[ 6.7442 ] 00000003: Could not initialize storage device [ 7.2088 ] [ 7.2116 ] tegradevflash --oem platformdetails storage storage_info.bin
logic@logic-dell:~/Desktop/Linux_for_Tegra$ sudo ./flash.sh -r -k APP -G backup.img jetson-nano-qspi-sd mmcblk0p1
[sudo] logic 的密码:
L4T BSP Information:
R32 , REVISION: 7.1
Target Board Information:
Name: jetson-nano-qspi-sd, Board Family: t210ref, SoC: Tegra 210,
OpMode: production, Boot Authentication: ,
Disk encryption: disabled ,
./tegraflash.py --chip 0x21 --applet “/home/logic/Desktop/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0015 ] Generating RCM messages
[ 0.0031 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/logic/Desktop/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0034 ] RCM 0 is saved as rcm_0.rcm
[ 0.0043 ] RCM 1 is saved as rcm_1.rcm
[ 0.0046 ] List of rcm files are saved in rcm_list.xml
[ 0.0046 ]
[ 0.0046 ] Signing RCM messages
[ 0.0060 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0063 ] Assuming zero filled SBK key
[ 0.0101 ]
[ 0.0101 ] Copying signature to RCM mesages
[ 0.0115 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0123 ]
[ 0.0123 ] Boot Rom communication
[ 0.0138 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0140 ] RCM version 0X210001
[ 1.8444 ] Boot Rom communication completed
[ 2.8528 ]
[ 2.8529 ] dump EEPROM info
[ 2.8558 ] tegrarcm --oem platformdetails eeprom /home/logic/Desktop/Linux_for_Tegra/bootloader/cvm.bin
[ 2.8571 ] Applet version 00.01.0000
[ 4.6499 ] Saved platform info in /home/logic/Desktop/Linux_for_Tegra/bootloader/cvm.bin
[ 4.7273 ]
[ 4.7301 ] tegrarcm --reboot recovery
[ 4.7309 ] Applet version 00.01.0000
[ 6.5300 ]
Board ID(3448) version(402)
copying bctfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/logic/Desktop/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Making Boot image… done.
Existing sosfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
copying wb0boot(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/logic/Desktop/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Existing tbcfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/logic/Desktop/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml… done.
copying flasher(/home/logic/Desktop/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Reading [APP] and storing to /home/logic/Desktop/Linux_for_Tegra/backup.img ***
./tegraflash.py --bl cboot.bin --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --chip 0x21 --applet nvtboot_recovery.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --cfg flash.xml --odmdata 0xa4000 --cmd “read APP /home/logic/Desktop/Linux_for_Tegra/backup.img”
version 1.0.0
[ 0.0030 ] Generating RCM messages
[ 0.0045 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0048 ] RCM 0 is saved as rcm_0.rcm
[ 0.0052 ] RCM 1 is saved as rcm_1.rcm
[ 0.0055 ] List of rcm files are saved in rcm_list.xml
[ 0.0055 ]
[ 0.0055 ] Signing RCM messages
[ 0.0070 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0072 ] Assuming zero filled SBK key
[ 0.0111 ]
[ 0.0111 ] Copying signature to RCM mesages
[ 0.0125 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0133 ]
[ 0.0133 ] Boot Rom communication
[ 0.0147 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0150 ] BR_CID: 0x32101001642c53090000000017060380
[ 0.9074 ] RCM version 0X210001
[ 1.8151 ] Boot Rom communication completed
[ 2.8232 ]
[ 2.8233 ] Parsing partition layout
[ 2.8259 ] tegraparser --pt flash.xml.tmp
[ 2.8291 ]
[ 2.8292 ] Creating list of images to be signed
[ 2.8320 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 2.8419 ]
[ 2.8420 ] Generating signatures
[ 2.8435 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.8438 ] Assuming zero filled SBK key
[ 2.8843 ]
[ 2.8844 ] Send BCT from Host
[ 2.8844 ] Generating br-bct
[ 2.8859 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 2.8893 ]
[ 2.8894 ] Updating boot device parameters
[ 2.8909 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 2.8912 ] Warning: No sdram params
[ 2.8913 ]
[ 2.8914 ] Updating bl info
[ 2.8928 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.8944 ]
[ 2.8944 ] Updating secondary storage information into bct
[ 2.8958 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.8963 ]
[ 2.8963 ] Updating Odmdata
[ 2.8977 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 2.8980 ] Warning: No sdram params
[ 2.8982 ]
[ 2.8983 ] Get Signed section of bct
[ 2.8997 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 2.9001 ]
[ 2.9001 ] Signing BCT
[ 2.9029 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 2.9032 ] Assuming zero filled SBK key
[ 2.9037 ]
[ 2.9037 ] Updating BCT with signature
[ 2.9051 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 2.9056 ]
[ 2.9056 ] Sending BCTs
[ 2.9070 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.9073 ] Applet version 00.01.0000
[ 4.7092 ] Sending bct
[ 4.7097 ] […] 100%
[ 4.9320 ]
[ 4.9321 ] Retrieving storage infomation
[ 4.9352 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 4.9367 ] Applet version 00.01.0000
[ 7.2088 ]
^[[A^[[A^[[B^[[B^[[B^[[B^[[B^[[B^CTraceback (most recent call last):
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2502, in tegraflash_get_storage_info
run_command(command)
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 206, in run_command
raise tegraflash_exception('Return value ’ + str(return_code) +
tegraflash_internal.tegraflash_exception: ‘Return value 3\nCommand tegrarcm --oem platformdetails storage storage_info.bin’
During handling of the above exception, another exception occurred:
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/./tegraflash.py”, line 1296, in
tegraflash_run_commands()
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/./tegraflash.py”, line 1155, in tegraflash_run_commands
interpreter.onecmd(command)
File “/usr/lib/python3.10/cmd.py”, line 217, in onecmd
return func(arg)
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/./tegraflash.py”, line 364, in do_read
tegraflash_read(exports, args[0], file_path)
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 440, in tegraflash_read
tegraflash_get_storage_info()
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 2506, in tegraflash_get_storage_info
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 202, in run_command
log = print_process(process, enable_print)
File “/home/logic/Desktop/Linux_for_Tegra/bootloader/tegraflash_internal.py”, line 161, in print_process
output = process.stdout.read(1)
KeyboardInterrupt
The terminal command output is stuck in this position
[ 7.2088 ]
My device is a jetson nano b01 development kit
sudo ./flash.sh -r -k APP -G backup.img jetson-nano-devkit mmcblk0p1
I also get the same result when I execute this command, stuck in the same position
Is it because nvidia does not officially support the image recovery function for this model device?because I want to make my own image with a specific program, and then I want to make a batch burn kit, using nvmassflashgen.sh. Then batch let the model device execute nvmflash.sh in recovery mode, and burn my own image. So now I’m stuck at this step and I can’t move on to the next step.
How do I accomplish this goal if I can’t back up the image with flash.sh?
Hi logiczym,
Are you sure that you are using the devkit from NVIDIA?
Or that might be the custom carrier board?
Can your board flash with the following command and boot up successfully?
$sudo ./flash.sh jetson-nano-devkit mmcblk0p1
Have you tried the latest R32.7.3?
Thanks for your reply, I confirmed that mine is nano devkit. I used the latest 7.3 burn image successfully sudo . /flash.sh jetson-nano-devkit mmcblk0p1
Then I also successfully entered the system and set the host name, then I want to backup the image, sudo . /flash.sh -r -k APP -G backup.img jetson-nano-devkit mmcblk0p1
logic@logic-dell:~/Desktop/32_7_3/Linux_for_Tegra$ sudo ./flash.sh -r -k APP -G backup.img jetson-nano-devkit mmcblk0p1
[sudo] logic 的密码:
R32 , REVISION: 7.3
Name: jetson-nano-devkit, Board Family: t210ref, SoC: Tegra 210,
./tegraflash.py --chip 0x21 --applet “/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin”
version 1.0.0
[ 0.0027 ] Generating RCM messages
[ 0.0043 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm /home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin 0 0
[ 0.0046 ] RCM 0 is saved as rcm_0.rcm
[ 0.0056 ] RCM 1 is saved as rcm_1.rcm
[ 0.0058 ] List of rcm files are saved in rcm_list.xml
[ 0.0058 ]
[ 0.0058 ] Signing RCM messages
[ 0.0073 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0076 ] Assuming zero filled SBK key
[ 0.0113 ]
[ 0.0113 ] Copying signature to RCM mesages
[ 0.0127 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0135 ]
[ 0.0136 ] Boot Rom communication
[ 0.0150 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0153 ] RCM version 0X210001
[ 1.5631 ] Boot Rom communication completed
[ 2.5705 ]
[ 2.5705 ] dump EEPROM info
[ 2.5721 ] tegrarcm --oem platformdetails eeprom /home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/cvm.bin
[ 2.5725 ] Applet version 00.01.0000
[ 4.0826 ] Saved platform info in /home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/cvm.bin
[ 4.1682 ]
[ 4.1712 ] tegrarcm --reboot recovery
[ 4.1725 ] Applet version 00.01.0000
[ 5.6758 ]
copying bctfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/BCT/P3448_A00_lpddr4_204Mhz_P987.cfg)… done.
copying bootloader(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying initrd(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
Existing sosfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)… done.
copying cpu_bootloader(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
copying bpffile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/sc7entry-firmware.bin)… done.
copying wb0boot(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)… done.
Existing tosfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/tos-mon-only.img) reused.
Existing eksfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
Existing tbcfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying tbcdtbfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/kernel/dtb/tegra210-p3448-0000-p3449-0000-b00.dtb)… done.
copying cfgfile(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/cfg/flash_l4t_t210_max-spi_sd_p3448.xml) to flash.xml… done.
copying flasher(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/t210ref/cboot.bin)… done.
Existing flashapp(/home/logic/Desktop/32_7_3/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Reading [APP] and storing to /home/logic/Desktop/32_7_3/Linux_for_Tegra/backup.img ***
./tegraflash.py --bl cboot.bin --bldtb kernel_tegra210-p3448-0000-p3449-0000-b00.dtb --chip 0x21 --applet nvtboot_recovery.bin --bct P3448_A00_lpddr4_204Mhz_P987.cfg --cfg flash.xml --odmdata 0xa4000 --cmd “read APP /home/logic/Desktop/32_7_3/Linux_for_Tegra/backup.img”
version 1.0.0
[ 0.0045 ] Generating RCM messages
[ 0.0060 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 0 --download rcm nvtboot_recovery.bin 0 0
[ 0.0064 ] RCM 0 is saved as rcm_0.rcm
[ 0.0068 ] RCM 1 is saved as rcm_1.rcm
[ 0.0071 ] List of rcm files are saved in rcm_list.xml
[ 0.0071 ]
[ 0.0071 ] Signing RCM messages
[ 0.0085 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0088 ] Assuming zero filled SBK key
[ 0.0142 ]
[ 0.0142 ] Copying signature to RCM mesages
[ 0.0157 ] tegrarcm --chip 0x21 0 --updatesig rcm_list_signed.xml
[ 0.0164 ]
[ 0.0164 ] Boot Rom communication
[ 0.0178 ] tegrarcm --chip 0x21 0 --rcm rcm_list_signed.xml
[ 0.0181 ] BR_CID: 0x32101001642c53090000000017060380
[ 0.5977 ] RCM version 0X210001
[ 1.4379 ] Boot Rom communication completed
[ 2.4454 ]
[ 2.4455 ] Parsing partition layout
[ 2.4481 ] tegraparser --pt flash.xml.tmp
[ 2.4505 ]
[ 2.4506 ] Creating list of images to be signed
[ 2.4531 ] tegrahost --chip 0x21 0 --partitionlayout flash.xml.bin --list images_list.xml
[ 2.4728 ]
[ 2.4728 ] Generating signatures
[ 2.4757 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 2.4771 ] Assuming zero filled SBK key
[ 2.5530 ]
[ 2.5530 ] Send BCT from Host
[ 2.5530 ] Generating br-bct
[ 2.5545 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.cfg --chip 0x21 0
[ 2.5578 ]
[ 2.5578 ] Updating boot device parameters
[ 2.5592 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatedevparam flash.xml.bin
[ 2.5594 ] Warning: No sdram params
[ 2.5596 ]
[ 2.5597 ] Updating bl info
[ 2.5610 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 2.5618 ]
[ 2.5618 ] Updating secondary storage information into bct
[ 2.5632 ] tegraparser --pt flash.xml.bin --chip 0x21 0 --updatecustinfo P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.5636 ]
[ 2.5636 ] Updating Odmdata
[ 2.5650 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatefields Odmdata =0xa4000
[ 2.5653 ] Warning: No sdram params
[ 2.5656 ]
[ 2.5656 ] Get Signed section of bct
[ 2.5670 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --listbct bct_list.xml
[ 2.5674 ]
[ 2.5674 ] Signing BCT
[ 2.5701 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 2.5704 ] Assuming zero filled SBK key
[ 2.5708 ]
[ 2.5708 ] Updating BCT with signature
[ 2.5722 ] tegrabct --bct P3448_A00_lpddr4_204Mhz_P987.bct --chip 0x21 0 --updatesig bct_list_signed.xml
[ 2.5762 ]
[ 2.5762 ] Sending BCTs
[ 2.5776 ] tegrarcm --download bct P3448_A00_lpddr4_204Mhz_P987.bct
[ 2.5779 ] Applet version 00.01.0000
[ 4.1053 ] Sending bct
[ 4.1058 ] […] 100%
[ 4.3282 ]
[ 4.3282 ] Retrieving storage infomation
[ 4.3302 ] tegrarcm --oem platformdetails storage storage_info.bin
[ 4.3346 ] Applet version 00.01.0000
[ 5.8240 ] 00000003: Could not initialize storage device
[ 6.2884 ]
[ 6.2915 ] tegradevflash --oem platformdetails storage storage_info.bin
Still stuck in the same position
Also I checked the README_Massflash.txt
Where actual values are.
BOARDID BOARDSKU FAB BOARDREV
jetson-agx-xavier-industrial 2888 0008 600 A.0
jetson-xavier-nx-devkit-tx2-nx 3636 0001 100 B.0
jetson-xavier-nx-devkit-emmc 3668 0001 100 N/A
jetson-nano-devkit-emmc 3448 0002 400 N/A
jetson-agx-xavier-devkit (16GB) 2888 0001 400 H.0
jetson-agx-xavier-devkit (32GB) 2888 0004 400 K.0
jetson-tx2-devkit 3310 1000 B02 N/A
jetson-tx2-devkit-tx2i 3489 0000 300 A.0
jetson-tx2-devkit-4gb 3489 0888 300 F.0
jetson-tx1-devkit 2180 0000 400 N/A
I don’t see the model number of the nano devkit, does that mean I can’t make a batch burn kit
Hi logiczym,
Sorry, I’ve confirmed that Jetson Nano SD cannot be cloned by flash.sh.
You can just put the sdcard to another host pc and use dd command to copy.
Thanks again for your reply, so I can’t make a batch burn kit with the nvmassflashgen.sh script either right? The hardware supports at least to nano emmc, right?
Yes, clone command of flash script is used for internal eMMC of Jetson Nano-eMMC which is also production module. For SD card, please just use dd command to copy it.
