I failed to install MLNX_OFED on Ubuntu 18.04 but all prerequisite packages were installed
Below are further informations
Env:
#uname -a
Linux r740 4.15.0 #1 SMP Fri Oct 11 02:32:49 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
the output of terminal:
./mlnxofedinstall --add-kernel-support
Note: This program will create MLNX_OFED_LINUX TGZ for ubuntu18.04 under /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0 directory.
See log file /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs/mlnx_ofed_iso.61958.log
Checking if all needed packages are installed…
Building MLNX_OFED_LINUX DEBS . Please wait…
ERROR: Failed executing “MLNX_OFED_SRC-5.0-2.1.8.0/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs --kernel-only --kernel 4.15.0 --kernel-sources /lib/modules/4.15.0/build --builddir /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958 --without-dkms --without-debug-symbols --build-only --distro ubuntu18.04”
ERROR: See /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs/mlnx_ofed_iso.61958.log
Failed to build MLNX_OFED_LINUX for 4.15.0
And the output in mlnx_ofed_iso.61958.log:
Logs dir: /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs/OFED.62161.logs
General log file: /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs/OFED.62161.logs/general.log
[32m
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
[0m
ofed-scripts
mlnx-ofed-kernel-utils
mlnx-ofed-kernel-modules
rshim-modules
iser-modules
isert-modules
srp-modules
mlnx-nvme-modules
mlnx-rdma-rxe-modules
kernel-mft-modules
knem-modules
Checking SW Requirements…
[31mOne or more required packages for installing OFED-internal are missing.[0m
[31mAttempting to install the following missing packages:
make build-essential quilt dh-autoreconf debhelper bzip2 pkg-config gcc[0m
This program will install the OFED package on your machine.
Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
Those packages are removed due to conflicts with OFED, do not reinstall them.
Installing new packages
Building DEB for ofed-scripts-5.0 (ofed-scripts)…
Running /usr/bin/dpkg-buildpackage -us -uc
Building DEB for mlnx-ofed-kernel-utils-5.0 (mlnx-ofed-kernel)…
-W- --with-mlx5-ipsec is enabled
[31mFailed to build mlnx-ofed-kernel DEB[0m
Collecting debug info…
[31mSee /tmp/MLNX_OFED_LINUX-5.0-2.1.8.0-4.15.0/mlnx_iso.61958_logs/OFED.62161.logs/mlnx-ofed-kernel.debbuild.log[0m
And message from mlnx-ofed-kernel.debbuild.log is attached below
Thanks for your help😁
mlnx-ofed-kernel.debbuild.log (609 KB)
