Failed to install mlnx-ofed-kernel-dkms DEB with Version 5.8-3.0.7.0
I am trying to install MLNX_OFED_LINUX-5.8-3.0.7.0-ubuntu22.04-x86_64. My MLNX card on the machine should support this version.
However, once I get to the mlnx-ofed-kernel-dkms driver install it fails.
Attached are the log files. some help would be greatly appreciated.
Unloading HCA driver: [ OK ]
Module mlx5_ib does not belong to MLNX_OFED, skipping… [FAILED]
Module mlx5_core does not belong to MLNX_OFED, skipping… [FAILED]
Module ib_umad does not belong to MLNX_OFED, skipping… [FAILED]
Module ib_uverbs does not belong to MLNX_OFED, skipping… [FAILED]
Module ib_ipoib does not belong to MLNX_OFED, skipping… [FAILED]
Loading HCA driver and Access Layer: [ OK ]
Module rdma_cm does not belong to MLNX_OFED, skipping… [FAILED]
Module rdma_ucm does not belong to MLNX_OFED, skipping… [FAILED]
All tasks completed successfully.
mlnx-ofed-kernel.debbuild.log (608.5 KB)
Downgraded to 20.04 and the issue has been fixed.
Were there several kernel in the system? That might get such error.
With ubuntu 22.04, did you try to reinstall OFED 5.8-3.0.7.0 ?
Anyway, good to hear that you have solved the issue.
Regards,
Levei
Hey, I did try to use OFED 5.8-3.0.7.0 on 22.04 but I was given error above.
Do you know why this error happened anyway?
