I failed to build MLNX_OFED_LINUX for 5.4.0-70-generic.
I tried to install MLNX_OFED on two machines, one with ubuntu 20.04.01 and Kernel 5.4.0-66-generic x86_64, the other with ubuntu 20.04.01 and Kernel 5.4.0-70-generic x86_64. I succeeded on the first one but failed the second.
Details:
$ sudo ./mlnxofedinstall --without-dkms --add-kernel-support --with-nvmf --force --without-fw-update
Note: This program will create MLNX_OFED_LINUX TGZ for ubuntu20.04 under /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic directory.
See log file /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.55884_logs/mlnx_ofed_iso.55884.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX DEBS . Please wait…
ERROR: Failed executing “MLNX_OFED_SRC-5.3-1.0.0.1/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.55884_logs --kernel-only --kernel 5.4.0-70-generic --kernel-sources /lib/modules/5.4.0-70-generic/build --builddir /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.55884 --without-dkms --force --without-debug-symbols --build-only --distro ubuntu20.04”
ERROR: See /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.55884_logs/mlnx_ofed_iso.55884.log
Failed to build MLNX_OFED_LINUX for 5.4.0-70-generic
And the log:
Logs dir: /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.51899_logs/OFED.52096.logs
General log file: /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.51899_logs/OFED.52096.logs/general.log
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
ofed-scripts
mlnx-ofed-kernel-utils
mlnx-ofed-kernel-modules
iser-modules
isert-modules
srp-modules
mlnx-nfsrdma-modules
mlnx-nvme-modules
kernel-mft-modules
knem-modules
Checking SW Requirements…
One or more required packages for installing OFED-internal are missing.
Attempting to install the following missing packages:
build-essential python3-distutils make pkg-config debhelper dh-autoreconf bzip2 quilt gcc
This program will install the OFED package on your machine.
Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
Those packages are removed due to conflicts with OFED, do not reinstall them.
Installing new packages
Building DEB for ofed-scripts-5.3 (ofed-scripts)…
Running /usr/bin/dpkg-buildpackage -us -uc
Building DEB for mlnx-ofed-kernel-utils-5.3 (mlnx-ofed-kernel)…
-W- --with-mlx5-ipsec is enabled
Failed to build mlnx-ofed-kernel DEB
Collecting debug info…
See /tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-5.4.0-70-generic/mlnx_iso.51899_logs/OFED.52096.logs/mlnx-ofed-kernel.debbuild.log
Is there any possibility that MLNX_OFED_LINUX-5.3-1.0.0.1 is not compatible with kernel 5.4.0-70-generic?
Please help!
Hello Jin,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, we are not able to reproduce the issue in our lab.
MLNX_OFED driver 5.3 install successfully on kernel 5.4.0-70
As you are running Ubuntu 20.04, recommended is to make use of DKMS which is enabled by default in the OS.
Our install log with the syntax used to install the driver:
# ./mlnxofedinstall -vvv --with-nvmf --force --without-fw-update
Distro was not provided, trying to auto-detect the current distro…
Auto-detected ubuntu20.04 distro.
set_cfg: name: ar-mgr, version: 1.0, debpath: /var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64/DEBS/ar-mgr_1.0-5.8.2.MLNX20210321.g58d33bf.53100_amd64.deb
Logs dir: /tmp/MLNX_OFED_LINUX.10284.logs
General log file: /tmp/MLNX_OFED_LINUX.10284.logs/general.log
Below is the list of MLNX_OFED_LINUX packages that you have chosen
ofed-scripts
mlnx-ofed-kernel-dkms
iser-dkms
isert-dkms
srp-dkms
mlnx-nvme-dkms
rdma-core
libibverbs1
ibverbs-utils
ibverbs-providers
libibverbs-dev
libibverbs1-dbg
libibumad3
libibumad-dev
ibacm
librdmacm1
rdmacm-utils
librdmacm-dev
mstflint
ibdump
libibmad5
libibmad-dev
libopensm
opensm
opensm-doc
libopensm-devel
libibnetdisc5
infiniband-diags
mft
kernel-mft-dkms
perftest
ibutils2
ar-mgr
dump-pr
ibsim
ibsim-doc
ucx
sharp
hcoll
knem-dkms
knem
openmpi
mpitests
libdapl2
dapl2-utils
libdapl-dev
dpcp
srptools
mlnx-ethtool
mlnx-iproute2
rshim
This program will install the MLNX_OFED_LINUX package on your machine.
Those packages are removed due to conflicts with MLNX_OFED_LINUX, do not reinstall them.
Running /usr/bin/dpkg -i --force-confmiss /var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64/DEBS/rshim_2.0.5-10.g0ae03b4.53100_amd64.deb
Running: FW_UPDATE_FLAGS=‘–log /tmp/MLNX_OFED_LINUX.10284.logs/fw_update.log -v --tmpdir /tmp’ RUN_FW_UPDATER=‘no’ /usr/bin/dpkg -i /var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64/DEBS/mlnx-fw-updater_5.3-1.0.0.1_amd64.deb
Selecting previously unselected package mlnx-fw-updater.
(Reading database … 118653 files and directories currently installed.)
Preparing to unpack …/mlnx-fw-updater_5.3-1.0.0.1_amd64.deb …
Unpacking mlnx-fw-updater (5.3-1.0.0.1) …
Setting up mlnx-fw-updater (5.3-1.0.0.1) …
Added 'RUN_FW_UPDATER_ONBOOT=no to /etc/infiniband/openib.conf
Skipping FW update.
Running: /usr/bin/dpkg-deb -x /var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64/DEBS/mlnx-ofed-kernel-dkms_5.3-OFED.5.3.1.0.0.1_all.deb /var/tmp/mlnx-ofed-kernel_module-check 2>/dev/null
is_module_in_deb: ipoib is in /var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64/DEBS/mlnx-ofed-kernel-dkms_5.3-OFED.5.3.1.0.0.1_all.deb
Installation passed successfully
To load the new driver, run:
/etc/init.d/openibd restart
Note: In order to load the new nvme-rdma and nvmet-rdma modules, the nvme module must be reloaded.
root@lx-u200401:/var/tmp/MLNX_OFED_LINUX-5.3-1.0.0.1-ubuntu20.04-x86_64#
Thank you and regards,
~NVIDIA Networking Technical Support
Hi Martijn! Thank you so much for your reply! I tried again and still failed and below is my detailed log. Please help me.
And here is log of make.
I’ve installed the lsb-core as the above file pointed, but now the mlnx-ofed-kernel-dkms still cannot be installed.
Thank you. It turns out that someone in my group changed gcc to another edition, after changing it back to the original one, OFED is now installed. ​
