Hi, I have a cluster with two nodes with the name mic01 and mic03, which are installed Redhat 6.3, and mic01 mounted from mic03. I install the MLNX_OFED driver MLNX_OFED_LINUX-2.4-1.0.4-rhel6.3-x86_64.iso in mic03 with the command from user manual:
mount -o ro,loop MLNX_OFED_LINUX-2.4-1.0.4-rhel6.3-x86_64.iso /mnt
and then ./mlnxofedinstall in /mnt. The driver is successfully installed in mic03(the ib status is active).
However when I install MLNX_OFED in mic01 with the same method above, it shows the information after ./mlnxofedinstall:
Starting MLNX_OFED_LINUX-2.4-1.0.4 installation …
Installing mlnx-ofa_kernel RPM
Preparing… ##################################################
mlnx-ofa_kernel ##################################################
Installing kmod-mlnx-ofa_kernel 2.4 RPM
kmod-mlnx-ofa_kernel ##################################################
Installing mlnx-ofa_kernel-devel RPM
mlnx-ofa_kernel-devel ##################################################
Installing kmod-kernel-mft-mlnx 3.8.0 RPM
kmod-kernel-mft-mlnx ##################################################
Installing knem-mlnx RPM
Failed to install knem-mlnx 1.1.1.90mlnx RPM
Collecting debug info…
See /tmp/MLNX_OFED_LINUX-2.4-1.0.4.13023.logs/knem-mlnx-1.1.1.90mlnx.rpminstall.err.log
And it failed to install knem-mlnx 1.1.1.90mlnx RPM. In the log, it shows the error:
error: unpacking of archive failed on file /opt/knem-1.1.1.90mlnx: cpio: chown failed - Inappropriate ioctl for device
Where did I have a mistake? Can anyone help me with the problem?
I will appreciate it if you help me with this Thank you!
