i’m using ubuntu18.04
and device is connectX-4 Lx
uname -r is 4.15.0-20-generic
i used sudo ./mlnxofedinstall --with-nfsrdma --with-nvmf --enable-gds --add-kernel-support
the result is
ERROR: Failed executing “MLNX_OFED_SRC-5.2-2.2.0.0/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.22959_logs --kernel-only --kernel 4.15.0-20-generic --kernel-sources /lib/modules/4.15.0-20-generic/build --builddir /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.22959 --without-dkms --without-debug-symbols --enable-gds --build-only --distro ubuntu18.04”
ERROR: See /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.22959_logs/mlnx_ofed_iso.22959.log
Failed to build MLNX_OFED_LINUX for 4.15.0-20-generic
and fail log like this
n file included from include/linux/printk.h:350:0,
from /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/include/linux/printk.h:7,
from include/linux/kernel.h:14,
from /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/include/linux/kernel.h:6,
from include/linux/uio.h:12,
from include/linux/socket.h:8,
from /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/include/linux/socket.h:4,
from ./include/uapi/linux/if.h:25,
from /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/include/linux/compat-2.6.h:11,
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/verbs.c:1267:14: error: ‘struct rpcrdma_xprt’ has no member named ‘rx_ia’; did you mean ‘rx_ep’?
r_xprt->rx_ia.ri_id->device->name, mr->mr_sg, mr->mr_nents);
include/linux/dynamic_debug.h:128:10: note: in definition of macro ‘dynamic_pr_debug’
##VA_ARGS); \
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/verbs.c:1266:4: note: in expansion of macro ‘pr_debug’
pr_debug(“rpcrdma_nvfs_unmap_data device %s mr->mr_sg: %p , nents: %d\n”,
LD [M] /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/drivers/infiniband/hw/mlx4/mlx4_ib.o
CC [M] /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/drivers/infiniband/ulp/iser/iscsi_iser.o
scripts/Makefile.build:332: recipe for target ‘/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/verbs.o’ failed
make[5]: *** [/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/verbs.o] Error 1
make[5]: *** Waiting for unfinished jobs…
CC [M] /tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/drivers/infiniband/hw/mlx5/cmd.o
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c: In function ‘frwr_mr_recycle’:
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c:91:39: error: ‘struct rpcrdma_xprt’ has no member named ‘rx_ia’; did you mean ‘rx_ep’?
if (rpcrdma_nvfs_unmap_data(r_xprt->rx_ia.ri_id->device->dma_device,
rx_ep
In file included from include/linux/printk.h:350:0,
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c:94:14: error: ‘struct rpcrdma_xprt’ has no member named ‘rx_ia’; did you mean ‘rx_ep’?
##VA_ARGS); \
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c:93:4: note: in expansion of macro ‘pr_debug’
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c: In function ‘frwr_map’:
/tmp/MLNX_OFED_LINUX-5.2-2.2.0.0-4.15.0-20-generic/mlnx_iso.60350/mlnx-ofed-kernel/mlnx-ofed-kernel-5.2/net/sunrpc/xprtrdma/frwr_ops.c:341:36: error: ‘ia’ undeclared (first use in this function); did you mean ‘i’?
dma_nents = rpcrdma_nvfs_map_data(ia->ri_id->device->dma_device,
i
what should i do…?
mlnx-ofed-kernel.debbuild.log (453 KB)
