An updated version that installs jtop on Thor without having to “install jetson-stats --break-system-packages”. It now includes fixes to some of the python code to more accurately reflect values of Thor in jtop. Here’s two bash shell scripts that will clone github.com/rbonghi/jetson_stats make modifications to enable JTOP to be run with ‘sudo jtop’ on Jetson Thor and modify the python files to allow jtop to report on Thor. The idea to use NVML to access Thor came from eous’ pr github.com/rbonghi/jetson_stats/pull/698 that I saw after I had done my pr 699 yesterday.
This is the updated setup_Jtop_thor.sh.txt (5.7 KB) that now also calls
patch_thor_jp7_in_repo.sh.txt (13.4 KB)
Save the two files .txt files into the same directory on your Thor as .sh then
chmod +x *.sh
sudo ./setup_Jtop_thor.sh
Then run jtop normally
sudo jtop
The content of the files are:
cat setup_Jtop_thor.sh
#!/usr/bin/env bash
# Setup jtop in a root-owned venv at /opt/jtop with Thor edits applied
# Tested on Ubuntu 24.04 (JetPack 7.x base)
set -euo pipefail
JTOP_ROOT="/opt/jtop"
VENV_DIR="$JTOP_ROOT/venv"
REPO_DIR="$JTOP_ROOT/jetson_stats"
SERVICE_PATH="/etc/systemd/system/jtop.service"
REPO_URL="https://github.com/rbonghi/jetson_stats.git"
need_root() {
if [[ "$(id -u)" != "0" ]]; then
echo "Please run as root (e.g., sudo bash $0)"
exit 1
fi
log() { echo -e "\e[1;32m==>\e[0m $*"; }
warn() { echo -e "\e[1;33m[warn]\e[0m $*"; }
info() { echo -e "\e[1;34m[info]\e[0m $*"; }
install_prereqs() {
log "Installing prerequisites (python3.12-venv, git)…"
apt-get update -y
# Prefer python3.12-venv (Noble default); fallback to python3-venv if needed
if ! apt-get install -y python3.12-venv git; then
warn "python3.12-venv not found; trying python3-venv"
apt-get install -y python3-venv git
fi
create_venv() {
log "Creating root-owned venv at $VENV_DIR"
mkdir -p "$JTOP_ROOT"
if [[ ! -d "$VENV_DIR" ]]; then
python3 -m venv "$VENV_DIR"
else
info "Venv already exists: $VENV_DIR"
fi
"$VENV_DIR/bin/python" -m pip install --upgrade pip setuptools wheel
clone_repo() {
log "Cloning jetson_stats into $REPO_DIR"
if [[ -d "$REPO_DIR/.git" ]]; then
info "Repo exists, pulling latest…"
git -C "$REPO_DIR" fetch --all --tags
git -C "$REPO_DIR" reset --hard origin/master
else
git clone --depth=1 "$REPO_URL" "$REPO_DIR"
fi
apply_thor_edits() {
log "Applying Thor edits to repository files"
local f_vars="$REPO_DIR/jtop/core/jetson_variables.py"
local f_gh="$REPO_DIR/jtop/github.py"
local f_svc="$REPO_DIR/services/jtop.service"
for f in "$f_vars" "$f_gh" "$f_svc"; do
[[ -f "$f" ]] || { echo "ERROR: Missing $f"; exit 1; }
cp -a "$f" "$f.bak.$(date +%Y%m%d-%H%M%S)"
done
# jetson_variables.py edits
# Add JP/L4T mappings
grep -qE '^\s*"38\.2\.0":\s*"7\.0",' "$f_vars" || \
sed -i '/# -------- JP6 --------/a\ "38.2.0": "7.0",' "$f_vars"
grep -qE '^\s*"36\.4\.4":\s*"6\.2\.1",' "$f_vars" || \
sed -i '/# -------- JP6 --------/a\ "36.4.4": "6.2.1",' "$f_vars"
# Add CUDA_TABLE tegra264
grep -qE "^\s*'tegra264':\s*'13\.0'," "$f_vars" || \
sed -i "/'tegra234':/i\ 'tegra264': '13.0', # JETSON THOR - tegra264" "$f_vars"
# Add MODULE_NAME_TABLE p3834-0008
grep -qE "^\s*'p3834-0008':\s*'NVIDIA Jetson AGX Thor \(Developer kit\)'," "$f_vars" || \
sed -i "/'p3767-0005':/i\ 'p3834-0008': 'NVIDIA Jetson AGX Thor (Developer kit)'," "$f_vars"
# services/jtop.service in repo: ensure only venv ExecStart
# Replace /usr/local/bin path with venv path if present
if grep -q '^ExecStart=/usr/local/bin/jtop --force$' "$f_svc"; then
sed -i 's#^ExecStart=/usr/local/bin/jtop --force#ExecStart=/opt/jtop/venv/bin/jtop --force#' "$f_svc"
fi
# Remove any duplicate /usr/local/bin ExecStart lines
sed -i '/^ExecStart=\/usr\/local\/bin\/jtop --force$/d' "$f_svc"
# Ensure one venv ExecStart exists after Environment= line
grep -q '^ExecStart=/opt/jtop/venv/bin/jtop --force$' "$f_svc" || \
sed -i '/^Environment="JTOP_SERVICE=True"$/a\ExecStart=/opt/jtop/venv/bin/jtop --force' "$f_svc"
log "Thor edits applied."
install_python_fixes() {
set -euo pipefail
local repo="/opt/jtop/jetson_stats"
local patch="$(dirname "$0")/patch_thor_jp7_in_repo.sh" # patch in same dir as instant one.
log "Installing python script changes for Jetson Thor (JP7.0) in: $repo"
[[ -d "$repo/.git" && -d "$repo/jtop" ]] || {
echo "ERROR: $repo does not look like a jetson_stats clone"; return 1; }
chmod +x "$patch"
# Run as its own process; it will sudo itself if needed.
"$patch" "$repo"
install_package() {
log "Installing jetson_stats into the venv"
"$VENV_DIR/bin/python" -m pip install --no-cache-dir -U "$REPO_DIR"
install_nvml() {
set -euo pipefail
log "Installing NVML bindings (pynvml) into the venv"
: "${VENV_DIR:?VENV_DIR must be set (e.g. /opt/jtop/venv)}"
local py="$VENV_DIR/bin/python"
if [[ ! -x "$py" ]]; then
echo "ERROR: $py not found/executable" >&2
return 1
fi
"$py" -m pip install -U nvidia-ml-py3
install_service() {
log "Installing systemd service at $SERVICE_PATH"
cat >"$SERVICE_PATH" <<'EOF'
# Jetson Stats (jtop) systemd unit using root-owned venv at /opt/jtop/venv
[Unit]
Description=Jetson Stats (jtop)
After=network.target multi-user.target
[Service]
Type=simple
Restart=on-failure
RestartSec=10s
TimeoutStartSec=30s
TimeoutStopSec=30s
[Install]
WantedBy=multi-user.target
EOF
# Wrapper so `sudo jtop` works nicely from PATH
log "Installing /usr/local/bin/jtop wrapper"
install -m 0755 -o root -g root /dev/stdin /usr/local/bin/jtop <<'EOF'
#!/bin/sh
exec /opt/jtop/venv/bin/jtop "$@"
EOF
# Create system group (ok if it already exists)
groupadd --system jtop 2>/dev/null || true
log "Reloading/Enabling/Restarting service"
systemctl daemon-reload
systemctl enable jtop.service
systemctl restart jtop.service || true
systemctl is-active --quiet jtop.service && log "jtop.service is active" || warn "jtop.service not active yet"
show_summary() {
echo
log "Done."
echo "Quick checks:"
echo " systemctl status jtop.service --no-pager"
echo " journalctl -u jtop --no-pager -e"
echo
echo "Run interactively with:"
echo " sudo jtop"
main() {
need_root
install_prereqs
create_venv
clone_repo
apply_thor_edits
install_package
install_nvml
install_service
show_summary
main "$@"
#!/usr/bin/env bash
# patch_thor_jp7_in_repo.sh
# Patch a cloned jetson_stats repo for Jetson Thor on JetPack 7.0
# - Writes drop-in GPU shim (NVML-first, devfreq fallback) compatible with legacy GUI/service
# - Updates jetson_variables.py for Thor/JP7 mappings
# - Tweaks jtop/github.py message
# - Don't run script independently. It is called from setup_Jtop_thor.sh
set -euo pipefail
if [[ ${EUID:-$(id -u)} -ne 0 ]]; then
exec sudo -E bash "$0" "$@"
fi
REPO_ROOT="${1:-}"
if [[ -z "$REPO_ROOT" ]]; then
echo "ERROR: pass path to your cloned jetson_stats repo (e.g., /opt/jtop/jetson_stats)" >&2
exit 1
fi
REPO_ROOT="${REPO_ROOT%/}"
[[ -d "$REPO_ROOT/jtop" ]] || { echo "ERROR: $REPO_ROOT does not look like a jetson_stats repo"; exit 1; }
ts() { date +%Y%m%d-%H%M%S; }
bk() { local f="$1"; [[ -f "$f" ]] && cp -a "$f" "$f.bak.$(ts)" || true; }
echo "==> Patching repo at: $REPO_ROOT"
# 1) Write drop-in GPU shim
GPU_PY="$REPO_ROOT/jtop/core/gpu.py"
mkdir -p "$(dirname "$GPU_PY")"
bk "$GPU_PY"
cat >"$GPU_PY" <<'PY'
# SPDX-License-Identifier: AGPL-3.0
# GPU shim for Jetson Thor / JetPack 7:
# - Prefer NVML (pynvml) for detection/metrics
# - Thanks to eous' jetson_stats pr that pointed the way to nvidia-ml-py3 (pynvml)
# - Fallback to /sys/class/devfreq (gpu-gpc-0)
# - Exposes legacy hooks/shape used by jtop service & GUI
from __future__ import annotations
import os, re, glob
try:
from .exceptions import JtopException # type: ignore
except Exception: # pragma: no cover
class JtopException(Exception): pass
def _read_int(p: str, d=None):
try:
with open(p) as f: return int(f.read().strip())
except Exception:
return d
def _read_str(p: str, d=None):
try:
with open(p) as f: return f.read().strip()
except Exception:
return d
def _exists(p: str) -> bool:
try: return os.path.exists(p)
except Exception: return False
def _compat_find_3d_scaling(sysfs_path: str | None) -> bool:
try:
if not sysfs_path: return False
p = os.path.join(sysfs_path, "device")
for _ in range(6):
cand = os.path.join(p, "enable_3d_scaling")
try:
with open(cand) as f:
v = f.read().strip()
return v in ("1","Y","y","true","True")
except Exception:
p = os.path.dirname(p)
return False
except Exception:
return False
def _compat_find_railgate(sysfs_path: str | None) -> bool:
try:
candidates = ("railgate_enable", "railgate", os.path.join("power","railgate"), os.path.join("power","railgate_enable"))
for _ in range(6):
for rel in candidates:
cand = os.path.join(p, rel)
try:
except Exception:
pass
return False
except Exception:
return False
def _i(x):
try:
return 0 if x is None else int(x)
except Exception:
return 0
def _build_entry(flat: dict) -> dict:
"""Return nested entry + top-level aliases expected by GUI."""
t = flat.get("type") or "integrated"
cur = _i(flat.get("cur_freq"))
mx = _i(flat.get("max_freq"))
mn = _i(flat.get("min_freq"))
gov = flat.get("governor")
online = bool(flat.get("online"))
load = _i(flat.get("load"))
scaling3d = _compat_find_3d_scaling(flat.get("sysfs_path"))
railgate = _compat_find_railgate(flat.get("sysfs_path"))
nested = {
"type": t,
"status": {
"online": online,
"load": load,
"3d_scaling": scaling3d,
"railgate": railgate,
"freq": {"cur": cur, "max": mx, "min": mn},
"cur_freq": cur,
"max_freq": mx,
"min_freq": mn,
"governor": gov,
"info": {
"name": flat.get("name"),
"product": flat.get("product"),
"memory_total": flat.get("memory_total"),
"memory_used": flat.get("memory_used"),
"source": flat.get("source"),
"sysfs_path": flat.get("sysfs_path"),
# Top-level aliases used by older GUI code
nested["freq"] = nested["status"]["freq"]
nested["online"] = online
nested["load"] = load
nested["cur_freq"] = cur
nested["max_freq"] = mx
nested["min_freq"] = mn
nested["governor"] = gov
nested["3d_scaling"] = scaling3d
nested["railgate"] = railgate
scaling_str = "Active" if scaling3d else "Disable"
railgate_str = "Active" if railgate else "Disable"
nested["power_control"] = f"3D-scaling: {scaling_str} | Railgate: {railgate_str}"
nested["name"] = nested["info"]["name"]
nested["product"] = nested["info"]["product"]
return nested
class GPU(dict):
"""NVML-first, devfreq-fallback GPU map with legacy GUI/service compatibility."""
def __init__(self):
super().__init__()
self._nvml_ok = False
self._nvml = None
try:
import pynvml as _nvml
_nvml.nvmlInit()
self._nvml = _nvml
self._nvml_ok = True
except Exception:
self._nvml = None
self.update()
# discovery paths
def _read_nvml(self) -> dict:
nv = self._nvml
if not nv: return {}
out = {}
try:
count = nv.nvmlDeviceGetCount()
except Exception:
return {}
for idx in range(count):
try:
h = nv.nvmlDeviceGetHandleByIndex(idx)
pname = nv.nvmlDeviceGetName(h)
if isinstance(pname, bytes): pname = pname.decode(errors="ignore")
try:
util = nv.nvmlDeviceGetUtilizationRates(h).gpu
except Exception:
util = None
def _clk(t):
try: return int(nv.nvmlDeviceGetClockInfo(h, t)) * 1_000_000
except Exception: return None
cur = _clk(nv.NVML_CLOCK_GRAPHICS)
try:
mx = int(nv.nvmlDeviceGetMaxClockInfo(h, nv.NVML_CLOCK_GRAPHICS)) * 1_000_000
except Exception:
mx = None
try:
mem = nv.nvmlDeviceGetMemoryInfo(h)
mt, mu = int(mem.total), int(mem.used)
except Exception:
mt = mu = None
key = f"gpu{idx}"
out[key] = {
"name": key,
"product": pname,
"source": "nvml",
"online": True,
"load": 0 if util is None else int(util),
"cur_freq": cur,
"max_freq": mx,
"min_freq": None,
"governor": None,
"sysfs_path": None,
"memory_total": mt,
"memory_used": mu,
"type": "integrated",
except Exception:
continue
return out
def _read_sysfs(self) -> dict:
base = "/sys/class/devfreq"
if not _exists(base): return {}
nodes = []
for d in glob.glob(os.path.join(base, "*")):
name = None
npath = os.path.join(d, "device", "of_node", "name")
if _exists(npath): name = _read_str(npath, None)
if not name: name = os.path.basename(d)
if (re.match(r"^g[a-z0-9]+b$", name or "") is not None) or name == "gpu" or (name or "").startswith("gpu-"):
nodes.append((name, d))
out = {}
for idx, (name, path) in enumerate(nodes):
key = name if name else f"gpu{idx}"
out[key] = {
"name": key,
"product": None,
"source": "sysfs",
"online": True,
"load": _read_int(os.path.join(path, "load")) or 0,
"cur_freq": _read_int(os.path.join(path, "cur_freq")),
"max_freq": _read_int(os.path.join(path, "max_freq")),
"min_freq": _read_int(os.path.join(path, "min_freq")),
"governor": _read_str(os.path.join(path, "governor")),
"sysfs_path": path,
"memory_total": None,
"memory_used": None,
return out
# public / legacy API
def update(self):
try:
flat = self._read_nvml() if self._nvml_ok else {}
if not flat:
flat = self._read_sysfs()
except Exception:
flat = {}
try:
self.clear()
for k, v in (flat or {}).items():
self[k] = _build_entry(v if isinstance(v, dict) else {})
except Exception:
pass
refresh = update
def get_status(self) -> dict:
"""Return nested snapshot (GUI/service expected shape)."""
try:
self.update()
except Exception:
pass
return {k: dict(v) if isinstance(v, dict) else v for k, v in self.items()}
# Legacy hooks
def _initialize(self, controller): # jtop.py expects this
try: self._controller = controller
except Exception: pass
try: self.update()
def _finalize(self): # jtop.py expects this
return None
def _update(self, dest: dict): # jtop.py expects this
snap = {}
try: snap = self.get_status()
if isinstance(dest, dict):
dest.clear()
dest.update(snap or {})
return dest
# Legacy alias for service.py
class GPUService(GPU):
"""Compatibility alias with same behavior as GPU."""
pass
# Legacy helper for github.py diagnostics
def get_raw_igpu_devices():
devices = []
if os.path.isdir(base):
for d in sorted(glob.glob(os.path.join(base, "*"))):
name_path = os.path.join(d, "device", "of_node", "name")
name = _read_str(name_path, None) or os.path.basename(d)
devices.append(d)
try:
import pynvml as nv
nv.nvmlInit()
try:
for i in range(count):
devices.append(f"nvml:gpu{i}")
finally:
try: nv.nvmlShutdown()
except Exception:
pass
return devices
PY
echo " wrote $GPU_PY"
# 2) Patch jetson_variables.py for (Thor & JP7)
VARS_PY="$REPO_ROOT/jtop/core/jetson_variables.py"
if [[ -f "$VARS_PY" ]]; then
bk "$VARS_PY"
# JP/L4T->JetPack mappings
grep -qE '^\s*"38\.2\.0":\s*"7\.0",' "$VARS_PY" || \
sed -i '/# -------- JP6 --------/a\ "38.2.0": "7.0",' "$VARS_PY"
grep -qE '^\s*"36\.4\.4":\s*"6\.2\.1",' "$VARS_PY" || \
sed -i '/# -------- JP6 --------/a\ "36.4.4": "6.2.1",' "$VARS_PY"
# CUDA table for Thor
grep -qE "^\s*'tegra264':\s*'13\.0'," "$VARS_PY" || \
sed -i "/'tegra234':/i\ 'tegra264': '13.0', # JETSON THOR - tegra264" "$VARS_PY"
# Module name table
grep -qE "^\s*'p3834-0008':\s*'NVIDIA Jetson AGX Thor \(Developer kit\)'," "$VARS_PY" || \
sed -i "/'p3767-0005':/i\ 'p3834-0008': 'NVIDIA Jetson AGX Thor (Developer kit)'," "$VARS_PY"
echo " patched $VARS_PY"
else
echo " skip: $VARS_PY not found"
fi
# 3) Patch jtop/github.py (insert warning line once)
GH_PY="$REPO_ROOT/jtop/github.py"
if [[ -f "$GH_PY" ]]; then
bk "$GH_PY"
if ! grep -q 'rollback jtop to not functioning on Thor' "$GH_PY"; then
python3 - "$GH_PY" <<'PY'
import re, sys
p=sys.argv[1]
with open(p, 'r', encoding='utf-8') as f:
s=f.read()
# Try the common anchor first (exact format call), then a looser fallback
anchor1 = r'(print\(\s*"\[\{status\}\]\s\{message\}"\.format\(status=bcolors\.warning\(\),\s*message=message\)\s*\)\s*\n)'
anchor2 = r'(print\(\s*"\[\{status\}\]\s\{message\}"\.format\([^)]*\)\s*\)\s*\n)'
insert = ' print(" For now, ignore the next 2 lines or it will rollback jtop to not functioning on Thor".format(bold=bcolors.BOLD, reset=bcolors.ENDC))\n'
s2, n = re.subn(anchor1, r'\1' + insert, s, count=1)
if n == 0:
s2, n = re.subn(anchor2, r'\1' + insert, s, count=1)
if n:
with open(p, 'w', encoding='utf-8') as f:
f.write(s2)
print(f" patched {p} (inserted 1)")
else:
sys.stderr.write(f"WARNING: Could not find anchor in {p}; skipping insert.\n")
PY
else
echo " note already present in $GH_PY"
fi
else
echo " skip: $GH_PY not found"
fi
echo "==> Thor/JP7 patching complete."
echo "pip will now install this jetson_stats repo, and 'nvidia-ml-py3*.whl' into the jtop venv."
