tried, now all controllers are listed, but still no NVMe
lspci
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1)
0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13)
0003:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1)
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1)
“lspci -v” reports “lspci: Unable to load libkmod resources: error -12” on one of the controllers, what can cause this?
0000:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33
Bus: primary=00, secondary=01, subordinate=ff, sec-latency=0
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] Express Root Port (Slot-), MSI 00
Capabilities: [b0] MSI-X: Enable- Count=8 Masked-
Capabilities: [100] Advanced Error Reporting
Capabilities: [148] #19
Capabilities: [168] #26
Capabilities: [190] #27
Capabilities: [1c0] L1 PM Substates
Capabilities: [1d0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2d0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [308] #25
Capabilities: [314] Precision Time Measurement
Capabilities: [320] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
Kernel driver in use: pcieport
0001:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 35
I/O behind bridge: 00000000-00000fff
Memory behind bridge: 40000000-400fffff
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
Capabilities: [158] #26
Capabilities: [17c] #27
Capabilities: [190] L1 PM Substates
Capabilities: [1a0] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
Capabilities: [2a0] Vendor Specific Information: ID=0001 Rev=1 Len=038 <?>
Capabilities: [2d8] #25
Capabilities: [2e4] Precision Time Measurement
Capabilities: [2f0] Vendor Specific Information: ID=0004 Rev=1 Len=054 <?>
0001:01:00.0 SATA controller: Marvell Technology Group Ltd. Device 9171 (rev 13) (prog-if 01 [AHCI 1.0])
Subsystem: Marvell Technology Group Ltd. Device 9171
Flags: bus master, fast devsel, latency 0, IRQ 820
I/O ports at 100010 [size=8]
I/O ports at 100020 [size=4]
I/O ports at 100018 [size=8]
I/O ports at 100024 [size=4]
I/O ports at 100000 [size=16]
Memory at 1230010000 (32-bit, non-prefetchable) [size=512]
Expansion ROM at 1230000000 [disabled] [size=64K]
Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Express Legacy Endpoint, MSI 00
Kernel driver in use: ahci
0003:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad2 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 37
0005:00:00.0 PCI bridge: NVIDIA Corporation Device 1ad0 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 39
