I am running linux mint 19 which is basically ubuntu 18.04. I recently bought a ConnectX-3 CX311A and am trying to get it running.
I downloaded the MLNX_OFED_LINUX-4.4-1.0.0.0-ubuntu18.04-x86_64 and tried to run it:
sudo ./mlnxofedinstall --add-kernel-support --distro ubuntu18.04
Result:
Note: This program will create MLNX_OFED_LINUX TGZ for ubuntu18.04 under /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic directory.
See log file /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496_logs/mlnx_ofed_iso.5496.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX RPMS . Please wait…
find: ‘MLNX_OFED_SRC-4.4-1.0.0.0/RPMS’: No such file or directory
Creating metadata-rpms for 4.15.0-29-generic …
ERROR: Failed executing “/usr/bin/perl /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496/MLNX_OFED_LINUX-4.4-1.0.0.0-ubuntu18.04-ext/create_mlnx_ofed_installers.pl --with-hpc --tmpdir /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496_logs --mofed /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496/MLNX_OFED_LINUX-4.4-1.0.0.0-ubuntu18.04-ext --rpms-tdir /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496/MLNX_OFED_LINUX-4.4-1.0.0.0-ubuntu18.04-ext/RPMS --output /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496/MLNX_OFED_LINUX-4.4-1.0.0.0-ubuntu18.04-ext --kernel 4.15.0-29-generic --ignore-groups eth-only”
ERROR: See /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496_logs/mlnx_ofed_iso.5496.log
Failed to build MLNX_OFED_LINUX for 4.15.0-29-generic
Once I check this log it says:
[33mUnsupported package: kmp [0m
Logs dir: /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496_logs/OFED.5926.logs
General log file: /tmp/MLNX_OFED_LINUX-4.4-1.0.0.0-4.15.0-29-generic/mlnx_iso.5496_logs/OFED.5926.logs/general.log
[32m
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
[0m
ofed-scripts
mlnx-ofed-kernel-utils
mlnx-ofed-kernel-dkms
iser-dkms
isert-dkms
srp-dkms
mlnx-nfsrdma-dkms
mlnx-nvme-dkms
mlnx-rdma-rxe-dkms
kernel-mft-dkms
knem-dkms
knem
Checking SW Requirements…
This program will install the OFED package on your machine.
Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
Those packages are removed due to conflicts with OFED, do not reinstall them.
Installing new packages
Building DEB for ofed-scripts-4.4 (ofed-scripts)…
Running /usr/bin/dpkg-buildpackage -us -uc
Building DEB for mlnx-ofed-kernel-utils-4.4 (mlnx-ofed-kernel)…
Building DEB for iser-dkms-4.0 (iser)…
Building DEB for isert-dkms-4.0 (isert)…
Building DEB for srp-dkms-4.0 (srp)…
Building DEB for mlnx-nfsrdma-dkms-3.4 (mlnx-nfsrdma)…
Building DEB for mlnx-nvme-dkms-4.0 (mlnx-nvme)…
Building DEB for mlnx-rdma-rxe-dkms-4.0 (mlnx-rdma-rxe)…
Building DEB for kernel-mft-dkms-4.10.0 (kernel-mft)…
Building DEB for knem-dkms-1.1.3.90mlnx1 (knem)…
[32mBuild passed successfully [0m
-E- ‘’ dir does not exist!
Strange!
Then I tried
sudo ./mlnxofedinstall --distro ubuntu18.04
which gives:
Logs dir: /tmp/MLNX_OFED_LINUX.12121.logs
General log file: /tmp/MLNX_OFED_LINUX.12121.logs/general.log
Below is the list of MLNX_OFED_LINUX packages that you have chosen
ofed-scripts
iser-dkms
isert-dkms
srp-dkms
mlnx-nfsrdma-dkms
mlnx-rdma-rxe-dkms
libibverbs1
ibverbs-utils
libibverbs-dev
libibverbs1-dbg
libmlx4-1
libmlx4-dev
libmlx4-1-dbg
libmlx5-1
libmlx5-dev
libmlx5-1-dbg
librxe-1
librxe-dev
librxe-1-dbg
libibumad
libibumad-static
libibumad-devel
ibacm
ibacm-dev
librdmacm1
librdmacm-utils
librdmacm-dev
mstflint
ibdump
libibmad
libibmad-static
libibmad-devel
libopensm
opensm
opensm-doc
libopensm-devel
infiniband-diags
infiniband-diags-compat
mft
kernel-mft-dkms
libibcm1
libibcm-dev
perftest
ibutils2
libibdm1
cc-mgr
ar-mgr
dump-pr
ibsim
ibsim-doc
knem-dkms
mxm
ucx
sharp
hcoll
openmpi
mpitests
knem
libdapl2
dapl2-utils
libdapl-dev
srptools
mlnx-ethtool
mlnx-iproute2
This program will install the MLNX_OFED_LINUX package on your machine.
Those packages are removed due to conflicts with MLNX_OFED_LINUX, do not reinstall them.
Do you want to continue?[y/N]:y
Removing old packages…
Installing ofed-scripts-4.4…
Installing mlnx-ofed-kernel-utils-4.4…
Installing mlnx-ofed-kernel-dkms-4.4…
Error: mlnx-ofed-kernel-dkms installation failed!
Collecting debug info…
See:
/tmp/MLNX_OFED_LINUX.12121.logs/mlnx-ofed-kernel-dkms.debinstall.log
Removing newly installed packages…
How can I install the drivers? Thank you for your help
