Hi all,
I am trying to capture the RGB888 mipi csi2 data from an FPGA without I2C.
I am using Jetson Orin Nano Developer kit and JetPack 5.1.1 .
My changes are below;
- Changed dts file (tegra234-camera-rbpcv2-imx219.dtsi)
tegra234-camera-rbpcv2-imx219.dtsi (25.8 KB)
- Modified nv_imx219 driver. I removed I2C functions.
imx219_mode_tbls.h (1.3 KB)
nv_imx219.c (9.0 KB)
Then, /dev/video0 file created after reboot.
Also, v4l2-ctl response is below;
v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'AR24' (32-bit BGRA 8-8-8-8)
Interval: Discrete 0.033s (30.000 fps)
But, when I called gst-launch-1.0 v4l2src ! video/x-raw,width=1280,height=720,format=BGRA ! videoconvert ! autovideosink, I didnt get any frame.
In dmesg log:
[ 2284.770151] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2284.779318] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2284.789910] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2284.797762] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 2284.808588] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 2284.816458] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found> Blockquote for stream- 0 vc- 0
[ 2284.827899] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
trace log
trace.log (32.0 KB)
My questions;
- Do you have any suggestions to get frame successfully?
- Are there any missing steps?
- I don’t understand why the pixel format is AR24 (in v4l2-ctl log). The variable “pixel_t” in the extract_pixel_format function (sensor_common.c) returns rgb_rgb88824. Is this normal?
Thanks in advance.
