Hello Guys,
While integrating CloudXR 3.2 library with Hello XR test application, I’m facing Fatal error as below :
A/libc: Fatal signal 11 (SIGSEGV), code 2 (SEGV_ACCERR), fault addr 0x73a6c78498 in tid 5478 (Thread-3), pid 5442 (llo_xr.opengles)
So, I checked that error in detail and found below logs :
F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
11-02 16:05:19.619 7269 7269 F DEBUG : Build fingerprint: '---'
11-02 16:05:19.619 7269 7269 F DEBUG : Revision: '0'
11-02 16:05:19.619 7269 7269 F DEBUG : ABI: 'arm64'
11-02 16:05:19.619 7269 7269 F DEBUG : Timestamp: 2022-11-02 16:05:19+0530
11-02 16:05:19.619 7269 7269 F DEBUG : pid: 7118, tid: 7154, name: Thread-3 >>> com.khronos.openxr.hello_xr.opengles <<<
11-02 16:05:19.619 7269 7269 F DEBUG : uid: 10120
11-02 16:05:19.619 7269 7269 F DEBUG : signal 11 (SIGSEGV), code 2 (SEGV_ACCERR), fault addr 0x77fadf4498
11-02 16:05:19.619 7269 7269 F DEBUG : x0 0000000000000001 x1 00000000000030f9 x2 0000000000000000 x3 ffffffff9c9db8f3
11-02 16:05:19.619 7269 7269 F DEBUG : x4 0029fd0a8c000000 x5 00676e61766564ff x6 00000078e79e2000 x7 000000000001abbe
11-02 16:05:19.619 7269 7269 F DEBUG : x8 00000077f9cf9000 x9 0000000000000000 x10 0000000000000001 x11 0000000000000000
11-02 16:05:19.619 7269 7269 F DEBUG : x12 c4c6055984d72f78 x13 00000000636247e7 x14 002114a0be738400 x15 00003da43b94f057
11-02 16:05:19.619 7269 7269 F DEBUG : x16 00000077f9cf8c08 x17 00000077fadf4498 x18 ffffffffffffffed x19 00000077c117d798
11-02 16:05:19.619 7269 7269 F DEBUG : x20 00000077f1a23508 x21 00000077f1a23500 x22 0000007854dc6418 x23 0000007854dc6dd8
11-02 16:05:19.619 7269 7269 F DEBUG : x24 0000007854a16470 x25 0000000000000038 x26 c0c0c0c0c0c0c0c1 x27 00000000000000aa
11-02 16:05:19.619 7269 7269 F DEBUG : x28 0000000000000018 x29 0000007854dc63a0
11-02 16:05:19.619 7269 7269 F DEBUG : sp 0000007854dc6390 lr 00000077f9cabd9c pc 00000077fadf4498
11-02 16:05:19.620 1124 4204 I SCVIS : erase keyframe: 6017
From above logs I found below backtrace :
11-02 16:05:19.712 7269 7269 F DEBUG : #00 pc 0000000000000498 /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk
11-02 16:05:19.712 7269 7269 F DEBUG : #01 pc 0000000000009d98 /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk!libCloudXRClient.so (offset 0x12a000) (BuildId: 073d0a27c1a66952e321cc2628e4408f403874f2)
11-02 16:05:19.712 7269 7269 F DEBUG : #02 pc 000000000000920c /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk!libCloudXRClient.so (offset 0x12a000) (BuildId: 073d0a27c1a66952e321cc2628e4408f403874f2)
11-02 16:05:19.712 7269 7269 F DEBUG : #03 pc 000000000002c7e0 /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk!libCloudXRClient.so (offset 0x12a000) (BuildId: 073d0a27c1a66952e321cc2628e4408f403874f2)
11-02 16:05:19.712 7269 7269 F DEBUG : #04 pc 00000000000a193c /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk (offset 0x247000) (CloudXRClient::ReleaseFrame(cxrFramesLatched*)+144) (BuildId: 510a277ecea060082666b98d85ebf9afd015de55)
11-02 16:05:19.712 7269 7269 F DEBUG : #05 pc 0000000000138da4 /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk (offset 0x247000) (BuildId: 510a277ecea060082666b98d85ebf9afd015de55)
11-02 16:05:19.712 7269 7269 F DEBUG : #06 pc 000000000012351c /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk (offset 0x247000) (BuildId: 510a277ecea060082666b98d85ebf9afd015de55)
11-02 16:05:19.712 7269 7269 F DEBUG : #07 pc 000000000011c780 /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk (offset 0x247000) (android_main+1368) (BuildId: 510a277ecea060082666b98d85ebf9afd015de55)
11-02 16:05:19.712 7269 7269 F DEBUG : #08 pc 000000000009c69c /data/app/com.khronos.openxr.hello_xr.opengles-BL8dquyP12iKu3S5x401HQ==/base.apk (offset 0x247000) (BuildId: 510a277ecea060082666b98d85ebf9afd015de55)
11-02 16:05:19.712 7269 7269 F DEBUG : #09 pc 00000000000e68a0 /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+36) (BuildId: 21847aa9757f000b0461310a9f5e6e51)
11-02 16:05:19.712 7269 7269 F DEBUG : #10 pc 0000000000084b6c /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+64) (BuildId: 21847aa9757f000b0461310a9f5e6e51)
Based on above backtrace I found that app is crashing on CloudXRClient::ReleaseFrame(cxrFramesLatched*) method.
That method code is as below :
cxrReleaseFrame(Receiver, framesLatched);
So, basically its crashing on Releasing Frame and that method is inside libCloudXRClient.so file.
Note : the same Cloud XR library working fine with diff. demo code for us for release frame.
Please provide solution on this asap.
Thanks & Regards,
Devang
