This program will install the MLNX_OFED_LINUX package on your machine.
Note that all other Mellanox, OEM, OFED, RDMA or Distribution IB packages will be removed.
Those packages are removed due to conflicts with MLNX_OFED_LINUX, do not reinstall them.
Do you want to continue?[y/N]:y
Checking SW Requirements…
Removing old packages…
Installing new packages
Installing ofed-scripts-4.6…
Installing mlnx-ofed-kernel-utils-4.6…
Installing mlnx-ofed-kernel-dkms-4.6…
Error: mlnx-ofed-kernel-dkms installation failed!
Collecting debug info…
See:
/tmp/MLNX_OFED_LINUX.19892.logs/mlnx-ofed-kernel-dkms.debinstall.log
/tmp/MLNX_OFED_LINUX.19892.logs/mlnx-ofed-kernel-dkms.make.log
Removing newly installed packages…
Try to review log files:
spruitt
3
Hi Jenny,
In add on and also documented in our UM 3.3.2 Installation Procedure.
MLNX_OFED for Ubuntu should be installed with the following flags in chroot environment:
./mlnxofedinstall --without-dkms --add-kernel-support --kernel --without-fw-update –
force
For example:
./mlnxofedinstall --without-dkms --add-kernel-support --kernel 3.13.0-85-generic --without-fw-update --force
Note that the path to kernel sources (–kernel-sources) should be added if the sources are not in their default location.
Sophie.
Hi Sophie,
Thank you very much for your reply. Your information is really helpful and I have solved this issue by using your instruction.
Best regards,
Jenny
