Hi ,
Im currently working on project that need to use Mellanox Infiniband card for our GPUDirect research. We are trying to setup a machine using the Infiniband card we just received but we face a problem with driver installation where it failed to fully install the “mlnx-ofed-kernel-2.0”. Hope we can get some help on the matter. Below shows the output we getting and some information about our machine.
CHECKING DEVICE AVAILABILITY
gpu1@gpu1-System-Product-Name:~$ lspci -v | grep Mellanox
05:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
Subsystem: Mellanox Technologies Device 0050
CHECKING UBUNTU VERSION
gpu1@gpu1-System-Product-Name:~/Downloads/MLNX_OFED_LINUX-2.0-3.0.0-ubuntu12.04-x86_64$ uname -a
Linux gpu1-System-Product-Name 3.8.0-34-generic #49~precise1-Ubuntu SMP Wed Nov 13 18:05:00 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
LAUCNHING THE INSTALLER
gpu1@gpu1-System-Product-Name:~/Downloads/MLNX_OFED_LINUX-2.0-3.0.0-ubuntu12.04-x86_64$ sudo ./mlnxofedinstall
[sudo] password for gpu1:
Log: /tmp/ofed.build.log
This program will install the MLNX_OFED_LINUX package on your machine.
Note that all other Mellanox, OEM, OFED, or Distribution IB packages will be removed.
Do you want to continue?[y/N]:y
Checking SW Requirements…
Checking for old packages…
Removing old packages…
Installing new packages
Installing ofed-scripts-2.0…
Running: /usr/bin/dpkg -i --force-confmiss /home/gpu1/Downloads/MLNX_OFED_LINUX-2.0-3.0.0-ubuntu12.04-x86_64/DEBS/ofed-scripts_2.0-1_amd64.deb
Installing mlnx-ofed-kernel-2.0…
Running: /usr/bin/dpkg -i --force-confnew --force-confmiss /home/gpu1/Downloads/MLNX_OFED_LINUX-2.0-3.0.0-ubuntu12.04-x86_64/DEBS/mlnx-ofed-kernel-dkms_2.0-OFED.2.0.2.6.9.6.g3a2d7bf_all.deb /home/gpu1/Downloads/MLNX_OFED_LINUX-2.0-3.0.0-ubuntu12.04-x86_64/DEBS/mlnx-ofed-kernel-utils_2.0-OFED.2.0.2.6.9.6.g3a2d7bf_amd64.deb
mlnx-ofed-kernel installation failed!
Removing newly installed packages…
Running: /usr/sbin/ofed_uninstall.sh --force
Please inform me if you need me to provide more data about this. attached is the logfile of the installer. Thank you.
NOTES:
- The output shows here is the second time i ran the installer, the first run of the installer show it install some other package required before proceed to install the ofed-script-2.0 and mlnx-ofed-kernel-2.0
- The computer is freshly format with ubuntu 12.04. CUDA 5.5 and nvidia driver 331 is also been installed.
Amirul,
MIMOS Software Engineer
ofed.uninstall.log.zip (792 Bytes)
ofed.build.log.zip (5.55 KB)
