1. Linux kernel recently dropped the strlcpy function
Compilation Error
/home/ubuntu/mellanox/mlnx-en-5.8-5.1.1.2-ubuntu22.04-x86_64/src/MLNX_EN_SRC-5.8-5.1.1.2/SOURCES/mlnx-en-5.8/drivers/net/ethernet/mellanox/mlx5/core/en_ethtool.c:46.o:9: error: implicit declaration of function ‘strlcpy’; did you mean ‘strscpy’? [-Werror=implicit-function-declaration] htool.o
46 | strlcpy(drvinfo->driver, KBUILD_MODNAME, sizeof(drvinfo->driver)); n function ‘mlx5e_ethtool_get_drvinfo’:
| ^~~~~~~ :9: error: implicit declaration of function ‘strlcpy’; did you mean ‘s
| strscpy
Fix for this is to replace strlcpy with strscpy
Reference: Making sure you're not a bot!
2. uuid_le was was moved to MEI namespace in the newer kernels
Compilation Error
/var/lib/dkms/mlnx-en/5.8/build/include/linux/mod_devicetable.h:725:9: error: unknown type name 'uuid_le'
725 | uuid_le uuid;
include/linux/uuid.h used to import “uapi/linux/uuid.h” which had uuid_le definition in the previous releases.
- 5.15 Kernel: git.launchpad .net/~ubuntu-kernel/ubuntu/+source/linux/+git/jammy/tree/include/linux/uuid.h?h=Ubuntu-5.15.0-125.135
- 6.8 Kernel: git.launchpad .net/~ubuntu-kernel/ubuntu/+source/linux/+git/noble/tree/include/linux/uuid.h?h=Ubuntu-6.8.0-38.38
Fix for now is to simply import uapi/linux/uuid.h in places uuid_le is required
Reference:
3. xdp_do_flush_map was removed
Compilation Error
/home/ubuntu/mellanox/mlnx-en-5.8-5.1.1.2-ubuntu22.04-x86_64/src/MLNX_EN_SRC-5.8-5.1.1.2/SOURCES/mlnx-en-5.8/drivers/net/ethernet/mellanox/mlx5/core/en/xdp.c:630:17: error
: implicit declaration of function ‘xdp_do_flush_map’; did you mean ‘xdp_do_flush’? [-Werror=implicit-function-declaration]
630 | xdp_do_flush_map();
| xdp_do_flush
Fix is to use xdp_do_flush
Reference:
Is there plan for OFED 5.8 to have these changes to support the 6.8 kernel any time in the future?
