800G Ethernet with CX-8
Does CX-8 support 800G ethernet speed?
If yes, which cables are recommended.
ethtool shows support only upto 400G and connects only at 400G or lower.
mlxconfig shows 2x400GbE; Single-cage OSFP;
Is there a specific cable which I can use to connect two CX-8 back-to-back?
Is there a specific cable which I can use to connect a CX-8 to any other 800G NIC in the market?
Also Is there a specific cable which I can use to connect CX-8 to a 400G NIC port?
Also recommend appropriate settings based on the mlxconfig output provided below to get the desired speeds.
Here is some info from ethtool, mlxconfig, mlxlink etc..
ethtool enp193s0np0
Settings for enp193s0np0:
Supported ports: [ Backplane ]
Supported link modes: 50000baseKR/Full
                    50000baseSR/Full
                    50000baseCR/Full
                    50000baseLR_ER_FR/Full
                    50000baseDR/Full
                    100000baseKR2/Full
                    100000baseSR2/Full
                    100000baseCR2/Full
                    100000baseLR2_ER2_FR2/Full
                    100000baseDR2/Full
                    200000baseKR4/Full
                    200000baseSR4/Full
                    200000baseLR4_ER4_FR4/Full
                    200000baseDR4/Full
                    200000baseCR4/Full
                    100000baseKR/Full
                    100000baseSR/Full
                    100000baseLR_ER_FR/Full
                    100000baseCR/Full
                    100000baseDR/Full
                    200000baseKR2/Full
                    200000baseSR2/Full
                    200000baseLR2_ER2_FR2/Full
                    200000baseDR2/Full
                    200000baseCR2/Full
                    400000baseKR4/Full
                    400000baseSR4/Full
                    400000baseLR4_ER4_FR4/Full
                    400000baseDR4/Full
                    400000baseCR4/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Supported FEC modes: None RS BASER
Advertised link modes: 400000baseKR4/Full
                    400000baseSR4/Full
                    400000baseDR4/Full
                    400000baseCR4/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Advertised FEC modes: RS
Speed: 400000Mb/s
Lanes: 4
Duplex: Full
Auto-negotiation: off
Port: Direct Attach Copper
PHYAD: 0
Transceiver: internal
Supports Wake-on: d
Wake-on: d
Link detected: yes
mlxconfig -d /dev/mst/mt4131_pciconf0 q
Device type: ConnectX8
Description: NVIDIA ConnectX-8 C8180 HHHL SuperNIC; 800Gbs XDR IB (default mode) / 2x400GbE; Single-cage OSFP; PCIe 6 x16 with x16 PCIe Socket Direct/Multi Host Extension option; Crypto Enabled; Secure Boot Enabled
Device: /dev/mst/mt4131_pciconf0
Configurations: Next Boot
RO ADVANCED_TESTABILITY False(0)
    LARGE_MTU_TWEAK_64                          False(0)
    AES_XTS_TWEAK_INC_64                        False(0)
    CRYPTO_POLICY                               UNRESTRICTED(1)
RO CUSTOMIZATION_NUMBER Array[0..15]
    DPA_AUTHENTICATION                          False(0)
    NVME_EMU_MNG_ENABLE                         False(0)
    NVME_EMU_MNG_NUM_VF                         0
    NVME_EMU_MNG_NUM_PF                         1
    NVME_EMU_MNG_VENDOR_ID                      5555
    NVME_EMU_MNG_DEVICE_ID                      24577
    NVME_EMU_MNG_CLASS_CODE                     67586
    NVME_EMU_MNG_REVISION_ID                    0
    NVME_EMU_MNG_SUBS_VENDOR_ID                 1335
    NVME_EMU_MNG_SUBS_ID                        0
    NVME_EMU_MNG_NUM_MSIX                       0
    NVME_EMU_MNG_NUM_VF_MSIX                    768
    NVME_EMU_MNG_MAX_QUEUE_DEPTH                0
    PCI_SWITCH_EMU_MNG_NUM_PORT                 16
    PCI_SWITCH_EMU_MNG_ENABLE                   False(0)
    VIRTIO_BLK_EMU_MNG_ENABLE                   False(0)
    VIRTIO_BLK_EMU_MNG_NUM_VF                   0
    VIRTIO_BLK_EMU_MNG_NUM_PF                   0
    VIRTIO_BLK_EMU_MNG_SUBS_VENDOR_ID           6900
    VIRTIO_BLK_EMU_MNG_SUBS_ID                  4162
    VIRTIO_BLK_EMU_MNG_NUM_MSIX                 2
    VIRTIO_BLK_EMU_MNG_NUM_VF_MSIX              0
    VIRTIO_FS_EMU_MNG_ENABLE                    False(0)
    VIRTIO_FS_EMU_MNG_NUM_VF                    0
    VIRTIO_FS_EMU_MNG_NUM_PF                    0
    VIRTIO_FS_EMU_MNG_SUBS_VENDOR_ID            6900
    VIRTIO_FS_EMU_MNG_SUBS_ID                   4186
    VIRTIO_FS_EMU_MNG_NUM_MSIX                  2
    VIRTIO_FS_EMU_MNG_NUM_VF_MSIX               0
    VIRTIO_NET_EMU_MNG_ENABLE                   False(0)
    VIRTIO_NET_EMU_MNG_NUM_VF                   0
    VIRTIO_NET_EMU_MNG_NUM_PF                   0
    VIRTIO_NET_EMU_MNG_SUBS_VENDOR_ID           6900
    VIRTIO_NET_EMU_MNG_SUBS_ID                  4161
    VIRTIO_NET_EMU_MNG_NUM_MSIX                 2
    VIRTIO_NET_EMU_MNG_NUM_VF_MSIX              0
    PCI_SWITCH_EMULATION_NUM_PORT               16
    PCI_SWITCH_EMULATION_ENABLE                 False(0)
    PORT_OWNER                                  True(1)
    ALLOW_RD_COUNTERS                           True(1)
    RENEG_ON_CHANGE                             True(1)
    TRACER_ENABLE                               True(1)
    FLEX_PARSER_PROFILE_ENABLE                  0
    PROG_PARSE_GRAPH                            False(0)
    FLEX_IPV4_OVER_VXLAN_PORT                   0
    SWITCH_COMPT_FEATURE_MASK                   0x0(0)
    PF_BAR2_SIZE                                0
    PF_NUM_OF_VF_VALID                          False(0)
    NON_PREFETCHABLE_PF_BAR                     False(0)
    VF_VPD_ENABLE                               False(0)
    PF_NUM_PF_MSIX_VALID                        False(0)
    PER_PF_NUM_SF                               False(0)
    STRICT_VF_MSIX_NUM                          False(0)
    VF_NODNIC_ENABLE                            False(0)
    NUM_PF_MSIX_VALID                           True(1)
    NUM_OF_VFS                                  16
    NUM_OF_PF                                   1
    PF_BAR2_ENABLE                              False(0)
    SRIOV_EN                                    True(1)
    PF_LOG_BAR_SIZE                             5
    VF_LOG_BAR_SIZE                             1
    NUM_PF_MSIX                                 63
    NUM_VF_MSIX                                 11
    PCIE_CREDIT_TOKEN_TIMEOUT                   0
    PCI_DOWNSTREAM_PORT_OWNER                   Array\[0..15\]
    STRAP_SD_OR_MH                              False(0)
    PCORE2_REVERSAL_VALID                       False(0)
    PCORE1_REVERSAL_VALID                       False(0)
    PCORE0_REVERSAL_VALID                       False(0)
    OFF_BOARD_SERIALIZER                        False(0)
    PCORE2_REVERSAL                             False(0)
    PCORE1_REVERSAL                             False(0)
    PCORE0_REVERSAL                             False(0)
    UPSTREAM_PORT0_GEN6_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN6_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN5_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN5_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN4_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN4_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN3_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT0_GEN3_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN6_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN6_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN5_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN5_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN4_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN4_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN3_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT1_GEN3_PRESET0                 DEVICE_DEFAULT(0)
    PCI_BUS01_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS01_SWITCH_INDEX                      0
    PCI_BUS01_SPEED                             PCI_GEN_1(0)
    PCI_BUS01_ASPM                              False(0)
    PCI_BUS01_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS00_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS00_SWITCH_INDEX                      0
    PCI_BUS00_SPEED                             PCI_GEN_6(5)
    PCI_BUS00_ASPM                              False(0)
    PCI_BUS00_WIDTH                             PCI_X16(5)
    PCI_BUS03_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS03_SWITCH_INDEX                      0
    PCI_BUS03_SPEED                             PCI_GEN_1(0)
    PCI_BUS03_ASPM                              False(0)
    PCI_BUS03_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS02_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS02_SWITCH_INDEX                      0
    PCI_BUS02_SPEED                             PCI_GEN_1(0)
    PCI_BUS02_ASPM                              False(0)
    PCI_BUS02_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS05_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS05_SWITCH_INDEX                      0
    PCI_BUS05_SPEED                             PCI_GEN_1(0)
    PCI_BUS05_ASPM                              False(0)
    PCI_BUS05_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS04_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS04_SWITCH_INDEX                      0
    PCI_BUS04_SPEED                             PCI_GEN_1(0)
    PCI_BUS04_ASPM                              False(0)
    PCI_BUS04_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS07_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS07_SWITCH_INDEX                      0
    PCI_BUS07_SPEED                             PCI_GEN_1(0)
    PCI_BUS07_ASPM                              False(0)
    PCI_BUS07_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS06_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS06_SWITCH_INDEX                      0
    PCI_BUS06_SPEED                             PCI_GEN_1(0)
    PCI_BUS06_ASPM                              False(0)
    PCI_BUS06_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS11_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS11_SWITCH_INDEX                      0
    PCI_BUS11_SPEED                             PCI_GEN_1(0)
    PCI_BUS11_ASPM                              False(0)
    PCI_BUS11_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS10_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS10_SWITCH_INDEX                      0
    PCI_BUS10_SPEED                             PCI_GEN_1(0)
    PCI_BUS10_ASPM                              False(0)
    PCI_BUS10_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS13_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS13_SWITCH_INDEX                      0
    PCI_BUS13_SPEED                             PCI_GEN_1(0)
    PCI_BUS13_ASPM                              False(0)
    PCI_BUS13_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS12_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS12_SWITCH_INDEX                      0
    PCI_BUS12_SPEED                             PCI_GEN_1(0)
    PCI_BUS12_ASPM                              False(0)
    PCI_BUS12_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS15_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS15_SWITCH_INDEX                      0
    PCI_BUS15_SPEED                             PCI_GEN_1(0)
    PCI_BUS15_ASPM                              False(0)
    PCI_BUS15_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS14_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS14_SWITCH_INDEX                      0
    PCI_BUS14_SPEED                             PCI_GEN_1(0)
    PCI_BUS14_ASPM                              False(0)
    PCI_BUS14_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS17_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS17_SWITCH_INDEX                      0
    PCI_BUS17_SPEED                             PCI_GEN_1(0)
    PCI_BUS17_ASPM                              False(0)
    PCI_BUS17_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS16_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS16_SWITCH_INDEX                      0
    PCI_BUS16_SPEED                             PCI_GEN_1(0)
    PCI_BUS16_ASPM                              False(0)
    PCI_BUS16_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS21_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS21_SWITCH_INDEX                      0
    PCI_BUS21_SPEED                             PCI_GEN_1(0)
    PCI_BUS21_ASPM                              False(0)
    PCI_BUS21_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS20_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS20_SWITCH_INDEX                      0
    PCI_BUS20_SPEED                             PCI_GEN_1(0)
    PCI_BUS20_ASPM                              False(0)
    PCI_BUS20_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS23_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS23_SWITCH_INDEX                      0
    PCI_BUS23_SPEED                             PCI_GEN_1(0)
    PCI_BUS23_ASPM                              False(0)
    PCI_BUS23_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS22_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS22_SWITCH_INDEX                      0
    PCI_BUS22_SPEED                             PCI_GEN_1(0)
    PCI_BUS22_ASPM                              False(0)
    PCI_BUS22_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS25_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS25_SWITCH_INDEX                      0
    PCI_BUS25_SPEED                             PCI_GEN_1(0)
    PCI_BUS25_ASPM                              False(0)
    PCI_BUS25_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS24_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS24_SWITCH_INDEX                      0
    PCI_BUS24_SPEED                             PCI_GEN_1(0)
    PCI_BUS24_ASPM                              False(0)
    PCI_BUS24_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS27_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS27_SWITCH_INDEX                      0
    PCI_BUS27_SPEED                             PCI_GEN_1(0)
    PCI_BUS27_ASPM                              False(0)
    PCI_BUS27_WIDTH                             PCI_INACTIVE(0)
    PCI_BUS26_HIERARCHY_TYPE                    PCIE_ENDPOINT(0)
    PCI_BUS26_SWITCH_INDEX                      0
    PCI_BUS26_SPEED                             PCI_GEN_1(0)
    PCI_BUS26_ASPM                              False(0)
    PCI_BUS26_WIDTH                             PCI_INACTIVE(0)
    PCI_SWITCH1_UPSTREAM_PORT_PEX               0
    PCI_SWITCH1_UPSTREAM_PORT_BUS               0
    PCI_SWITCH0_UPSTREAM_PORT_PEX               0
    PCI_SWITCH0_UPSTREAM_PORT_BUS               0
    PCI_SWITCH2_UPSTREAM_PORT_PEX               0
    PCI_SWITCH2_UPSTREAM_PORT_BUS               0
    UPSTREAM_PORT0_TX_AMP                       0
    UPSTREAM_PORT1_TX_AMP                       0
    UPSTREAM_PORT2_TX_AMP                       0
    UPSTREAM_PORT3_TX_AMP                       0
    UPSTREAM_PORT0_PCIE_BUS                     0
    UPSTREAM_PORT1_PCIE_BUS                     0
    UPSTREAM_PORT2_PCIE_BUS                     0
    UPSTREAM_PORT3_PCIE_BUS                     0
    UPSTREAM_PORT2_GEN6_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN6_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN5_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN5_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN4_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN4_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN3_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT2_GEN3_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN6_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN6_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN5_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN5_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN4_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN4_PRESET0                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN3_PRESET1                 DEVICE_DEFAULT(0)
    UPSTREAM_PORT3_GEN3_PRESET0                 DEVICE_DEFAULT(0)
    ROCE_CC_COMPATIBILITY_MODE                  DEVICE_DEFAULT(0)
    ROCE_CC_RTT_TIMESTAMP_FORMAT                DEVICE_DEFAULT(0)
    ROCE_CC_TX_EVENT_ACK                        DEVICE_DEFAULT(0)
    ROCE_CC_DCQCN_COMPATIBILITY_MODE            DEVICE_DEFAULT(0)
    ROCE_CC_STEERING_EXT                        DISABLED(1)
    ROCE_CC_LEGACY_DCQCN_SW                     False(0)
    SILENT_MODE                                 False(0)
    MKEY_BY_NAME_RANGE                          DEVICE_DEFAULT(0)
    ROCE_CONTROL                                ROCE_ENABLE(2)
    PCI_WR_ORDERING                             per_mkey(0)
    MULTI_PORT_VHCA_EN                          False(0)
    HOST_CHAINING_MODE                          DISABLED(0)
    HOST_CHAINING_CACHE_DISABLE                 False(0)
    HOST_CHAINING_DESCRIPTORS                   Array\[0..7\]
    HOST_CHAINING_TOTAL_BUFFER_SIZE             Array\[0..7\]
    RDE_DISABLE                                 False(0)
    PLDM_FW_UPDATE_DISABLE                      False(0)
    MCTP_I3C_DISABLE                            False(0)
    RBT_DISABLE                                 False(0)
    PCIE_SMBUS_DISABLE                          False(0)
    PCIE_IN_BAND_VDM_DISABLE                    False(0)
    SM_DISABLE                                  False(0)
    LOG_DCR_HASH_TABLE_SIZE                     11
    MAX_PACKET_LIFETIME                         0
    DCR_LIFO_SIZE                               16384
    IB_PROTO_WIDTH_EN_MASK_P1                   125288449
    ESWITCH_HAIRPIN_DESCRIPTORS                 Array\[0..7\]
    ESWITCH_HAIRPIN_TOT_BUFFER_SIZE             Array\[0..7\]
    KEEP_ETH_LINK_UP_P1                         True(1)
    KEEP_IB_LINK_UP_P1                          False(0)
    KEEP_LINK_UP_ON_BOOT_P1                     False(0)
    KEEP_LINK_UP_ON_STANDBY_P1                  False(0)
    DO_NOT_CLEAR_PORT_STATS_P1                  False(0)
    AUTO_POWER_SAVE_LINK_DOWN_P1                False(0)
    PHY_AUTO_NEG_P1                             DEVICE_DEFAULT(0)
    PHY_RATE_MASK_OVERRIDE_P1                   False(0)
    LLDP_NB_DCBX_P1                             False(0)
    LLDP_NB_RX_MODE_P1                          OFF(0)
    LLDP_NB_TX_MODE_P1                          OFF(0)
    DCBX_IEEE_P1                                True(1)
    DCBX_CEE_P1                                 True(1)
    DCBX_WILLING_P1                             True(1)
    MEMIC_BAR_SIZE                              0
    MEMIC_SIZE_LIMIT                            \_256KB(1)
    MEMIC_ATOMIC                                MEMIC_ATOMIC_ENABLE(2)
    MEMIC_ATOMIC_ENDIANESS                      DEVICE_DEFAULT(0)
    MODULE_SPLIT_M0                             Array\[0..15\]
    DUP_MAC_ACTION_P1                           LAST_CFG(0)
    MPFS_MC_LOOPBACK_DISABLE_P1                 False(0)
    MPFS_UC_LOOPBACK_DISABLE_P1                 False(0)
    UNKNOWN_UPLINK_MAC_FLOOD_P1                 False(0)
    SRIOV_IB_ROUTING_MODE_P1                    LID(1)
    NUM_OF_PLANES_P1                            4
    LOAD_BALANCE_MODE_P1                        TRANSPORT(2)
    PCC_NP_HANDLE_CORE_UTIL                     DEVICE_DEFAULT(0)
    PCC_HANDLE_CORE_UTIL                        DEVICE_DEFAULT(0)
    PCC_INT_NP_RTT_DSCP                         26
    PCC_INT_NP_RTT_DSCP_EN                      False(0)
    PCC_INT_NP_RTT_DATA_MODE                    RTT_V0(64)
    PCC_INT_EN                                  False(0)
    PCC_INT_SYSTEM_RTT                          0
    BAR_PAGE_ALIGNMENT                          DEVICE_DEFAULT(0)
    P2P_ORDERING_MODE                           DEVICE_DEFAULT(0)
    ATS_ENABLED                                 False(0)
    DYNAMIC_VF_MSIX_TABLE                       False(0)
    EXP_ROM_UEFI_ARM_ENABLE                     True(1)
    EXP_ROM_UEFI_x86_ENABLE                     True(1)
    EXP_ROM_PXE_ENABLE                          True(1)
    ADVANCED_PCI_SETTINGS                       False(0)
    STEERING_CACHE_REFRESH                      0
    TX_SCHEDULER_LOCALITY_MODE                  DEVICE_DEFAULT(0)
    ICM_CACHE_MODE                              DEVICE_DEFAULT(0)
    TX_SCHEDULER_FWS_REACTIVITY                 DIRECT(1)
    HAIRPIN_DATA_BUFFER_LOCK                    False(0)
    TX_SCHEDULER_BURST                          0
    TX_PCI_DATA_FETCH_LATENCY                   40
    PF_TOTAL_SF                                 0
    PF_SD_GROUP                                 0
    PF_DEVICE_ID_ENABLE                         False(0)
    PF_SF_BAR_SIZE                              0
    PF_NUM_PF_MSIX                              63
    PF_DEVICE_ID                                4131
    RT_PPS_ENABLED_ON_POWERUP                   False(0)
    LAG_RESOURCE_ALLOCATION                     DEVICE_DEFAULT(0)
    ACCURATE_TX_SCHEDULER                       False(0)
    PARTIAL_RESET_EN                            False(0)
    RESET_WITH_HOST_ON_ERRORS                   False(0)
    USER_PROGRAMMABLE_CC                        False(0)
    NUM_OF_VL_P1                                \_4_VLs(3)
    NUM_OF_TC_P1                                \_8_TCs(0)
    NUM_OF_PFC_P1                               8
    VL15_BUFFER_SIZE_P1                         0
    QOS_TRUST_STATE_P1                          TRUST_PCP(1)
    ETS_SCHED_MODE_P1                           device_default(0)
    VL_BUFFER_ALLOCATION_P1                     FULL_DYNAMIC(1)
    ROCE_NEXT_PROTOCOL                          254
    ROCE_CC_PRIO_MASK_P1                        255
    ROCE_CC_CNP_MODERATION_P1                   DEVICE_DEFAULT(0)
    ROCE_CC_SHAPER_COALESCE_P1                  DEVICE_DEFAULT(0)
    IB_CC_SHAPER_COALESCE_P1                    DEVICE_DEFAULT(0)
    CLAMP_TGT_RATE_AFTER_TIME_INC_P1            True(1)
    CLAMP_TGT_RATE_P1                           False(0)
    RPG_TIME_RESET_P1                           300
    RPG_BYTE_RESET_P1                           32767
    RPG_THRESHOLD_P1                            1
    RPG_MAX_RATE_P1                             0
    RPG_AI_RATE_P1                              5
    RPG_HAI_RATE_P1                             50
    RPG_GD_P1                                   11
    RPG_MIN_DEC_FAC_P1                          50
    RPG_MIN_RATE_P1                             1
    RATE_TO_SET_ON_FIRST_CNP_P1                 0
    DCE_TCP_G_P1                                1019
    DCE_TCP_RTT_P1                              1
    RATE_REDUCE_MONITOR_PERIOD_P1               4
    INITIAL_ALPHA_VALUE_P1                      1023
    MIN_TIME_BETWEEN_CNPS_P1                    4
    CNP_802P_PRIO_P1                            6
    CNP_DSCP_MODE_P1                            DEVICE_DEFAULT(0)
    CNP_DSCP_P1                                 48
    ROCE_RTT_RESP_DSCP_P1                       0
    ROCE_RTT_RESP_DSCP_MODE_P1                  DEVICE_DEFAULT(0)
    BOOT_VLAN                                   1
    LEGACY_BOOT_PROTOCOL                        PXE(1)
    BOOT_INTERRUPT_DIS                          False(0)
    BOOT_LACP_DIS                               True(1)
    BOOT_VLAN_EN                                False(0)
    IP_VER                                      IPv4(0)
    BOOT_UNDI_NETWORK_WAIT                      0
    BOOT_DBG_LOG                                False(0)
    BOOT_PKEY                                   0
    UEFI_HII_EN                                 True(1)
    UEFI_LOGS                                   DISABLED(0)
    LOG_MAX_QUEUE                               17
    DBR_LESS_SQP                                ENABLE(1)
    LOG_MAX_OUTSTANDING_READ_ATOMIC             0
    MULTIPATH_DSCP                              DEVICE_DEFAULT(0)
    SWP_L4_CHECKSUM_MODE                        DEVICE_DEFAULT(0)
    CQE_COMPRESSION                             BALANCED(0)
    IP_OVER_VXLAN_EN                            False(0)
    MKEY_BY_NAME                                False(0)
    PRIO_TAG_REQUIRED_EN                        False(0)
    UCTX_EN                                     True(1)
    REAL_TIME_CLOCK_ENABLE                      False(0)
    RDMA_SELECTIVE_REPEAT_EN                    False(0)
    PCI_ATOMIC_MODE                             PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
    TUNNEL_ECN_COPY_DISABLE                     False(0)
    LRO_LOG_TIMEOUT0                            6
    LRO_LOG_TIMEOUT1                            7
    LRO_LOG_TIMEOUT2                            8
    LRO_LOG_TIMEOUT3                            13
    LOG_TX_PSN_WINDOW                           9
    VF_MIGRATION_MODE                           DEVICE_DEFAULT(0)
    LOG_MAX_OUTSTANDING_WQE                     7
    ROCE_ADAPTIVE_ROUTING_EN                    False(0)
    TUNNEL_IP_PROTO_ENTROPY_DISABLE             False(0)
    INT_LOG_MAX_PAYLOAD_SIZE                    AUTOMATIC(0)
    TPH_STEERING_TAG_TABLE                      DEVICE_DEFAULT(0)
    LINK_TYPE_P1                                IB(1)
    SAFE_MODE_THRESHOLD                         10
    SAFE_MODE_ENABLE                            True(1)
The ‘RO’ shows parameters which are for read only and cannot be changed
cat /sys/class/infiniband/mlx5_0/fw_ver
40.45.1200
flint -d /dev/mst/mt4131_pciconf0 query
Image type: FS5
FW Version: 40.45.1200
FW Release Date: 12.5.2025
Product Version: 40.45.1200
Rom Info: type=UEFI version=14.38.16 cpu=AMD64,AARCH64
                   type=PXE version=3.7.500 cpu=AMD64
Base GUID: cc40f303002f317c 32
Base MAC: cc40f32f317c 32
System GUID: cc40f303002f317c
Node GUID: cc40f303002f317c
Port GUID: cc40f303002f317c
Allocated GUID: 0000000000000000
Image VSD: N/A
Device VSD: N/A
PSID: MT_0000001167
Security Attributes: secure-fw
Socket Direct: Yes
Hi
Sorry that:
CX8 do not suppot 800G ETHERNET right now.
you can check with this link:
Thank you
Meng, Shi
