I am getting this error while building project for Oculus VR with all right dependencies:
Execution failed for task ‘:app:generateJsonModelDebug’.
Build command failed.
Error while executing process C:\Users\SDONGRE1\AppData\Local\Android\Sdk\ndk\21.4.7075529\ndk-build.cmd with arguments {NDK_PROJECT_PATH=null APP_BUILD_SCRIPT=D:\CloudXR4\OculusVR\app\src\main\jni\Android.mk NDK_APPLICATION_MK=D:\CloudXR4\OculusVR\app\src\main\jni\Application.mk APP_ABI=arm64-v8a NDK_ALL_ABIS=arm64-v8a NDK_DEBUG=1 APP_PLATFORM=android-24 NDK_OUT=D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj NDK_LIBS_OUT=D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib OVR_SDK_ROOT=D:\CloudXR4\OculusVR\app\build\ovr_sdk OBOE_SDK_ROOT=D:\CloudXR4\OculusVR\app\build\Oboe CLOUDXR_SDK_ROOT=D:\CloudXR4\OculusVR\app\build\CloudXR C_SHARED_INCLUDE=D:\shared -j4 NDK_DEBUG=1 APP_SHORT_COMMANDS=false LOCAL_SHORT_COMMANDS=false -B -n}
md “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib\arm64-v8a” >NUL 2>NUL || rem
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Gdbserver ": “[aarch64-linux-android] D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/gdbserver”
copy /b/y “C:\Users\SDONGRE1\AppData\Local\Android\Sdk\ndk\21.4.7075529\build\…\prebuilt\android-arm64\gdbserver\gdbserver” “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib\arm64-v8a\gdbserver” > NUL
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Gdbsetup ": “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/gdb.setup”
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe “set solib-search-path D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj/local/arm64-v8a” > D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/gdb.setup
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe “directory C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/sysroot D:/CloudXR4/OculusVR/app/src/main/jni D:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/OVR/Include D:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/utilities/include D:\CloudXR4\OculusVR\app\build\ovr_sdk/3rdParty/stb/src D:\CloudXR4\OculusVR\app\build\Oboe/prefab/modules/oboe/include D:\shared D:\CloudXR4\OculusVR\app\build\CloudXR/include …/src C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/android/native_app_glue D:/CloudXR4/OculusVR/app/build/ovr_sdk/VrApi/Projects/AndroidPrebuilt/jni/…/…/…/Include C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/include C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/…/llvm-libc++abi/include C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++abi/include” >> D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/gdb.setup
md “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\obj\local\arm64-v8a” >NUL 2>NUL || rem
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Prebuilt ": “libCloudXRClient.so <= D:\CloudXR4\OculusVR\app\build\CloudXR/jni/arm64-v8a/”
copy /b/y “D:\CloudXR4\OculusVR\app\build\CloudXR\jni\arm64-v8a\libCloudXRClient.so” “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\obj\local\arm64-v8a\libCloudXRClient.so” > NUL
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Install ": “libCloudXRClient.so => D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/libCloudXRClient.so”
copy /b/y “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\obj\local\arm64-v8a\libCloudXRClient.so” “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib\arm64-v8a\libCloudXRClient.so” > NUL
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/bin/aarch64-linux-android-strip --strip-unneeded D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\lib/arm64-v8a/libCloudXRClient.so
md “D:\CloudXR4\OculusVR\app\build\intermediates\ndkBuild\debug\obj\local\arm64-v8a\objs-debug\CloudXRClientOVR__\src” >NUL 2>NUL || rem
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Compile++ ": “CloudXRClientOVR <= main.cpp”
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++.exe -MMD -MP -MF D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj/local/arm64-v8a/objs-debug/CloudXRClientOVR//src/main.o.d -target aarch64-none-linux-android24 -fdata-sections -ffunction-sections -fstack-protector-strong -funwind-tables -no-canonical-prefixes --sysroot C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/sysroot -g -Wno-invalid-command-line-argument -Wno-unused-command-line-argument -D_FORTIFY_SOURCE=2 -fno-exceptions -fno-rtti -fpic -O0 -UNDEBUG -fno-limit-debug-info -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/OVR/Include -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/utilities/include -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/3rdParty/stb/src -ID:\CloudXR4\OculusVR\app\build\Oboe/prefab/modules/oboe/include -ID:\shared -ID:\CloudXR4\OculusVR\app\build\CloudXR/include -I…/src -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/android/native_app_glue -ID:/CloudXR4/OculusVR/app/build/ovr_sdk/VrApi/Projects/AndroidPrebuilt/jni/…/…/…/Include -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/include -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/…/llvm-libc++abi/include -ID:/CloudXR4/OculusVR/app/src/main/jni -DANDROID -nostdinc++ -Wformat -Werror=format-security -fno-strict-aliasing -fexceptions -c D:/CloudXR4/OculusVR/app/src/main/jni/…/src/main.cpp -o D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj/local/arm64-v8a/objs-debug/CloudXRClientOVR//src/main.o
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/prebuilt/windows-x86_64/bin/echo.exe [arm64-v8a] "Compile++ ": “CloudXRClientOVR <= EGLHelper.cpp”
C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/bin/clang++.exe -MMD -MP -MF D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj/local/arm64-v8a/objs-debug/CloudXRClientOVR//src/EGLHelper.o.d -target aarch64-none-linux-android24 -fdata-sections -ffunction-sections -fstack-protector-strong -funwind-tables -no-canonical-prefixes --sysroot C:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/toolchains/llvm/prebuilt/windows-x86_64/sysroot -g -Wno-invalid-command-line-argument -Wno-unused-command-line-argument -D_FORTIFY_SOURCE=2 -fno-exceptions -fno-rtti -fpic -O0 -UNDEBUG -fno-limit-debug-info -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/OVR/Include -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/1stParty/utilities/include -ID:\CloudXR4\OculusVR\app\build\ovr_sdk/3rdParty/stb/src -ID:\CloudXR4\OculusVR\app\build\Oboe/prefab/modules/oboe/include -ID:\shared -ID:\CloudXR4\OculusVR\app\build\CloudXR/include -I…/src -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/android/native_app_glue -ID:/CloudXR4/OculusVR/app/build/ovr_sdk/VrApi/Projects/AndroidPrebuilt/jni/…/…/…/Include -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/include -IC:/Users/SDONGRE1/AppData/Local/Android/Sdk/ndk/21.4.7075529/build//…/sources/cxx-stl/llvm-libc++/…/llvm-libc++abi/include -ID:/CloudXR4/OculusVR/app/src/main/jni -DANDROID -nostdinc++ -Wformat -Werror=format-security -fno-strict-aliasing -fexceptions -c D:/CloudXR4/OculusVR/app/src/main/jni/…/src/EGLHelper.cpp -o D:/CloudXR4/OculusVR/app/build/intermediates/ndkBuild/debug/obj/local/arm64-v8a/objs-debug/CloudXRClientOVR//src/EGLHelper.o
Does anyone have the pre-built APK for quest 3?
