Environment
- GPU: 8x NVIDIA B300 SXM6 AC
- Driver: 580.159.04 open kernel module (GSP); behavior also verified against 580.178.04 sources
- Kernel: 6.6.y, Ubuntu 24.04 userland, CONFIG_PREEMPT_VOLUNTARY
- Workload: ~150 CUDA client processes per node (ray + vLLM inference, 21 processes per GPU, MPS dual instance)
Evidence comes from three hosts — two crashed, one live
- Host A and Host B: crashed (kdump captured). Both panicked with
softlockup: hung tasks(softlockup_panic=1), ~4 hours apart, same workload. - Host C: identical symptom, has NOT crashed. Same driver/workload, 6 GPU-vector
CPUs saturated at 70-97%. All bpftrace/perf numbers below were captured live on
Host C while degraded — they are measurements of the failure mode in progress,
not post-mortem reconstruction.
Crashed hosts: NMI backtraces (kdump)
At panic time, multiple CPUs (one per busy GPU) were spinning inside the GPU
interrupt handler on the event spinlock:
__raw_spin_lock_irqsave
os_acquire_spinlock [nvidia] <- spin_lock_irqsave, IRQs off
portSyncSpinlockAcquire [nvidia]
osDereferenceObjectCount [nvidia]
osNotifyEvent [nvidia]
_gpuEngineEventNotificationListNotify [nvidia]
gkflcnServiceNotificationInterrupt_IMPL [nvidia]
intrServiceNotificationRecords_IMPL [nvidia]
_intrServiceNonStallLeaf_TU102 [nvidia]
intrServiceNonStall_TU102 [nvidia]
osInterruptPending [nvidia]
osIsr [nvidia]
rm_isr [nvidia]
nvidia_isr [nvidia]
nvidia_isr_msix [nvidia]
handle_edge_irq / common_interrupt
On Host B, the thread that exceeded the 40s softlockup threshold was itself
executing an NVIDIA ioctl — i.e., both the CPU consumer (IRQ path above) and the
stalled victim are driver code paths:
watchdog: BUG: soft lockup - CPU#144 stuck for 44s! [ray::DashboardA:57169]
RIP: 0010:refHasAncestor+0x8/0x40 [nvidia]
? clientRefIterNext+0xd0/0x130 [nvidia]
_gpushareddataRequestDataPoll+0x8d/0x100 [nvidia] <- RUSD data poll,
resControl_IMPL+0x1a9/0x1b0 [nvidia] iterates ALL RM clients
serverControl+0x47e/0x590 [nvidia]
_rmapiRmControl+0x4f2/0x820 [nvidia]
rmapiControlWithSecInfo+0x79/0x140 [nvidia]
rmapiControlWithSecInfoTls+0x8f/0xf0 [nvidia]
_nv04ControlWithSecInfo+0x8d/0xa0 [nvidia]
RmIoctl+0x90b/0xda0 [nvidia]
rm_ioctl+0x66/0x4f0 [nvidia]
nvidia_unlocked_ioctl+0x4d3/0x9b0 [nvidia]
__x64_sys_ioctl / do_syscall_64
With the CPU ~94% consumed by interrupt servicing, this client-iteration loop
(no scheduling point) could not finish within 40s → watchdog → host panic.
(On Host A the starved victim was an xfs log-completion kworker instead; any
kernel path without a scheduling point on a saturated CPU triggers the same.)
kdump vmcores/dmesg of both crashed hosts available on request.
Live measurements on Host C (same symptom, pre-crash)
- nvidia interrupt rate: ~8.6k/s (healthy-node baseline ~10.7k/s — NOT an interrupt storm)
- Per-interrupt handler duration (tracepoint irq_handler_entry/exit): bimodal,
heavy population 2-4 ms per interrupt (healthy baseline: tens of us) - os_acquire_spinlock acquisitions per interrupt: bimodal, heavy population 512-2048
- Lock hold time: <1 us; lock wait: 4-16 us; ~540k lock acquisitions/sec machine-wide
- perf (99Hz, saturated CPUs): ~30% of samples in native_queued_spin_lock_slowpath,
call chains dominated by the nvidia_isr_msix → … → osNotifyEvent path above;
contending contexts include the hard-IRQ path, ksoftirqd, and user threads inside
nvidia ioctls (cuda-EvtHandlr, application threads).
Arithmetic cross-check: ~1000-2000 events notified per interrupt x ~2 global-lock
round-trips each (reference + dereference in the osNotifyEvent path) x 4-16 us
contention = 2-4 ms/interrupt, matching the duration histogram; summed ISR time
matches the 6 saturated CPUs.
Code references (public sources)
- src/nvidia/src/kernel/rmapi/event_notification.c, _gpuEngineEventNotificationListNotify
(L338-438 @ tag 580.95.05): per-entry notification loop - src/nvidia/arch/nvalloc/unix/src/os.c: referenceEventForPost / dereferenceEventForPost
acquire nv->event_spinlock per event - Note: 595.104.02 / 615.78.08 added a bDoRefCount parameter to osNotifyEvent that skips
the second acquisition — this halves the cost, but the O(N)-events-per-interrupt x
shared-spinlock structure remains, and the mitigation is NOT in the 580 production branch.
