MLNX_OFED_LINUX installtion Error: Error: The current MLNX_OFED_LINUX is intended for rhel6.4
Hi
Just try to install MLNX_OFED_LINUX-2.0-3.0.0-rhel6.4-x86_64.iso on Oracle Enterprise Linux 6.4. The command ./mlnxofedinstall gives error: The current MLNX_OFED_LINUX is intended for rhel6.4
uname -r is 2.6.32-358.el6.x86_64 (change to rehl kernel)
Tried also to run new installation package:
./mlnx_add_kernel_support.sh -m /mnt --make-tgz -k 2.6.32-358.el6.x86_64 -s /lib/modules/2.6.32-358.el6.x86_64/build -n MLNX-NEW
creation success, but when I try to install the same error:
Any Idea ?
Many thanks
did execute the commands, please see below:
[root@xxx]# lspci -d 15b3:
03:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
[root@xxx]# lsmod | grep mlx
mlx5_ib 78913 0
mlx5_core 72388 1 mlx5_ib
mlx4_en 78738 0
mlx4_ib 155891 0
ib_sa 24010 5 rdma_ucm,rdma_cm,ib_ipoib,ib_cm,mlx4_ib
ib_mad 43177 4 ib_cm,ib_umad,mlx4_ib,ib_sa
ib_core 81943 12 rdma_ucm,ib_ucm,rdma_cm,iw_cm,ib_ipoib,ib_cm,ib_uverbs,ib_umad,mlx5_ib,mlx4_ib,ib_sa,ib_mad
mlx4_core 240441 2 mlx4_en,mlx4_ib
compat 22986 17 rdma_ucm,ib_ucm,rdma_cm,iw_cm,ib_addr,ib_ipoib,ib_cm,ib_uverbs,ib_umad,mlx5_ib,mlx5_core,mlx4_en,mlx4_ib,ib_sa,ib_mad,ib_core,mlx4_core
[root@xxx]# ibv_devices
device node GUID
…still no device visible, any other idea ? Many thanks in advance
Hi here is the output:
ls -l /dev/infiniband/
total 0
crw-rw-rw-. 1 root root 10, 56 Jan 1 10:33 rdma_cm
and this:
cat /etc/udev/rules.d/90-ib.rules
KERNEL==“umad*”, NAME=“infiniband/%k” MODE=“0666”
KERNEL==“issm*”, NAME=“infiniband/%k”
KERNEL==“ucm*”, NAME=“infiniband/%k”, MODE=“0666”
KERNEL==“uverbs*”, NAME=“infiniband/%k”, MODE=“0666”
KERNEL==“ucma”, NAME=“infiniband/%k”, MODE=“0666”
KERNEL==“rdma_cm”, NAME=“infiniband/%k”, MODE=“0666”
What to do next ?
Stop openibd
Turn debug on for udev.
udevadm control --log-priority debug
udevadm control --reload-rules
Start openibd
And search for 90-ib.rules in /var/log/messages
These are logs when it works, but you should see errors that can give use some clues
Jan 6 23:08:40 my-host udevd-work[11143]: MODE 0666 /etc/udev/rules.d/90-ib.rules:3
Jan 6 23:08:40 my-host udevd-work[11143]: NAME ‘infiniband/ucm0’ /etc/udev/rules.d/90-ib.rules:3
Jan 6 23:08:40 my-host udevd-work[11143]: create db link (infiniband/ucm0 char/231:224)
Jan 6 23:08:40 my-host udevd-work[11143]: creating device node ‘/dev/infiniband/ucm0’, devnum=231:224, mode=0666, uid=0, gid=0
Jan 6 23:08:40 my-host udevd-work[11143]: preserve file ‘/dev/infiniband/ucm0’, because it has correct dev_t
Jan 6 23:08:40 my-host udevd-work[11143]: preserve permissions /dev/infiniband/ucm0, 020666, uid=0, gid=0
Jan 6 23:08:40 my-host udevd-work[11143]: creating symlink ‘/dev/char/231:224’ to ‘…/infiniband/ucm0’
Ok did install OEL OFED.
Still have the issue that I dont see the ib0
Could it be that I have already configured eth1 as ethernt ?
see output (is empty):
ibv_devices
device node GUID
Since you’re using OEL 6.4 ,I would recommend downloading the version for OEL 6.4
Here the Iso link:
Mellanox Technologies: MLNX_OFED EULA http://www.mellanox.com/page/mlnx_ofed_eula?mtag=linux_sw_drivers&mrequest=downloads&mtype=ofed&mver=MLNX_OFED-2.0-3.0.0&mname=MLNX_OFED_LINUX-2.0-3.0.0-oel6.4-x86_64.iso
Or TGZ file"
MLNX_OFED_LINUX-2.0-3.0.0-oel6.4-x86_64.tgz http://www.mellanox.com/page/mlnx_ofed_eula?mtag=linux_sw_drivers&mrequest=downloads&mtype=ofed&mver=MLNX_OFED-2.0-3.0.0&mname=MLNX_OFED_LINUX-2.0-3.0.0-oel6.4-x86_64.tgz
Hi
Thanks that helped out with --skip-distro-check
My question now, I think hardware is working. But I dont see any Ib0 interface ? How to get the infiniband interface name ?
./hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … x86_64
Host Driver Version … MLNX_OFED_LINUX-2.0-3.0.0 (OFED-2.0-3.0.0): 2.6.32-358.el6.x86_64
Host Driver RPM Check … PASS
Firmware on CA #0 VPI … v2.30.3200
Firmware Check on CA #0 (VPI) … PASS
NOTE: The found fw version is higher than the fw included in this package (v2.30.3110)
Host Driver Initialization … PASS
Number of CA Ports Active … 0
Kernel Syslog Check … PASS
Node GUID on CA #0 (VPI) … NA
------------------ DONE ---------------------
You can skip the distro check with --skip-distro-check
You might also need --without-depcheck
Cheers,
sorin
As Rian pointed out, you should install OEL OFED (I had no idea it is available)
ibdev2netdev should show something like this
mlx4_0 port 1 ==> ib0 (Up)
mlx4_0 port 2 ==> eth1 (Up)
ibv_devices should show something like this, regardless how the ports are configured
device node GUID
mlx4_0 0002c9030…
Do you see the adapter with this command?
lspci -d 15b3:
If yes, can you check if mlx modules are loaded? lsmod | grep mlx
Can you check this dir?
total 0
crw-rw---- 1 root root 231, 64 Jan 6 18:57 issm0
crw-rw---- 1 root root 231, 65 Jan 6 18:57 issm1
crw-rw-rw- 1 root root 10, 56 Dec 28 00:17 rdma_cm
crw-rw-rw- 1 root root 231, 224 Dec 28 00:17 ucm0
crw-rw-rw- 1 root root 231, 0 Jan 6 18:57 umad0
crw-rw-rw- 1 root root 231, 1 Jan 6 18:57 umad1
crw-rw-rw- 1 root root 231, 192 Dec 28 00:17 uverbs0
Those are created by udev and the rules should look like this.
If those rules are missing or have wrong permissions, that might be the cause.
I did plug in the 2 infiniband cables and checked if they are correct plugged in into port 1 and 2.
Now output looks like this:
[root@xxx ~]# ibv_devices
device node GUID
mlx4_0 0002c90300345f50
[root@xxx ~]# lspci -d 15b3:
[root@xxx ~]# ls -l /dev/infiniband/
total 0
crw-rw----. 1 root root 231, 64 Jan 7 10:10 issm0
crw-rw----. 1 root root 231, 65 Jan 7 10:10 issm1
crw-rw-rw-. 1 root root 10, 56 Jan 7 10:10 rdma_cm
crw-rw-rw-. 1 root root 231, 224 Jan 7 10:10 ucm0
crw-rw-rw-. 1 root root 231, 0 Jan 7 10:10 umad0
crw-rw-rw-. 1 root root 231, 1 Jan 7 10:10 umad1
crw-rw-rw-. 1 root root 231, 192 Jan 7 10:10 uverbs0
[root@xxx ~]# ls /sys/class/infiniband
mlx4_0
[root@ewsexaobi01 ~]# ibv_devinfo
hca_id: mlx4_0
transport: InfiniBand (0)
fw_ver: 2.30.3200
node_guid: 0002:c903:0034:5f50
sys_image_guid: 0002:c903:0034:5f53
vendor_id: 0x02c9
vendor_part_id: 4099
hw_ver: 0x1
board_id: HP_0230240019
phys_port_cnt: 2
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
active_mtu: 4096 (5)
sm_lid: 2
port_lid: 13
port_lmc: 0x00
link_layer: InfiniBand
port: 2
max_mtu: 4096 (5)
sm_lid: 2
port_lid: 14
port_lmc: 0x00
Is this ok now ? How to get now network configured ip ?
Hi ,
To configure ip , and for configuration in general i’ll recommend using the Mellanox OFED user manual:
http://www.mellanox.com/related-docs/prod_software/Mellanox_OFED_Linux_User_Manual_v2.1-1.0.0.pdf http://www.mellanox.com/related-docs/prod_software/Mellanox_OFED_Linux_User_Manual_v2.1-1.0.0.pdf
Section 4.3.3
