Hi All, We are trying to install Mellanox and getting “mlnx-ofed-kernel installation failed!” issue. Need your support to resolve the issue.
Followed below steps:
Install the libverbs library using the below command. apt-get install ibverbs-utils
Download the latest Mellanox OFED/EN as below. The version in the example may vary. This can be found from the Mellanox site
- Install the above package using the below command in the base directory of the package.
./mlnxofedinstall --upstream-libs --dpdk
Error: mlnx-ofed-kernel-dkms installation failed!
Collecting debug info…
See:
/tmp/MLNX_OFED_LINUX.26945.logs/mlnx-ofed-kernel-dkms.debinstall.log
/tmp/MLNX_OFED_LINUX.26945.logs/mlnx-ofed-kernel-dkms.make.log
Removing newly installed packages…
Note: Please find the hardware details:
Model no: CX516A
HCA---->ConnectX®-5/ConnectX®-5 Ex (50GbE)
mlnx-ofed-kernel-dkms.make.log (82.3 KB)
