I am trying to install MLNX_OFED 4.5-1.0.1.0 on a Fedora 28 machine. The kernel version is 4.20.17-100.fc28.x86_64. Running the mlnxofedinstall gives the following error message and:
The 4.20.17-100.fc28.x86_64 kernel is installed, MLNX_OFED_LINUX does not have drivers available for this kernel.
Running the mlnx_add_kernel_support.sh using the below command
./mlnx_add_kernel_support.sh -m /path/to/MLNX_OFED_LINUX-4.5-1.0.1.0-fc28-x86_64/ --kernel 4.20.17-100.fc28.x86_64 --make-tgz
also fails with error messages
Failed to build mlnx-ofa_kernel 4.5 RPM
and looking at the rpm build log for errors gives these logs
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/net/ethernet/mellanox/mlx5/core/main.c:1766:22: error: initialization of ‘int (*)(struct devlink *, u16, struct netlink_ext_ack )’ {aka 'int ()(struct devlink *, short unsigned int, struct netlink_ext_ack )’} from incompatible pointer type 'int ()(struct devlink , u16)’ {aka 'int ()(struct devlink *, short unsigned int)’} [-Werror=incompatible-pointer-types]
.eswitch_mode_set = mlx5_devlink_eswitch_mode_set,
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/net/ethernet/mellanox/mlx5/core/main.c:1766:22: note: (near initialization for ‘mlx5_devlink_ops.eswitch_mode_set’)
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/net/ethernet/mellanox/mlx5/core/main.c:1770:29: error: initialization of ‘int (*)(struct devlink *, u8, struct netlink_ext_ack )’ {aka 'int ()(struct devlink *, unsigned char, struct netlink_ext_ack )’} from incompatible pointer type 'int ()(struct devlink , u8)’ {aka 'int ()(struct devlink *, unsigned char)’} [-Werror=incompatible-pointer-types]
.eswitch_inline_mode_set = mlx5_devlink_eswitch_inline_mode_set,
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/net/ethernet/mellanox/mlx5/core/main.c:1770:29: note: (near initialization for ‘mlx5_devlink_ops.eswitch_inline_mode_set’)
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/net/ethernet/mellanox/mlx5/core/main.c:1774:28: error: initialization of ‘int (*)(struct devlink *, u8, struct netlink_ext_ack )’ {aka 'int ()(struct devlink *, unsigned char, struct netlink_ext_ack )’} from incompatible pointer type 'int ()(struct devlink , u8)’ {aka 'int ()(struct devlink *, unsigned char)’} [-Werror=incompatible-pointer-types]
.eswitch_encap_mode_set = mlx5_devlink_eswitch_encap_mode_set,
and also some of these logs
/tmp/mlnx_iso.25438/OFED_topdir/BUILD/mlnx-ofa_kernel-4.5/obj/default/drivers/infiniband/ulp/ipoib/ipoib_ethtool.c:387:3: error: ‘const struct ethtool_ops’ has no member named ‘get_settings’; did you mean ‘get_strings’?
.get_settings = ipoib_get_settings,
get_strings
What can be done to fix these errors? Also what is the officially supported kernel version by MLNX_OFED 4.5.1.0.1.0 ?
