I recently built up a linux server with Ubuntu 14.04.2 server and MCX353A-FCBT.
Actually, I tested this with Ubuntu 14.04.01 version with no problem installing MLNX_OFED_LINUX-2.4-1.0.0-ubuntu14.04-x86_64.
However, I cannnot install the driver after OS is newly installed with upgraded version (14.04.2).
Would anyone let me have a clue to find the problem?
Please refer to the following for some messages.
stdout
Installing ofed-scripts-2.4…
Installing mlnx-ofed-kernel-utils-2.4…
Installing mlnx-ofed-kernel-dkms-2.4…
Error: mlnx-ofed-kernel-dkms installation failed!
Collecting debug info…
See:
/tmp/OFED.42892.logs/mlnx-ofed-kernel-dkms.debinstall.log
/tmp/OFED.42892.logs/mlnx-ofed-kernel-dkms.make.log
Removing newly installed packages…
CC [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_send.o
CC [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/net/ethernet/mellanox/mlx4/en_sysfs.o
CC [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_stats.o
CC [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ucma.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/net/ethernet/mellanox/mlx5/core/mlx5_core.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/net/eipoib/eth_ipoib.o
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_recv.c: In function ‘rds_tcp_data_ready’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_recv.c:356:9: warning: assignment from incompatible pointer type [enabled by default]
ready = sk->sk_data_ready;
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_listen.c: In function ‘rds_tcp_listen_data_ready’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_listen.c:129:9: warning: assignment from incompatible pointer type [enabled by default]
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_listen.c: In function ‘rds_tcp_listen_init’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp_listen.c:162:26: warning: assignment from incompatible pointer type [enabled by default]
sock->sk->sk_data_ready = rds_tcp_listen_data_ready;
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp.c: In function ‘rds_tcp_set_callbacks’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp.c:135:30: warning: comparison of distinct pointer types lacks a cast [enabled by default]
if (sock->sk->sk_data_ready == rds_tcp_listen_data_ready)
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/tcp.c:145:26: warning: assignment from incompatible pointer type [enabled by default]
sock->sk->sk_data_ready = rds_tcp_data_ready;
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/ib.c: In function ‘rds_ib_ip_excl_ips_init’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/ib.c:1360:1: warning: the frame size of 1056 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/ib.c: In function ‘rds_ib_ip_failover_groups_init’:
/var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/ib.c:1425:1: warning: the frame size of 1064 bytes is larger than 1024 bytes [-Wframe-larger-than=]
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/hw/mlx5/mlx5_ib.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/rds.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/rds_rdma.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/net/rds/rds_tcp.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/ulp/ipoib/ib_ipoib.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/hw/mlx4/mlx4_ib.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/net/ethernet/mellanox/mlx4/mlx4_core.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/net/ethernet/mellanox/mlx4/mlx4_en.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_core.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_mad.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_sa.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_cm.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/iw_cm.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_addr.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/rdma_cm.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_umad.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_uverbs.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/ib_ucm.o
LD [M] /var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband/core/rdma_ucm.o
make[2]: *** [/var/lib/dkms/mlnx-ofed-kernel/2.4/build/drivers/infiniband] Error 2
make[1]: *** [module/var/lib/dkms/mlnx-ofed-kernel/2.4/build] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.16.0-31-generic’
make: *** [kernel] Error 2
Thank you in advance!
