mlnx_add_kernel_support.sh and magic version errors.
I have successfully built and installed ofed 3.2-2.0.0.0 on an Oracle Enterprise Linux 6.7 system. I tested this ofed installation in ethernet emulation mode with iperf3 and a ConnectX-4 port looping back to the other ConnectX-4 port on the same system. I disabled the internal loopback and configured nat to force the data to be issued over the physical IB cable.
I used the same build and install sequence on a simulator system with a custom kernel based on Oracle Enterprise Linux 7.1. This system is failing “mst start”
I used MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.tgz and the mlnx_add_kernel_support.sh completed without issue.
Here is the uname info for the custom kernel the system is running:
uname -a
Linux 4.1.12-32.el7uek-axnp.debug.070000.009400 #1 SMP Fri Jan 29 12:18:44 PST 2016 x86_64 x86_64 x86_64 GNU/Linux
The extra modules directory is populated with what seems like the correct directories and files:
ls /usr/lib/modules/4.1.12-32.el7uek-axnp.debug.070000.009400/extra
dmadriver_api_mod.ko knem pdgCommon.ko slbmgr_api_mod.ko
i40e.ko ksimod.ko pdgPm8018.ko slbmgrmod.ko
iser mlnx-ofa_kernel pdgQlSan.ko srp
kernel-mft nvdimm.ko psg_services.ko tdsmod.ko
The mst modules are present:
ls ./usr/lib/modules/4.1.12-32.el7uek-axnp.debug.070000.009400/extra/kernel-mft/
mst_pciconf.ko mst_pci.ko
However “mst start” fails for “version magic”:
mst start
Starting MST (Mellanox Software Tools) driver set
Loading MST PCI modulemodprobe: ERROR: could not insert ‘mst_pci’: Exec format error
  • Failure: 1
Loading MST PCI configuration modulemodprobe: ERROR: could not insert ‘mst_pciconf’: Exec format error
  • Failure: 1
Create devices
mst_pci driver not found
Unloading MST PCI module (unused) - Success
Unloading MST PCI configuration module (unused) - Success
From dmesg:
[ 2264.895260] mst_pci: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400 SMP mod_unload ’
[ 2265.048972] mst_pciconf: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400 SMP mod_unload ’
It looks like the .070000.009400 is being truncated off the “version magic” in the mst_pci and mst_pciconf modules.
Is there a string length limit for the kernel versioning in mlnx_add_kernel_support.sh?
I’m not sure how this issue was marked with a “correct answer.”
I downloaded and tried the stand-a-lone 4.3.0 mft utilities and there is no difference in behavior. “mst start” still fails for the “version magic” number.
[root@co-sanfs2sim-01 bin]# ./mlxup --query
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX4
Part Number: MCX456A-ECA_Ax
Description: ConnectX-4 VPI adapter card; EDR IB (100Gb/s) and 100GbE; dual-port QSFP28; PCIe3.0 x16; ROHS R6
PSID: MT_2190110032
PCI Device Name: 0000:90:00.0
Base GUID: 7cfe900300726e9a
Base MAC: 00007cfe90726e9a
Versions: Current Available
FW 12.14.2036 12.14.2036
Status: Up to date
[root@co-sanfs2sim-01 mft-4.3.0-25]# uname -a
Linux co-sanfs2sim-01.us.oracle.com 4.1.12-32.el7uek-axnp.debug.070000.009400 #1 SMP Fri Jan 29 12:18:44 PST 2016 x86_64 x86_64 x86_64 GNU/Linux
[root@co-sanfs2sim-01 mft-4.3.0-25]# ./install.sh
-I- Removing all installed mft packages: mft kernel-mft
-I- Building the MFT kernel binary RPM…
-I- Installing the MFT RPMs…
Preparing… ################################# [100%]
Updating / installing…
1:kernel-mft-4.3.0-4.1.12_32.el7uek################################# [100%]
1:mft-4.3.0-25 ################################# [100%]
-I- In order to start mst, please run “mst start”.
[root@co-sanfs2sim-01 mft-4.3.0-25]# mst start
  • Failure: 1
  • Failure: 1
Create devices
from dmesg.
[ 5898.964905] mst_pci: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400 SMP mod_unload ’
[ 5899.116921] mst_pciconf: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400SMP mod_unload ’
Device #1:
PSID: MT_2190110032
Status: Up to date
  • Failure: 1
  • Failure: 1
Create devices
from dmesg.
[ 5899.116921] mst_pciconf: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400 SMP mod_unload ’
I have looked through the mlnx_add_kernel_support.sh and mlnxofedinstall to try get this to install properly. So far I have been unsuccessful.
I have successfully installed ofed on the following kernel:
4.1.12-32.1.2.el7uek.x86_64
This is the kernel that gets the magic number issue and I don’t have control over changing this number format.
mlx_compat: version magic '4.1.12-32.el7uek-axnp.debug SMP mod_unload ’ should be '4.1.12-32.el7uek-axnp.debug.070000.009400 SMP mod_unload ’
It looks like “mlnx_add_kernel_support.sh” has a kernel name format requirement. Can you point to the area of the script that does this. I found the uname portion, but it just reads in the kernel number and uses it. It doesn’t manipulate it.
Hi Nathan,
Did you actually download and install the MFT package version 4.3.0 for Linux, which is required if you wanted to use the MFT utilities.
mlxup - Mellanox Update and Query Utility mlxup - Mellanox Update and Query Utility
NOTE: Version 4.3.0 is the latest.
Thank you,
Sophie.
I didn’t download the MFT package. I must have used the MFT supplied in
MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.tgz.
It looks like I have mft 4.3
mst version*
*mst, mft 4.3.0-25, built on Jan 25 2016, 19:10:21. Git SHA Hash: 7465f26
I followed this doc to setup ofed.
https://community.mellanox.com/s/article/getting-started-with-connectx-4-100gb-s-adapter-for-linux
*These are the steps I followed. It worked for standard OEL 6.7 with the
proper 6.7 *tar ball.
  1. Download ofed 3.2-2.0.0.0 tar ball to /tmp
http://www.mellanox.com/page/products_dyn?product_family=26&mtag=linux_sw_drivers http://www.mellanox.com/page/products_dyn?product_family=26&mtag=linux_sw_drivers
MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.tgz for OEL 7.1
  1. Untar MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.tgz
tar zxvf MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.tgz
creates /tmp/MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64
  1. Install other required software packages.
yum install rpm-build gcc-gfortran
  1. Generate the ofed binaries for your specific kernel from
/tmp/MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64.
./mlnx_add_kernel_support.sh --make-tgz --mlnx_ofed
/tmp/MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64 --ofed-sources
/tmp/MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64/src/MLNX_OFED_SRC-3.2-2.0.0.0.tgz–skip-repo
-t /tmp
SCREEN OUPUT:
Note: This program will create MLNX_OFED_LINUX TGZ for oel7.1 under
/usr/tmp directory.
Do you want to continue?[y/N]:y
See log file /tmp/mlnx_ofed_iso.1651.log
Building OFED RPMS . Please wait…
Created /tmp/MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64-ext.tgz
  1. Untar the ofed package that was just created.
tar zxvf MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64-ext.tgz
  1. navigate to the direcotry that hold the package for the specific
system and run install script.
cd MLNX_OFED_LINUX-3.2-2.0.0.0-oel7.1-x86_64-ext
./mlnxofedinstall
SCREEN OUPUT:
Logs dir: /tmp/MLNX_OFED_LINUX-3.2-2.0.0.0.3782.logs
This program will install the MLNX_OFED_LINUX package on your machine.
Note that all other Mellanox, OEM, OFED, or Distribution IB
packages will be removed.
Device (90:00.0):
90:00.0 Infiniband controller: Mellanox Technologies MT27700
Family
Link Width: x16
PCI Link Speed: 8GT/s
Device (90:00.1):
90:00.1 Infiniband controller: Mellanox Technologies MT27700
Family
Link Width: x16
Installation finished successfully.
1:mlnx-fw-updater-3.2-2.0.0.0 #################################
Added 'RUN_FW_UPDATER_ONBOOT=no to /etc/infiniband/openib.conf
Attempting to perform Firmware update…
Device #1:
