Full transparency - I was running 2bit v4 flash and was happy, same here - I’m happy. Its not perfect but I also don’t have tens of thousands of dollars to spend on a cluster than could run remotely close to a higher quant. I’m okay with the quality loss under the circumstances
I guess the question is, have you tried comparing running your work load on qwen3.8 27b or flash next on a single spark and seeing what handles your tasks with less issue?
Don’t kid yourself. What’s the point of all that speed under this quantization setup? Speed only holds value when it’s built on top of model capability.
I was able to successfully deploy it with changes suggested in PRs 3 and 4. But the max speed is 50 tok/s before PRs (it crashes after ~10ktokens) 40 with PRs applied (works reliably). Not bad still, but please dont advertise 60 tok/s.
Just started using it. Using it on Hermes Desktop via Spark Studio, thinking set to Medium and I couldn’t do anything just loops. Changed it to Low thinking and its actually performing a bit better, got it up to 26.4 tok/s on some tasks but it fluctuates. It did create a schedule for me on an excel file, and it also rendered an editable HMLT calendar with a GUI to make changes to the month. It did take quite a while, been used to the qwen3.8 speeds.
Managed to get GLM-5.3-Flash-EXL3-2.05 load successfully on the single dgx spark but had to shut down all other containers and apps to make room in the ram.
Thanks to gitcommit90 for the recipe.
Running the same setup I still can not get the same results.
I just get 87/100 in tool eval benchy.
told claude to figure it out but the ai need more information.
Here is what it needs to know.
Context & State 60 (yours: 95), Autonomous Planning 67 (the same as yours).
The context was limited to 8192, so 3 scenarios (TC-38/39/40) were rejected, and the default scenario set doesn’t include Hard Mode.
llama-benchy, depth 0: 21.2 tok/s decode, 418 tok/s prefill, TTFT 5.2 s. At depth 4096 it was 13.6 tok/s. Your numbers are 29.7 decode and 571 prefill. Draft acceptance on the tool-eval run was 58.5%, with a mean of 3.93 tokens per step.
The EXL3 diagnostics logged effective_tier=sorted with fallback_reasons=degraded_shared_suh and shared_suh_layers=0/42 on every layer. The README says this fallback is expected for this checkpoint, but we don’t know if you see the same.
Problems that cost us a day (maybe useful to others)
Corrupt shards gave garbage output. Three of the 12 weight shards (09, 10, 11) were sparse files with zero-filled holes after an interrupted download. The first token was right (“Paris”), then the output collapsed even at temperature 0, with spec decoding off too. The loader warnings (f_b_proj/g_b_proj resolved=[], shared_suh_absent) turned out to be harmless. Running sha256sum -c against the Hugging Face hashes found it at once, so please check your shards. Draft acceptance was 1.1–1.7 while corrupt and 3.9–5.6 after the fix.
Page cache hurts CUDA-free memory on the GB10. After reading the weights, MemAvailable showed 100+ GiB while CUDA saw only 14 GiB free. We needed sync; echo 3 | sudo tee /proc/sys/vm/drop_caches before every launch. Even then, vLLM saw about 5 GiB less than a separate torch.cuda.mem_get_info() measurement. At 0.82–0.85 vLLM refused to start.
Not enough KV at 0.80. With async scheduling on, we needed about 14.5–15 GiB of KV even for one sequence, whatever the context. At 0.80 that gave 8192 context at best. We’d read in issue #3 that --no-async-scheduling and drafter block 1024 cut this to about 10 GiB at 262144, and we’re now trying that.
A container death under load. The vLLM container died abruptly during tool-eval at about scenario 50, with host MemAvailable around 3 GiB beforehand. We saw no OOM or earlyoom entry. The log was overwritten by the restart, so the cause isn’t proven. Our box also runs other services, so host headroom is tighter than on a dedicated Spark.
What we’d love to know
Your exact launch command and env: ONE_SPARK_* values, GLM53_INDEXER_WORKSPACE, ONE_SPARK_K, gpu-memory-utilization, max_num_seqs, and whether you used the PR #4 serve script unmodified.
Which “tweaks from the Issue” you applied (async off, drafter block 1024, mamba seed fix?).
The tool-eval-bench command: thinking on or off, temperature, max tokens, parallelism, and whether Hard Mode was enabled (your 104 scenarios) with seed 42.
Chat template, tool-call parser (glm47?) and reasoning parser (glm45?).
Whether you also see effective_tier=sorted / shared_suh_layers=0/42 in the EXL3 diag, and what “kernel tier” would need.
Whether anything else was running on the machine, and your host-free memory after init.
Yes, it needs the entire DGX spark. Unload everything, all the other containers, etc. ie, debloat your spark.
I am running “headless” and took advantage of reducing the display reservation setting in the new OTA2610 firmware: see Let's optimize ... DGX Spark for this and some other ideas.
I changed the **--gpu-memory-utilization**to 0.85 but was able to increase the KV cache somewhat from the ideas in Issue#4.
Here are the arguments I used for tool-eval-bench:
tool-eval-bench --hardmode --seed 42 --backend-kwargs ‘{“max_tokens”:16384,“chat_template_kwargs”: {“enable_thinking”:true,“reasoning_effort”:“max”}}’ --base-url --needle
If the performance was a little better I might use it. Maybe someone will create a TensorFold version.
