I guess the title describes the question. Will CUDA recognize a 8800GTS (G92 version) and a 9800GX2 as three identical devices?
Thanks, Skippy
Thanks, Skippy
How identical do you need? The shader and memory clocks are slightly different between the 8800 GTS (G92) and the 9800 GX2.
By a strange coincidence, I happen to have a machine with a 9800 GX2 and a G92 8800 GTS…
64-bit linux CUDA 2.0 beta 174.55 drivers
./deviceQuery
There are 3 devices supporting CUDA
Device 0: "GeForce 9800 GX2"
Major revision number: 1
Minor revision number: 1
Total amount of global memory: 536150016 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.51 GHz
Concurrent copy and execution: Yes
Device 1: "GeForce 9800 GX2"
Total amount of global memory: 536608768 bytes
Warp size: 32
Device 2: "GeForce 8800 GTS 512"
Warp size: 32
Clock rate: 1.67 GHz
All 3 devices seem to work, though I have yet to to exhaustive testing.
I can’t tell you if this works under Vista64 since there you need one monitor per CUDA device and I don’t have 3 monitors to connect.
Note: I had trouble with this setup in 32-bit linux / CUDA 1.1 / latest 174.14.05 drivers. I’m not sure if the trouble was the fact that it was 32-bit linux not being able to address all those cards’ memory or something else. At some point, I’ll try CUDA 2.0 beta there and see if that works, but it’s not a high priority.
Edit: As seibert says, they do have different clock rates so the performance from one device to the next will vary slightly. Otherwise, they should be identical.
Bandwith to the cards is also different, the 9800GX2’s 2 GPU’s have to share the PCI-Express bus.
