To uninstall the driver I ran :
sudo apt purge nvidia-*
And then rebooted. While the machine was booting, programs automatically started: the terminal, Web browser, and evolution. Here is the output of dmesg after reboot, without trying to install a driver for the egpu at all–just with the ExpressCard connected.
[ 0.773763] Loaded X.509 cert 'Canonical Ltd. Secure Boot Signing: 61482aa2830d0ab2ad5af10b7250da9033ddcef0'
[ 0.774280] zswap: loaded using pool lzo/zbud
[ 0.774479] Key type ._fscrypt registered
[ 0.774481] Key type .fscrypt registered
[ 0.774482] Key type fscrypt-provisioning registered
[ 0.778235] Key type encrypted registered
[ 0.778243] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.778251] ima: No TPM chip found, activating TPM-bypass!
[ 0.778257] Loading compiled-in module X.509 certificates
[ 0.779166] Loaded X.509 cert 'Build time autogenerated kernel key: 60d8ae168976e8da9176b1a7b39dd86a29d1fa2c'
[ 0.779169] ima: Allocated hash algorithm: sha1
[ 0.779177] ima: No architecture policies found
[ 0.779189] evm: Initialising EVM extended attributes:
[ 0.779190] evm: security.selinux
[ 0.779191] evm: security.SMACK64
[ 0.779192] evm: security.SMACK64EXEC
[ 0.779193] evm: security.SMACK64TRANSMUTE
[ 0.779194] evm: security.SMACK64MMAP
[ 0.779194] evm: security.apparmor
[ 0.779195] evm: security.ima
[ 0.779196] evm: security.capability
[ 0.779197] evm: HMAC attrs: 0x1
[ 0.779501] PM: Magic number: 6:668:339
[ 0.779790] RAS: Correctable Errors collector initialized.
[ 1.074989] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.094994] usb 2-1: new high-speed USB device number 2 using ehci-pci
[ 1.231009] tsc: Refined TSC clocksource calibration: 2494.334 MHz
[ 1.231025] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x23f45126d86, max_idle_ns: 440795256522 ns
[ 1.231072] clocksource: Switched to clocksource tsc
[ 1.231668] usb 1-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.231690] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.232328] hub 1-1:1.0: USB hub found
[ 1.232651] hub 1-1:1.0: 6 ports detected
[ 1.251747] usb 2-1: New USB device found, idVendor=8087, idProduct=0024, bcdDevice= 0.00
[ 1.251768] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.252326] hub 2-1:1.0: USB hub found
[ 1.252635] hub 2-1:1.0: 6 ports detected
[ 1.355077] ata2.00: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.355096] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 1.357571] ata2.00: ATA-9: HGST HTS545050A7E680, GR2OA350, max UDMA/133
[ 1.357575] ata2.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.362292] ata2.00: configured for UDMA/133
[ 1.539011] usb 2-1.1: new full-speed USB device number 3 using ehci-pci
[ 1.651375] usb 2-1.1: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=30.00
[ 1.651399] usb 2-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.651401] usb 2-1.1: Product: USB Receiver
[ 1.651403] usb 2-1.1: Manufacturer: Logitech
[ 1.731000] usb 2-1.2: new full-speed USB device number 4 using ehci-pci
[ 1.841091] usb 2-1.2: New USB device found, idVendor=2563, idProduct=0575, bcdDevice= 1.00
[ 1.841098] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.841101] usb 2-1.2: Product: Wireless Gamepad
[ 1.841102] usb 2-1.2: Manufacturer: ShanWan
[ 1.919022] ata1.01: failed to resume link (SControl 0)
[ 2.079070] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.079089] ata1.01: SATA link down (SStatus 4 SControl 0)
[ 2.081910] ata1.00: ATA-8: WDC WD3200BPVT-75ZEST0, 01.01A01, max UDMA/133
[ 2.081917] ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 2.087028] ata1.00: configured for UDMA/133
[ 2.087296] scsi 0:0:0:0: Direct-Access ATA WDC WD3200BPVT-7 1A01 PQ: 0 ANSI: 5
[ 2.087767] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.087892] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 2.087899] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 2.087919] sd 0:0:0:0: [sda] Write Protect is off
[ 2.087923] scsi 1:0:0:0: Direct-Access ATA HGST HTS545050A7 A350 PQ: 0 ANSI: 5
[ 2.087923] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.087959] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.088142] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.088199] sd 1:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.088202] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 2.088215] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.088219] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.088243] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.119923] sda: sda1
[ 2.148515] sdb: sdb1 sdb2 sdb3
[ 2.151051] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.187311] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.189888] Freeing unused decrypted memory: 2036K
[ 2.190317] Freeing unused kernel image (initmem) memory: 2900K
[ 2.190376] Write protecting the kernel read-only data: 30720k
[ 2.190933] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 2.191292] Freeing unused kernel image (rodata/data gap) memory: 1788K
[ 2.248967] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.248969] x86/mm: Checking user space page tables
[ 2.303812] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 2.303820] Run /init as init process
[ 2.303822] with arguments:
[ 2.303823] /init
[ 2.303824] splash
[ 2.303825] with environment:
[ 2.303826] HOME=/
[ 2.303827] TERM=linux
[ 2.303828] BOOT_IMAGE=/boot/vmlinuz-5.13.0-40-generic
[ 2.444661] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 2.449230] sdhci: Secure Digital Host Controller Interface driver
[ 2.449236] sdhci: Copyright(c) Pierre Ossman
[ 2.453999] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210331/utaddress-204)
[ 2.454011] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 2.454016] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210331/utaddress-204)
[ 2.454023] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 2.454025] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210331/utaddress-204)
[ 2.454031] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 2.454033] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210331/utaddress-204)
[ 2.454039] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 2.454041] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 2.455433] sdhci-pci 0000:09:00.1: SDHCI controller found [1217:8321] (rev 5)
[ 2.455705] mmc0 bounce up to 128 segments into one, max segment size 65536 bytes
[ 2.456263] mmc0: SDHCI controller on PCI [0000:09:00.1] using DMA
[ 2.496501] hid: raw HID events driver (C) Jiri Kosina
[ 2.501937] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 2.505189] usbcore: registered new interface driver usbhid
[ 2.505194] usbhid: USB HID core driver
[ 2.513332] cryptd: max_cpu_qlen set to 1000
[ 2.513719] i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[ 2.513725] i2c i2c-0: 2/2 memory slots populated (from DMI)
[ 2.515088] firewire_ohci 0000:09:00.0: added OHCI v1.10 device as card 0, 8 IR + 8 IT contexts, quirks 0x10
[ 2.519114] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 2.540858] AVX version of gcm_enc/dec engaged.
[ 2.540888] AES CTR mode by8 optimization enabled
[ 2.541114] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/0003:046D:C52F.0001/input/input7
[ 2.542243] random: fast init done
[ 2.543673] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input0
[ 2.544128] input: Logitech USB Receiver Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C52F.0002/input/input8
[ 2.603133] hid-generic 0003:046D:C52F.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input1
[ 2.603368] input: ShanWan Wireless Gamepad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/0003:2563:0575.0003/input/input11
[ 2.603455] hid-generic 0003:2563:0575.0003: input,hidraw2: USB HID v1.11 Gamepad [ShanWan Wireless Gamepad] on usb-0000:00:1d.0-1.2/input0
[ 2.604551] checking generic (d0000000 410000) vs hw (e0c00000 400000)
[ 2.604557] checking generic (d0000000 410000) vs hw (d0000000 10000000)
[ 2.604559] fb0: switching to inteldrmfb from VESA VGA
[ 2.604691] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 2.607877] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 2.628724] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[ 2.629936] ACPI: video: Video Device [VID] (multi-head: yes rom: no post: no)
[ 2.635320] logitech-djreceiver 0003:046D:C52F.0001: hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input0
[ 2.635663] acpi device:38: registered as cooling_device4
[ 2.636116] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[ 2.651063] fbcon: i915drmfb (fb0) is primary device
[ 2.651067] fbcon: Deferring console take-over
[ 2.651070] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 2.657479] ACPI BIOS Error (bug): Could not resolve symbol [\_PR.CPU0._PPC], AE_NOT_FOUND (20210331/psargs-330)
[ 2.657496]
Initialized Local Variables for Method [PPCE]:
[ 2.657498] Local0: (____ptrval____) <Obj> Integer 0000000000000000
[ 2.657505] Initialized Arguments for Method [PPCE]: (2 arguments defined for method invocation)
[ 2.657506] Arg0: (____ptrval____) <Obj> Integer 0000000000000000
[ 2.657511] Arg1: (____ptrval____) <Obj> Integer 0000000000000000
[ 2.657517] ACPI Error: Aborting method \_PR.PPCE due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
[ 2.657525] ACPI Error: Aborting method \EV3 due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
[ 2.657531] ACPI Error: Aborting method \SMIE due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
[ 2.657537] ACPI Error: Aborting method \NEVT due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
[ 2.657543] ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_NOT_FOUND) (20210331/psparse-529)
[ 2.751467] logitech-djreceiver 0003:046D:C52F.0002: hiddev0,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:1d.0-1.1/input1
[ 2.812460] logitech-djreceiver 0003:046D:C52F.0002: device of type eQUAD step 4 DJ (0x04) connected on slot 1
[ 2.812955] input: Logitech Wireless Mouse PID:4055 Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C52F.0002/0003:046D:4055.0004/input/input13
[ 2.813142] input: Logitech Wireless Mouse PID:4055 Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C52F.0002/0003:046D:4055.0004/input/input14
[ 2.813248] hid-generic 0003:046D:4055.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse PID:4055] on usb-0000:00:1d.0-1.1/input1:1
[ 2.902717] input: Logitech Wireless Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.1/0003:046D:C52F.0002/0003:046D:4055.0004/input/input18
[ 2.902865] logitech-hidpp-device 0003:046D:4055.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:00:1d.0-1.1/input1:1
[ 3.022983] firewire_core 0000:09:00.0: created device fw0: GUID 03462f21384fc000, S400
[ 3.704546] input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio1/input/input6
[ 4.279867] EXT4-fs (sdb3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 5.013172] random: crng init done
[ 9.092422] systemd[1]: Inserted module 'autofs4'
[ 9.965508] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 9.983086] systemd[1]: Detected architecture x86-64.
[ 10.058419] systemd[1]: Set hostname to <anthony-Latitude-E5420>.
[ 15.214095] systemd[1]: Created slice system-modprobe.slice.
[ 15.214396] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 15.214704] systemd[1]: Created slice User and Session Slice.
[ 15.214786] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 15.215040] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 15.215095] systemd[1]: Reached target User and Group Name Lookups.
[ 15.215114] systemd[1]: Reached target Remote File Systems.
[ 15.215127] systemd[1]: Reached target Slices.
[ 15.215282] systemd[1]: Listening on Syslog Socket.
[ 15.215389] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 15.215448] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 15.215666] systemd[1]: Listening on Journal Audit Socket.
[ 15.215770] systemd[1]: Listening on Journal Socket (/dev/log).
[ 15.215893] systemd[1]: Listening on Journal Socket.
[ 15.216009] systemd[1]: Listening on udev Control Socket.
[ 15.216105] systemd[1]: Listening on udev Kernel Socket.
[ 15.217177] systemd[1]: Mounting Huge Pages File System...
[ 15.218285] systemd[1]: Mounting POSIX Message Queue File System...
[ 15.219528] systemd[1]: Mounting Kernel Debug File System...
[ 15.220733] systemd[1]: Mounting Kernel Trace File System...
[ 15.222340] systemd[1]: Starting Journal Service...
[ 15.223679] systemd[1]: Starting Set the console keyboard layout...
[ 15.225589] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 15.225691] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 15.276459] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 15.276522] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 15.352794] systemd[1]: Starting Load Kernel Modules...
[ 15.353996] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 15.355422] systemd[1]: Starting udev Coldplug all Devices...
[ 15.356470] systemd[1]: Starting Uncomplicated firewall...
[ 15.358418] systemd[1]: Mounted Huge Pages File System.
[ 15.358605] systemd[1]: Mounted POSIX Message Queue File System.
[ 15.358759] systemd[1]: Mounted Kernel Debug File System.
[ 15.358930] systemd[1]: Mounted Kernel Trace File System.
[ 15.359487] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 15.425858] systemd[1]: Started Journal Service.
[ 15.540373] EXT4-fs (sdb3): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 16.182959] Adding 2097148k swap on /swapfile. Priority:-2 extents:6 across:2260988k FS
[ 16.331728] lp: driver loaded but no devices found
[ 16.380203] systemd-journald[321]: Received client request to flush runtime journal.
[ 16.460827] ppdev: user-space parallel port driver
[ 16.504627] bpfilter: Loaded bpfilter_umh pid 347
[ 16.504948] Started bpfilter
[ 16.578646] parport_pc 00:04: [io 0x0378-0x037b]
[ 16.578659] parport_pc 00:04: [io 0x0278-0x027b]
[ 16.578666] parport_pc 00:04: [io 0x03bc-0x03bf]
[ 16.578672] parport_pc 00:04: [io 0x0378-0x037b]
[ 16.578765] parport_pc 00:04: [irq 7]
[ 16.580906] parport_pc 00:04: activated
[ 16.580910] parport_pc 00:04: reported by Plug and Play ACPI
[ 16.908843] IPMI message handler: version 39.2
[ 16.966841] ipmi device interface
[ 17.963581] loop0: detected capacity change from 0 to 8
[ 17.983334] loop1: detected capacity change from 0 to 113680
[ 18.096701] loop2: detected capacity change from 0 to 113696
[ 18.217800] loop3: detected capacity change from 0 to 126760
[ 18.300671] loop4: detected capacity change from 0 to 126776
[ 18.507745] loop5: detected capacity change from 0 to 337424
[ 18.531241] loop6: detected capacity change from 0 to 133552
[ 18.784810] loop7: detected capacity change from 0 to 89352
[ 18.919309] loop8: detected capacity change from 0 to 91496
[ 18.995306] loop9: detected capacity change from 0 to 32
[ 19.067300] loop10: detected capacity change from 0 to 32
[ 19.151177] loop11: detected capacity change from 0 to 31072
[ 19.215352] loop12: detected capacity change from 0 to 27680
[ 20.862075] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[ 21.069258] dell-smbios A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[ 21.374583] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input19
[ 21.822373] at24 0-0050: supply vcc not found, using dummy regulator
[ 21.822988] at24 0-0050: 256 byte spd EEPROM, read-only
[ 22.114344] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 163840 ms ovfl timer
[ 22.114349] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[ 22.114351] RAPL PMU: hw unit of domain package 2^-16 Joules
[ 22.114353] RAPL PMU: hw unit of domain pp1-gpu 2^-16 Joules
[ 23.485568] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 23.486153] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 25.664123] dell_laptop: Using i8042 filter function for receiving events
[ 27.144035] intel_rapl_common: Found RAPL domain package
[ 27.144041] intel_rapl_common: Found RAPL domain core
[ 27.144042] intel_rapl_common: Found RAPL domain uncore
[ 27.144049] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 27.163348] wl: loading out-of-tree module taints kernel.
[ 27.163355] wl: module license 'MIXED/Proprietary' taints kernel.
[ 27.163357] Disabling lock debugging due to kernel taint
[ 27.165780] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 27.325191] wlan0: Broadcom BCM4727 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 27.468749] wl 0000:02:00.0 wlp2s0: renamed from wlan0
[ 27.544973] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 27.983833] snd_hda_codec_idt hdaudioC0D0: autoconfig for 92HD90BXX: line_outs=1 (0xe/0x0/0x0/0x0/0x0) type:line
[ 27.983840] snd_hda_codec_idt hdaudioC0D0: speaker_outs=1 (0xd/0x0/0x0/0x0/0x0)
[ 27.983843] snd_hda_codec_idt hdaudioC0D0: hp_outs=1 (0xb/0x0/0x0/0x0/0x0)
[ 27.983845] snd_hda_codec_idt hdaudioC0D0: mono: mono_out=0x0
[ 27.983846] snd_hda_codec_idt hdaudioC0D0: inputs:
[ 27.983848] snd_hda_codec_idt hdaudioC0D0: Dock Mic=0xf
[ 27.983849] snd_hda_codec_idt hdaudioC0D0: Internal Mic=0x11
[ 27.983851] snd_hda_codec_idt hdaudioC0D0: Mic=0xa
[ 28.098571] input: HDA Intel PCH Dock Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[ 28.098671] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[ 28.098765] input: HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[ 28.098855] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
[ 28.099162] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
[ 28.099251] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input25
[ 28.099329] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input26
[ 33.769243] usb 2-1.2: USB disconnect, device number 4
[ 34.030995] usb 2-1.2: new full-speed USB device number 5 using ehci-pci
[ 34.153494] usb 2-1.2: New USB device found, idVendor=045e, idProduct=028e, bcdDevice= 1.10
[ 34.153502] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 34.153504] usb 2-1.2: Product: Xbox360 For Windows
[ 34.153506] usb 2-1.2: Manufacturer: ShanWan
[ 34.153507] usb 2-1.2: SerialNumber: 10F36D6
[ 34.889460] input: Microsoft X-Box 360 pad as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input27
[ 34.889675] usbcore: registered new interface driver xpad
[ 36.201463] audit: type=1400 audit(1652030472.932:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=982 comm="apparmor_parser"
[ 36.201473] audit: type=1400 audit(1652030472.932:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=982 comm="apparmor_parser"
[ 36.214927] audit: type=1400 audit(1652030472.948:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=980 comm="apparmor_parser"
[ 36.237668] audit: type=1400 audit(1652030472.968:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=981 comm="apparmor_parser"
[ 36.237678] audit: type=1400 audit(1652030472.968:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=981 comm="apparmor_parser"
[ 36.237681] audit: type=1400 audit(1652030472.968:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=981 comm="apparmor_parser"
[ 36.405027] audit: type=1400 audit(1652030473.136:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=989 comm="apparmor_parser"
[ 36.451988] audit: type=1400 audit(1652030473.184:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=987 comm="apparmor_parser"
[ 36.508779] audit: type=1400 audit(1652030473.240:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/tcpdump" pid=988 comm="apparmor_parser"
[ 36.531342] audit: type=1400 audit(1652030473.264:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=978 comm="apparmor_parser"
[ 62.406426] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
[ 65.071321] vboxdrv: Found 4 processor cores
[ 65.091176] vboxdrv: TSC mode is Invariant, tentative frequency 2494320189 Hz
[ 65.091183] vboxdrv: Successfully loaded version 6.1.32_Ubuntu r149290 (interface 0x00320000)
[ 65.249717] VBoxNetFlt: Successfully started.
[ 65.578064] VBoxNetAdp: Successfully started.
[ 66.203388] kauditd_printk_skb: 28 callbacks suppressed
[ 66.203392] audit: type=1400 audit(1652030502.936:40): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=1192 comm="cups-browsed" capability=23 capname="sys_nice"
[ 70.303330] loop13: detected capacity change from 0 to 8
[ 151.119639] logitech-hidpp-device 0003:046D:4055.0004: HID++ 4.5 device connected.
[ 184.862533] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:f8:2c:18:ee:e3:c9:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 291.813495] input: Microsoft X-Box 360 pad 0 as /devices/virtual/input/input28
[ 309.888018] [UFW BLOCK] IN=wlp2s0 OUT= MAC=01:00:5e:00:00:01:f8:2c:18:ee:e3:c9:08:00 SRC=192.168.1.254 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
[ 347.202348] pci 0000:03:00.0: [10de:1d01] type 00 class 0x030000
[ 347.202428] pci 0000:03:00.0: reg 0x10: [mem 0x00000000-0x00ffffff]
[ 347.202476] pci 0000:03:00.0: reg 0x14: [mem 0x00000000-0x0fffffff 64bit pref]
[ 347.202532] pci 0000:03:00.0: reg 0x1c: [mem 0x00000000-0x01ffffff 64bit pref]
[ 347.202552] pci 0000:03:00.0: reg 0x24: [io 0x0000-0x007f]
[ 347.202577] pci 0000:03:00.0: reg 0x30: [mem 0x00000000-0x0007ffff pref]
[ 347.203203] pci 0000:03:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:1c.2 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 347.203413] pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 347.203420] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 347.203521] pci 0000:03:00.1: [10de:0fb8] type 00 class 0x040300
[ 347.203573] pci 0000:03:00.1: reg 0x10: [mem 0x00000000-0x00003fff]
[ 347.204125] pci_bus 0000:01: Allocating resources
[ 347.204131] pcieport 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 347.204136] pcieport 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 347.204142] pcieport 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 347.204155] pci_bus 0000:02: Allocating resources
[ 347.204163] pcieport 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 347.204168] pcieport 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 347.204179] pci_bus 0000:03: Allocating resources
[ 347.204203] pci_bus 0000:09: Allocating resources
[ 347.204229] pcieport 0000:00:1c.5: bridge window [io 0x1000-0x0fff] to [bus 09] add_size 1000
[ 347.204233] pcieport 0000:00:1c.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 09] add_size 200000 add_align 100000
[ 347.204246] pcieport 0000:00:1c.0: BAR 14: assigned [mem 0xcfa00000-0xcfbfffff]
[ 347.204255] pcieport 0000:00:1c.0: BAR 15: assigned [mem 0xcfc00000-0xcfdfffff 64bit pref]
[ 347.204261] pcieport 0000:00:1c.1: BAR 15: assigned [mem 0xcfe00000-0xcfffffff 64bit pref]
[ 347.204267] pcieport 0000:00:1c.5: BAR 15: assigned [mem 0xe0a00000-0xe0bfffff 64bit pref]
[ 347.204273] pcieport 0000:00:1c.0: BAR 13: assigned [io 0x4000-0x4fff]
[ 347.204278] pcieport 0000:00:1c.1: BAR 13: assigned [io 0x5000-0x5fff]
[ 347.204283] pcieport 0000:00:1c.5: BAR 13: assigned [io 0x6000-0x6fff]
[ 347.204295] pci 0000:03:00.0: BAR 1: no space for [mem size 0x10000000 64bit pref]
[ 347.204298] pci 0000:03:00.0: BAR 1: failed to assign [mem size 0x10000000 64bit pref]
[ 347.204304] pci 0000:03:00.0: BAR 3: no space for [mem size 0x02000000 64bit pref]
[ 347.204307] pci 0000:03:00.0: BAR 3: failed to assign [mem size 0x02000000 64bit pref]
[ 347.204310] pci 0000:03:00.0: BAR 0: no space for [mem size 0x01000000]
[ 347.204313] pci 0000:03:00.0: BAR 0: failed to assign [mem size 0x01000000]
[ 347.204317] pci 0000:03:00.0: BAR 6: assigned [mem 0xe1000000-0xe107ffff pref]
[ 347.204321] pci 0000:03:00.1: BAR 0: assigned [mem 0xe1080000-0xe1083fff]
[ 347.204332] pci 0000:03:00.0: BAR 5: assigned [io 0x2000-0x207f]
[ 347.204470] pci 0000:03:00.1: D0 power state depends on 0000:03:00.0
[ 347.204757] snd_hda_intel 0000:03:00.1: enabling device (0000 -> 0002)
[ 347.204879] snd_hda_intel 0000:03:00.1: Disabling MSI
[ 347.204888] snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
[ 347.499246] nouveau 0000:03:00.0: enabling device (0000 -> 0001)
[ 347.499337] nouveau 0000:03:00.0: unable to map PRI
[ 347.499345] nouveau: probe of 0000:03:00.0 failed with error -12
[ 348.218141] snd_hda_intel 0000:03:00.1: azx_get_response timeout, switching to polling mode: last cmd=0x001f000f
[ 349.226140] snd_hda_intel 0000:03:00.1: azx_get_response timeout, switching to single_cmd mode: last cmd=0x001f000f
[ 349.233180] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1c.2/0000:03:00.1/sound/card1/input29
[ 349.233363] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1c.2/0000:03:00.1/sound/card1/input30
[ 349.233494] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1c.2/0000:03:00.1/sound/card1/input31
[ 349.233623] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1c.2/0000:03:00.1/sound/card1/input32
[ 349.233751] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1c.2/0000:03:00.1/sound/card1/input33
[ 354.876247] pci_bus 0000:01: Allocating resources
[ 354.876260] pci_bus 0000:02: Allocating resources
[ 354.876273] pci_bus 0000:03: Allocating resources
[ 354.876293] pci_bus 0000:09: Allocating resources
anthony@anthony-Latitude-E5420:~$
