oskar8
December 30, 2016, 5:51pm
#1
I get an error when I try to install MLNX OFED for RHEL 7.3 Real time kernel.
For normal kernel RHEL 7.3 I can install OFED without any problems. What can be the problem? Btw. I installed kernel-devel and added –add-kernel-support but I got below ERROR after installation:
ERROR: Failed executing “MLNX_OFED_SRC-3.4-2.0.0.0/install.pl --tmpdir /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64 --kernel-only --kernel 3.10.0-514.2.2.rt56.424.el7.x86_64 --kernel-sources /lib/modules/3.10.0-514.2.2.rt56.424.el7.x86_64/build --builddir /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_iso.21610 --disable-kmp --force --build-only --distro rhel7.3”
ERROR: See /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_ofed_iso.21610.log
Failed to build MLNX_OFED_LINUX for 3.10.0-514.2.2.rt56.424.el7.x86_64
I have Mellanox Connectx-3 VPI
Hi Oskar,
We need the contents of /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/OFED.29661.logs/mlnx-ofa_kernel-3.4.rpmbuild.log
Thanks and regards,
~Martijn
oskar8
January 9, 2017, 2:42pm
#3
Probably I deleted tjis log but below is different log with for the same error:
Logs dir: /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/OFED.29661.logs
[32m
Below is the list of OFED packages that you have chosen
(some may have been added by the installer due to package dependencies):
[0m
ofed-scripts
mlnx-ofa_kernel
mlnx-ofa_kernel-modules
mlnx-ofa_kernel-devel
knem
kernel-mft
iser
srp
isert
mlnx-sdp
mlnx-rds
Build ofed-scripts 3.4 RPM
Running rpmbuild --rebuild --define ‘_topdir /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_iso.29365/OFED_topdir’ --define ‘_sourcedir %{_topdir}/SOURCES’ --define ‘_specdir %{_topdir}/SPECS’ --define ‘_srcrpmdir %{_topdir}/SRPMS’ --define ‘_rpmdir %{_topdir}/RPMS’ --define ‘dist %{nil}’ --target x86_64 --define ‘_prefix /usr’ --define ‘_exec_prefix /usr’ --define ‘_sysconfdir /etc’ --define ‘_usr /usr’ /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_iso.29365/MLNX_OFED_SRC-3.4-2.0.0.0/SRPMS/ofed-scripts-3.4-OFED.3.4.2.0.0.src.rpm
Build mlnx-ofa_kernel 3.4 RPM
Running rpmbuild --rebuild --define ‘_topdir /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_iso.29365/OFED_topdir’ --define ‘_sourcedir %{_topdir}/SOURCES’ --define ‘_specdir %{_topdir}/SPECS’ --define ‘_srcrpmdir %{_topdir}/SRPMS’ --define ‘_rpmdir %{_topdir}/RPMS’ --nodeps --define ‘_dist .rhel7u3’ --define ‘configure_options --with-core-mod --with-user_mad-mod --with-user_access-mod --with-addr_trans-mod --with-mthca-mod --with-mlx4-mod --with-mlx4_en-mod --with-mlx4_vnic-mod --with-mlx5-mod --with-cxgb3-mod --with-cxgb4-mod --with-nes-mod --with-ehca-mod --with-qib-mod --with-ipoib-mod --with-ipath_inf-mod --with-amso1100-mod --with-ocrdma-mod --with-sdp-mod --with-srp-mod --with-rds-mod --with-iser-mod --with-e_ipoib-mod --with-9pnet_rdma-mod --with-9p-mod --with-cxgb3i-mod --with-cxgb4i-mod --with-isert-mod’ --define ‘KVERSION 3.10.0-514.2.2.rt56.424.el7.x86_64’ --define ‘K_SRC /lib/modules/3.10.0-514.2.2.rt56.424.el7.x86_64/build’ --define ‘_prefix /usr’ /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_iso.29365/MLNX_OFED_SRC-3.4-2.0.0.0/SRPMS/mlnx-ofa_kernel-3.4-OFED.3.4.2.0.0.1.g30039f7.src.rpm
[31mFailed to build mlnx-ofa_kernel 3.4 RPM [0m
Collecting debug info…
[31mSee /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/OFED.29661.logs/mlnx-ofa_kernel-3.4.rpmbuild.log [0m
oskar8
January 9, 2017, 7:20pm
#4
can you give me your email. File is too big to paste here.
Hi Oskar,
Are you able to provide us with the requested log?
Thanks and regards,
~Martijn
oskar8
January 5, 2017, 5:50pm
#6
Can anyone help in above issue?
MvB
January 6, 2017, 1:18am
#7
Hi Oskar,
Can you provide the contents of the logfile which is mentioned in the log /tmp/MLNX_OFED_LINUX-3.4-2.0.0.0-3.10.0-514.2.2.rt56.424.el7.x86_64/mlnx_ofed_iso.21610.log?
The logfile name should contain *.rpmbuild.log
Thanks and regards,
~Martijn
MvB
January 9, 2017, 6:03pm
#8
Hi Oskar,
Can you please share that log file.
Thanks and regards,
~Martijn
MvB
January 12, 2017, 1:39am
#9
Hi Oskar,
As discussed by mail, there is no support for Real Time kernel in Mellanox OFED right now.
Thanks and regards,
~Martijn
I also got thoose error. MLNX_OFED_LINUX-3.4-2.0.0.0-rhel7.3-x86_64 install failed. u can dont see it, it have no answers.
so I using now 3.10.0-327.36.3.rt56.238 with ofed 3.4-2 and it works. its a bug with mutex configuration in mellanox src.
