MLNX_OFED 4.7-1.0.0.1 Installation failed on Ubuntu 18.04 ARM platform
Downloaded the MLNX_OFED V4.7-1.0.0.1 to ARM platform.
MLNX_OFED_LINUX-4.7-1.0.0.1-ubuntu18.04-aarch64.tgz
My platform OS:
​uname -a:
5.0.0-31-generic #33~18.04.1-Ubuntu SMP Tue Oct 1 10:19:33 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
When install the OFED drivers to the platform, report failures.
./mlnxofedinstall --upstream-libs --add-kernel-support --without-fw-update --force
message below.
Creating deb for: mlnx-ofed-hypervisor-user-only
Built mlnx-ofed-hypervisor-user-only deb
Error: no packages files were found in ‘/tmp/MLNX_OFED_LINUX-4.7-1.0.0.1-5.0.0-31-generic/mlnx_iso.8983/MLNX_OFED_LINUX-4.7-1.0.0.1-ubuntu18.04-ext/DEBS/MLNX_LIBS’ directory!
I followed the steps from below. how to fix the issues?
https://docs.mellanox.com/display/MLNXOFEDv471001/Installation
Please note that the OFED 4.6 installation is successful.
Thanks,
Jerry
Hello Jerry,
Thank you for posting your question on the Mellanox Community.
On a local setup I made a ubuntu machine with the same specifications as your machine and installed the Mellanox MLNX_OFED as shown bellow:
# ./mlnxofedinstall --upstream-libs --without-fw-update --force
Logs dir: /tmp/MLNX_OFED_LINUX.32432.logs
General log file: /tmp/MLNX_OFED_LINUX.32432.logs/general.log
Below is the list of MLNX_OFED_LINUX packages that you have chosen
(some may have been added by the installer due to package dependencies):
ofed-scripts
Skipping FW update.
Installation passed successfully
To load the new driver, run:
# /etc/init.d/openibd restart
As you are using Ubuntu there is no need for --add-kernel-support option as the Dynamic Kernel Module Support (DKMS) handles these functions.
You also need to have the proper kernel headers and modules install which can be done with
apt-get install linux-image-5.0.0-31-generic linux-headers-5.0.0-31-generic
Mellanox OFED requires certain packages which can be installed with
apt-get install perl dpkg autotools-dev autoconf libtool automake m4 dkms debhelper tcl tcl8.5 chrpath swig graphviz tcl-dev tcl8.5-dev tk-dev tk8.5-dev bison flex dpatch zlib1g-dev curl libcurl4-gnutls-dev python-libxml2 libvirt-bin libvirt0 libnl-3-dev libglib2.0-dev libgfortran3 automake m4 pkg-config libnuma-dev logrotate ethtool lsof libnl-route-3-dev
You can read more at https://docs.mellanox.com/display/MLNXOFEDv471001/General+Support+in+MLNX_OFED
under the Hardware and Software Requirements section.
If you need any further assistance, please do not hesitate to open a Mellanox Technical Support Ticket, by sending an email to support@mellanox.com
Kind Regards,
~Mellanox Technical Support.
Hi, Abigail
Thanks a lot for your prompt support!
With your instructions, I could install the OFED 4.7 to my platform without errors now.
And the installation for Kernel 4.15 works fine.
Jerry
