-470 amd64 (no description available)
hn libnvidia-ifr1-470-server amd64 (no description available)
hn libnvidia-ml-dev amd64 (no description available)
hn libnvidia-nscq-450 amd64 (no description available)
hn libnvidia-nscq-460 amd64 (no description available)
hn libnvidia-nscq-470 amd64 (no description available)
hn libnvidia-nscq-510 amd64 (no description available)
hn libnvidia-nscq-515 amd64 (no description available)
hn libnvidia-nscq-525 amd64 (no description available)
hn libnvidia-nscq-535 amd64 (no description available)
hn libnvidia-nscq-550 amd64 (no description available)
hn nvidia-340 amd64 (no description available)
hn nvidia-340-dev amd64 (no description available)
hn nvidia-340-uvm amd64 (no description available)
hn nvidia-384 amd64 (no description available)
hn nvidia-384-dev amd64 (no description available)
hn nvidia-cg-dev amd64 (no description available)
hn nvidia-cg-doc all (no description available)
hn nvidia-cg-toolkit amd64 (no description available)
hn nvidia-common amd64 (no description available)
hn nvidia-compute-utils-390 amd64 (no description available)
hn nvidia-compute-utils-418 amd64 (no description available)
hn nvidia-compute-utils-418-server amd64 (no description available)
hn nvidia-compute-utils-430 amd64 (no description available)
hn nvidia-compute-utils-435 amd64 (no description available)
hn nvidia-compute-utils-440 amd64 (no description available)
hn nvidia-compute-utils-440-server amd64 (no description available)
hn nvidia-compute-utils-450 amd64 (no description available)
hn nvidia-compute-utils-450-server amd64 (no description available)
hn nvidia-compute-utils-455 amd64 (no description available)
hn nvidia-compute-utils-460 amd64 (no description available)
hn nvidia-compute-utils-460-server amd64 (no description available)
hn nvidia-compute-utils-465 amd64 (no description available)
hn nvidia-compute-utils-470 amd64 (no description available)
hn nvidia-compute-utils-470-server amd64 (no description available)
hn nvidia-compute-utils-495 amd64 (no description available)
hn nvidia-compute-utils-510 amd64 (no description available)
hn nvidia-compute-utils-510-server amd64 (no description available)
hn nvidia-compute-utils-515 amd64 (no description available)
hn nvidia-compute-utils-515-server amd64 (no description available)
hn nvidia-compute-utils-520 amd64 (no description available)
hn nvidia-compute-utils-525 amd64 (no description available)
hn nvidia-compute-utils-525-server amd64 (no description available)
hn nvidia-compute-utils-530 amd64 (no description available)
hn nvidia-compute-utils-535-server amd64 (no description available)
hn nvidia-compute-utils-545 amd64 (no description available)
hn nvidia-compute-utils-550-server amd64 (no description available)
hn nvidia-container-runtime all (no description available)
hn nvidia-container-runtime-hook amd64 (no description available)
hn nvidia-cuda-dev amd64 (no description available)
hn nvidia-cuda-gdb amd64 (no description available)
hn nvidia-cuda-toolkit amd64 (no description available)
hn nvidia-cuda-toolkit-doc all (no description available)
hn nvidia-cuda-toolkit-gcc amd64 (no description available)
hn nvidia-cudnn amd64 (no description available)
hn nvidia-dkms-390 amd64 (no description available)
hn nvidia-dkms-418 amd64 (no description available)
hn nvidia-dkms-418-server amd64 (no description available)
hn nvidia-dkms-430 amd64 (no description available)
hn nvidia-dkms-435 amd64 (no description available)
hn nvidia-dkms-440 amd64 (no description available)
hn nvidia-dkms-440-server amd64 (no description available)
hn nvidia-dkms-450 amd64 (no description available)
hn nvidia-dkms-450-server amd64 (no description available)
hn nvidia-dkms-455 amd64 (no description available)
hn nvidia-dkms-460 amd64 (no description available)
hn nvidia-dkms-460-server amd64 (no description available)
hn nvidia-dkms-465 amd64 (no description available)
hn nvidia-dkms-470 amd64 (no description available)
hn nvidia-dkms-470-server amd64 (no description available)
hn nvidia-dkms-495 amd64 (no description available)
hn nvidia-dkms-510 amd64 (no description available)
hn nvidia-dkms-510-server amd64 (no description available)
hn nvidia-dkms-515 amd64 (no description available)
hn nvidia-dkms-515-open amd64 (no description available)
hn nvidia-dkms-515-server amd64 (no description available)
hn nvidia-dkms-520 amd64 (no description available)
hn nvidia-dkms-520-open amd64 (no description available)
hn nvidia-dkms-525 amd64 (no description available)
hn nvidia-dkms-525-open amd64 (no description available)
hn nvidia-dkms-525-server amd64 (no description available)
hn nvidia-dkms-530 amd64 (no description available)
hn nvidia-dkms-530-open amd64 (no description available)
hn nvidia-dkms-535 amd64 (no description available)
hn nvidia-dkms-535-open amd64 (no description available)
hn nvidia-dkms-535-server amd64 (no description available)
hn nvidia-dkms-535-server-open amd64 (no description available)
hn nvidia-dkms-545 amd64 (no description available)
hn nvidia-dkms-545-open amd64 (no description available)
hn nvidia-dkms-550-server amd64 (no description available)
hn nvidia-dkms-550-server-open amd64 (no description available)
hn nvidia-docker2 all (no description available)
hn nvidia-driver-390 amd64 (no description available)
hn nvidia-driver-418 amd64 (no description available)
hn nvidia-driver-418-server amd64 (no description available)
hn nvidia-driver-430 amd64 (no description available)
hn nvidia-driver-435 amd64 (no description available)
hn nvidia-driver-440 amd64 (no description available)
hn nvidia-driver-440-server amd64 (no description available)
hn nvidia-driver-450 amd64 (no description available)
hn nvidia-driver-450-server amd64 (no description available)
hn nvidia-driver-455 amd64 (no description available)
hn nvidia-driver-460 amd64 (no description available)
hn nvidia-driver-460-server amd64 (no description available)
hn nvidia-driver-465 amd64 (no description available)
hn nvidia-driver-470 amd64 (no description available)
hn nvidia-driver-470-server amd64 (no description available)
hn nvidia-driver-495 amd64 (no description available)
hn nvidia-driver-510 amd64 (no description available)
hn nvidia-driver-510-server amd64 (no description available)
hn nvidia-driver-515 amd64 (no description available)
hn nvidia-driver-515-open amd64 (no description available)
hn nvidia-driver-515-server amd64 (no description available)
hn nvidia-driver-520 amd64 (no description available)
hn nvidia-driver-520-open amd64 (no description available)
hn nvidia-driver-525 amd64 (no description available)
hn nvidia-driver-525-open amd64 (no description available)
hn nvidia-driver-525-server amd64 (no description available)
hn nvidia-driver-530 amd64 (no description available)
hn nvidia-driver-530-open amd64 (no description available)
hn nvidia-driver-535-open amd64 (no description available)
hn nvidia-driver-535-server amd64 (no description available)
hn nvidia-driver-535-server-open amd64 (no description available)
hn nvidia-driver-545 amd64 (no description available)
hn nvidia-driver-545-open amd64 (no description available)
hn nvidia-driver-550-server amd64 (no description available)
hn nvidia-driver-550-server-open amd64 (no description available)
hn nvidia-fabricmanager-450 amd64 (no description available)
hn nvidia-fabricmanager-460 amd64 (no description available)
hn nvidia-fabricmanager-470 amd64 (no description available)
hn nvidia-fabricmanager-510 amd64 (no description available)
hn nvidia-fabricmanager-515 amd64 (no description available)
hn nvidia-fabricmanager-525 amd64 (no description available)
hn nvidia-fabricmanager-535 amd64 (no description available)
hn nvidia-fabricmanager-550 amd64 (no description available)
hn nvidia-fabricmanager-dev-450 amd64 (no description available)
hn nvidia-fabricmanager-dev-460 amd64 (no description available)
hn nvidia-fabricmanager-dev-470 amd64 (no description available)
hn nvidia-fabricmanager-dev-510 amd64 (no description available)
hn nvidia-fabricmanager-dev-515 amd64 (no description available)
hn nvidia-fabricmanager-dev-525 amd64 (no description available)
hn nvidia-fabricmanager-dev-535 amd64 (no description available)
hn nvidia-fabricmanager-dev-550 amd64 (no description available)
hn nvidia-firmware-535-535.104.05 amd64 (no description available)
hn nvidia-firmware-535-535.113.01 amd64 (no description available)
hn nvidia-firmware-535-535.129.03 amd64 (no description available)
hn nvidia-firmware-535-535.146.02 amd64 (no description available)
hn nvidia-firmware-535-535.161.07 amd64 (no description available)
hn nvidia-firmware-535-535.54.03 amd64 (no description available)
hn nvidia-firmware-535-535.86.05 amd64 (no description available)
hn nvidia-firmware-535-server-535.104.05 amd64 (no description available)
hn nvidia-firmware-535-server-535.104.12 amd64 (no description available)
hn nvidia-firmware-535-server-535.129.03 amd64 (no description available)
hn nvidia-firmware-535-server-535.154.05 amd64 (no description available)
hn nvidia-firmware-535-server-535.161.07 amd64 (no description available)
hn nvidia-firmware-535-server-535.161.08 amd64 (no description available)
hn nvidia-firmware-535-server-535.54.03 amd64 (no description available)
hn nvidia-firmware-545-545.29.06 amd64 (no description available)
hn nvidia-firmware-550-server-550.54.14 amd64 (no description available)
hn nvidia-headless-390 amd64 (no description available)
hn nvidia-headless-418 amd64 (no description available)
hn nvidia-headless-418-server amd64 (no description available)
hn nvidia-headless-430 amd64 (no description available)
hn nvidia-headless-435 amd64 (no description available)
hn nvidia-headless-440 amd64 (no description available)
hn nvidia-headless-440-server amd64 (no description available)
hn nvidia-headless-450 amd64 (no description available)
hn nvidia-headless-450-server amd64 (no description available)
hn nvidia-headless-455 amd64 (no description available)
hn nvidia-headless-460 amd64 (no description available)
hn nvidia-headless-460-server amd64 (no description available)
hn nvidia-headless-465 amd64 (no description available)
hn nvidia-headless-470 amd64 (no description available)
hn nvidia-headless-470-server amd64 (no description available)
hn nvidia-headless-495 amd64 (no description available)
hn nvidia-headless-510 amd64 (no description available)
hn nvidia-headless-510-server amd64 (no description available)
hn nvidia-headless-515 amd64 (no description available)
hn nvidia-headless-515-open amd64 (no description available)
hn nvidia-headless-515-server amd64 (no description available)
hn nvidia-headless-520 amd64 (no description available)
hn nvidia-headless-520-open amd64 (no description available)
hn nvidia-headless-525 amd64 (no description available)
hn nvidia-headless-525-open amd64 (no description available)
hn nvidia-headless-525-server amd64 (no description available)
hn nvidia-headless-530 amd64 (no description available)
hn nvidia-headless-530-open amd64 (no description available)
hn nvidia-headless-535 amd64 (no description available)
hn nvidia-headless-535-open amd64 (no description available)
hn nvidia-headless-535-server amd64 (no description available)
hn nvidia-headless-535-server-open amd64 (no description available)
hn nvidia-headless-545 amd64 (no description available)
hn nvidia-headless-545-open amd64 (no description available)
hn nvidia-headless-550-server amd64 (no description available)
hn nvidia-headless-550-server-open amd64 (no description available)
hn nvidia-headless-no-dkms-390 amd64 (no description available)
hn nvidia-headless-no-dkms-418 amd64 (no description available)
hn nvidia-headless-no-dkms-418-server amd64 (no description available)
hn nvidia-headless-no-dkms-430 amd64 (no description available)
hn nvidia-headless-no-dkms-435 amd64 (no description available)
hn nvidia-headless-no-dkms-440 amd64 (no description available)
hn nvidia-headless-no-dkms-440-server amd64 (no description available)
hn nvidia-headless-no-dkms-450 amd64 (no description available)
hn nvidia-headless-no-dkms-450-server amd64 (no description available)
hn nvidia-headless-no-dkms-455 amd64 (no description available)
hn nvidia-headless-no-dkms-460 amd64 (no description available)
hn nvidia-headless-no-dkms-460-server amd64 (no description available)
hn nvidia-headless-no-dkms-465 amd64 (no description available)
hn nvidia-headless-no-dkms-470 amd64 (no description available)
hn nvidia-headless-no-dkms-470-server amd64 (no description available)
hn nvidia-headless-no-dkms-495 amd64 (no description available)
hn nvidia-headless-no-dkms-510 amd64 (no description available)
hn nvidia-headless-no-dkms-510-server amd64 (no description available)
hn nvidia-headless-no-dkms-515 amd64 (no description available)
hn nvidia-headless-no-dkms-515-open amd64 (no description available)
hn nvidia-headless-no-dkms-515-server amd64 (no description available)
hn nvidia-headless-no-dkms-520 amd64 (no description available)
hn nvidia-headless-no-dkms-520-open amd64 (no description available)
hn nvidia-headless-no-dkms-525 amd64 (no description available)
hn nvidia-headless-no-dkms-525-open amd64 (no description available)
hn nvidia-headless-no-dkms-525-server amd64 (no description available)
hn nvidia-headless-no-dkms-530 amd64 (no description available)
hn nvidia-headless-no-dkms-530-open amd64 (no description available)
hn nvidia-headless-no-dkms-535 amd64 (no description available)
hn nvidia-headless-no-dkms-535-open amd64 (no description available)
hn nvidia-headless-no-dkms-535-server amd64 (no description available)
hn nvidia-headless-no-dkms-535-server-open amd64 (no description available)
hn nvidia-headless-no-dkms-545 amd64 (no description available)
hn nvidia-headless-no-dkms-545-open amd64 (no description available)
hn nvidia-headless-no-dkms-550-server amd64 (no description available)
hn nvidia-headless-no-dkms-550-server-open amd64 (no description available)
hn nvidia-kernel-common-390 amd64 (no description available)
hn nvidia-kernel-common-418 amd64 (no description available)
hn nvidia-kernel-common-418-server amd64 (no description available)
hn nvidia-kernel-common-430 amd64 (no description available)
hn nvidia-kernel-common-435 amd64 (no description available)
hn nvidia-kernel-common-440 amd64 (no description available)
hn nvidia-kernel-common-440-server amd64 (no description available)
hn nvidia-kernel-common-450 amd64 (no description available)
hn nvidia-kernel-common-450-server amd64 (no description available)
hn nvidia-kernel-common-455 amd64 (no description available)
hn nvidia-kernel-common-460 amd64 (no description available)
hn nvidia-kernel-common-460-server amd64 (no description available)
hn nvidia-kernel-common-465 amd64 (no description available)
hn nvidia-kernel-common-470 amd64 (no description available)
hn nvidia-kernel-common-470-server amd64 (no description available)
hn nvidia-kernel-common-495 amd64 (no description available)
hn nvidia-kernel-common-510 amd64 (no description available)
hn nvidia-kernel-common-510-server amd64 (no description available)
hn nvidia-kernel-common-515 amd64 (no description available)
hn nvidia-kernel-common-515-server amd64 (no description available)
hn nvidia-kernel-common-520 amd64 (no description available)
hn nvidia-kernel-common-525 amd64 (no description available)
hn nvidia-kernel-common-525-server amd64 (no description available)
hn nvidia-kernel-common-530 amd64 (no description available)
hn nvidia-kernel-common-535-server amd64 (no description available)
hn nvidia-kernel-common-545 amd64 (no description available)
hn nvidia-kernel-common-550-server amd64 (no description available)
hn nvidia-kernel-source-390 amd64 (no description available)
hn nvidia-kernel-source-418 amd64 (no description available)
hn nvidia-kernel-source-418-server amd64 (no description available)
hn nvidia-kernel-source-430 amd64 (no description available)
hn nvidia-kernel-source-435 amd64 (no description available)
hn nvidia-kernel-source-440 amd64 (no description available)
hn nvidia-kernel-source-440-server amd64 (no description available)
hn nvidia-kernel-source-450 amd64 (no description available)
hn nvidia-kernel-source-450-server amd64 (no description available)
hn nvidia-kernel-source-455 amd64 (no description available)
hn nvidia-kernel-source-460 amd64 (no description available)
hn nvidia-kernel-source-460-server amd64 (no description available)
hn nvidia-kernel-source-465 amd64 (no description available)
hn nvidia-kernel-source-470 amd64 (no description available)
hn nvidia-kernel-source-470-server amd64 (no description available)
hn nvidia-kernel-source-495 amd64 (no description available)
hn nvidia-kernel-source-510 amd64 (no description available)
hn nvidia-kernel-source-510-server amd64 (no description available)
hn nvidia-kernel-source-515 amd64 (no description available)
hn nvidia-kernel-source-515-open amd64 (no description available)
hn nvidia-kernel-source-515-server amd64 (no description available)
hn nvidia-kernel-source-520 amd64 (no description available)
hn nvidia-kernel-source-520-open amd64 (no description available)
hn nvidia-kernel-source-525 amd64 (no description available)
hn nvidia-kernel-source-525-open amd64 (no description available)
hn nvidia-kernel-source-525-server amd64 (no description available)
hn nvidia-kernel-source-530 amd64 (no description available)
hn nvidia-kernel-source-530-open amd64 (no description available)
hn nvidia-kernel-source-535-open amd64 (no description available)
hn nvidia-kernel-source-535-server amd64 (no description available)
hn nvidia-kernel-source-535-server-open amd64 (no description available)
hn nvidia-kernel-source-545 amd64 (no description available)
hn nvidia-kernel-source-545-open amd64 (no description available)
hn nvidia-kernel-source-550-server amd64 (no description available)
hn nvidia-kernel-source-550-server-open amd64 (no description available)
hn nvidia-libopencl1-340 amd64 (no description available)
hn nvidia-libopencl1-384 amd64 (no description available)
un nvidia-libopencl1-dev (no description available)
hn nvidia-modprobe amd64 (no description available)
hn nvidia-opencl-dev amd64 (no description available)
hn nvidia-opencl-icd-340 amd64 (no description available)
hn nvidia-opencl-icd-384 amd64 (no description available)
un nvidia-prime (no description available)
hn nvidia-primus-vk-common amd64 (no description available)
hn nvidia-primus-vk-wrapper amd64 (no description available)
hn nvidia-profiler amd64 (no description available)
hn nvidia-utils-390 amd64 (no description available)
hn nvidia-utils-418 amd64 (no description available)
hn nvidia-utils-418-server amd64 (no description available)
hn nvidia-utils-430 amd64 (no description available)
hn nvidia-utils-435 amd64 (no description available)
hn nvidia-utils-440 amd64 (no description available)
hn nvidia-utils-440-server amd64 (no description available)
hn nvidia-utils-450 amd64 (no description available)
hn nvidia-utils-450-server amd64 (no description available)
hn nvidia-utils-455 amd64 (no description available)
hn nvidia-utils-460 amd64 (no description available)
hn nvidia-utils-460-server amd64 (no description available)
hn nvidia-utils-465 amd64 (no description available)
hn nvidia-utils-470 amd64 (no description available)
hn nvidia-utils-470-server amd64 (no description available)
hn nvidia-utils-495 amd64 (no description available)
hn nvidia-utils-510 amd64 (no description available)
hn nvidia-utils-510-server amd64 (no description available)
hn nvidia-utils-515 amd64 (no description available)
hn nvidia-utils-515-server amd64 (no description available)
hn nvidia-utils-520 amd64 (no description available)
hn nvidia-utils-525 amd64 (no description available)
hn nvidia-utils-525-server amd64 (no description available)
hn nvidia-utils-530 amd64 (no description available)
hn nvidia-utils-535-server amd64 (no description available)
hn nvidia-utils-545 amd64 (no description available)
hn nvidia-utils-550-server amd64 (no description available)
hn nvidia-visual-profiler amd64 (no description available)
screenshot:
dpkg -l dkms gives:
ii dkms 3.0.11-1ubuntu14 all Dynamic Kernel Module System (DKMS)
‘sudo prime-select intel’ does not work (prime-select is not installed)
Thanks for the details. Note that in the first column you’ll properly see “un” as uninstalled. But the “bn” is something I haven’t seen before… and it looks like it indicates half-installed.
So… “purge *nvidia*”, and dpkg should then show nothing for nvidia, or all nvidia as “un”. Then using Additional Drivers, install the 550 or 555 (not the -open version) driver (I’m starting to suspect 560 problems… as it’s a beta release).
Report back.
