My use-case is an avionics DVR.
I am using Linux R35.5.0 (Jetpack 5.1.3) with a custom carrier board.
I have modified the device tree and ov5693 driver to support camera capture from an FPGA.
In this use-case a NTSC composite camera is routed to the FPGA which de-interlaces the video and send 720x480p to Jetson MIPI. Capture seems to work using v4l2-ctl. See below and raw frame is attached as well.
When I capture using gstreamer and specify the capture width=720 and height=480 the video is garbled.
When I capture the same composite source with gstreamer and specify the capture width=1280 and height=720 the 720x480 area of video looks ok.
Why?
tegra194-camera-e3333-a00.zip (3.2 KB)
frame.zip (108.4 KB)
Blockquote
root@xavier:~# v4l2-ctl --device /dev/video2 --set-fmt-video=width=720,height=480,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 59.94 fps
Blockquote
root@xavier:~# v4l2-ctl -d /dev/video2 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'YUYV' (YUYV 4:2:2)
Size: Discrete 1920x1080
Interval: Discrete 0.017s (59.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Interval: Discrete 0.020s (50.000 fps)
[1]: 'YUYV' (YUYV 4:2:2)
root@xavier:~#
