When I executed caffe model with deepstream, the following error occurred.
0:00:01.250098520 10261 0x32740cd0 WARN nvinfer gstnvinfer.cpp:523:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:log(): Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
Creating LL OSD context new
0:00:05.287065975 10261 0x32336770 WARN nvinfer gstnvinfer.cpp:1157:convert_batch_and_push_to_input_thread:<primary_gie_classifier> error: NvBufSurfTransform failed with error -2 while converting buffer
ERROR from primary_gie_classifier: NvBufSurfTransform failed with error -2 while converting buffer
Debug info: gstnvinfer.cpp(1157): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
ERROR from qtdemux0: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
streaming stopped, reason error (-5)
Quitting
App run failed
The code in the function “convert_batch_and_push_to_input_thread” of the gstnvinfer.cpp
err = NvBufSurfTransform (&nvinfer->tmp_surf, mem->surf,
&nvinfer->transform_params);
my caffe prototxt is
layer {
type: "Input"
top: "input_1"
input_param {
shape: { dim: 1 dim: 3 dim: 112 dim: 112 }
layer {
bottom: "input_1"
top: "conv_1_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 3
pad: 1
stride: 2
bias_term: false
layer {
bottom: "conv_1_conv2d"
top: "conv_1_batchnorm"
type: "BatchNorm"
batch_norm_param {
use_global_stats: true
moving_average_fraction: 0.9
eps: 0.001
layer {
bottom: "conv_1_batchnorm"
type: "Scale"
scale_param { bias_term: true }
layer {
top: "conv_1_relu"
type: "ReLU"
layer {
bottom: "conv_1_relu"
top: "conv_2_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 3
pad: 1
group: 64
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "conv_2_dw_conv2d"
top: "conv_2_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "conv_2_dw_batchnorm"
type: "Scale"
layer {
top: "conv_2_dw_relu"
type: "ReLU"
layer {
bottom: "conv_2_dw_relu"
top: "dconv_23_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_23_conv_sep_conv2d"
top: "dconv_23_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_23_conv_sep_batchnorm"
type: "Scale"
layer {
top: "dconv_23_conv_sep_relu"
type: "ReLU"
layer {
bottom: "dconv_23_conv_sep_relu"
top: "dconv_23_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 3
pad: 1
group: 128
engine:CAFFE
stride: 2
bias_term: false
layer {
bottom: "dconv_23_conv_dw_conv2d"
top: "dconv_23_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_23_conv_dw_batchnorm"
type: "Scale"
layer {
top: "dconv_23_conv_dw_relu"
type: "ReLU"
layer {
bottom: "dconv_23_conv_dw_relu"
top: "dconv_23_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_23_conv_proj_conv2d"
top: "dconv_23_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_23_conv_proj_batchnorm"
type: "Scale"
layer {
top: "res_3_block0_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block0_conv_sep_conv2d"
top: "res_3_block0_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block0_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_3_block0_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_3_block0_conv_sep_relu"
top: "res_3_block0_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 3
pad: 1
group: 128
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_3_block0_conv_dw_conv2d"
top: "res_3_block0_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block0_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_3_block0_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_3_block0_conv_dw_relu"
top: "res_3_block0_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block0_conv_proj_conv2d"
top: "res_3_block0_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block0_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
top: "_plus0"
eltwise_param { operation: SUM }
layer {
bottom: "_plus0"
top: "res_3_block1_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block1_conv_sep_conv2d"
top: "res_3_block1_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block1_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_3_block1_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_3_block1_conv_sep_relu"
top: "res_3_block1_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 3
pad: 1
group: 128
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_3_block1_conv_dw_conv2d"
top: "res_3_block1_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block1_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_3_block1_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_3_block1_conv_dw_relu"
top: "res_3_block1_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block1_conv_proj_conv2d"
top: "res_3_block1_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block1_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus0"
top: "_plus1"
layer {
bottom: "_plus1"
top: "res_3_block2_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block2_conv_sep_conv2d"
top: "res_3_block2_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block2_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_3_block2_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_3_block2_conv_sep_relu"
top: "res_3_block2_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 3
pad: 1
group: 128
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_3_block2_conv_dw_conv2d"
top: "res_3_block2_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block2_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_3_block2_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_3_block2_conv_dw_relu"
top: "res_3_block2_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block2_conv_proj_conv2d"
top: "res_3_block2_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block2_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus1"
top: "_plus2"
layer {
bottom: "_plus2"
top: "res_3_block3_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block3_conv_sep_conv2d"
top: "res_3_block3_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block3_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_3_block3_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_3_block3_conv_sep_relu"
top: "res_3_block3_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 3
pad: 1
group: 128
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_3_block3_conv_dw_conv2d"
top: "res_3_block3_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block3_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_3_block3_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_3_block3_conv_dw_relu"
top: "res_3_block3_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 64
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_3_block3_conv_proj_conv2d"
top: "res_3_block3_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_3_block3_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus2"
top: "_plus3"
layer {
bottom: "_plus3"
top: "dconv_34_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_34_conv_sep_conv2d"
top: "dconv_34_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_34_conv_sep_batchnorm"
type: "Scale"
layer {
top: "dconv_34_conv_sep_relu"
type: "ReLU"
layer {
bottom: "dconv_34_conv_sep_relu"
top: "dconv_34_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 2
bias_term: false
layer {
bottom: "dconv_34_conv_dw_conv2d"
top: "dconv_34_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_34_conv_dw_batchnorm"
type: "Scale"
layer {
top: "dconv_34_conv_dw_relu"
type: "ReLU"
layer {
bottom: "dconv_34_conv_dw_relu"
top: "dconv_34_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_34_conv_proj_conv2d"
top: "dconv_34_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_34_conv_proj_batchnorm"
type: "Scale"
layer {
top: "res_4_block0_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block0_conv_sep_conv2d"
top: "res_4_block0_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block0_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block0_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block0_conv_sep_relu"
top: "res_4_block0_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block0_conv_dw_conv2d"
top: "res_4_block0_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block0_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block0_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block0_conv_dw_relu"
top: "res_4_block0_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block0_conv_proj_conv2d"
top: "res_4_block0_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block0_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
top: "_plus4"
layer {
bottom: "_plus4"
top: "res_4_block1_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block1_conv_sep_conv2d"
top: "res_4_block1_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block1_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block1_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block1_conv_sep_relu"
top: "res_4_block1_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block1_conv_dw_conv2d"
top: "res_4_block1_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block1_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block1_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block1_conv_dw_relu"
top: "res_4_block1_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block1_conv_proj_conv2d"
top: "res_4_block1_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block1_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus4"
top: "_plus5"
layer {
bottom: "_plus5"
top: "res_4_block2_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block2_conv_sep_conv2d"
top: "res_4_block2_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block2_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block2_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block2_conv_sep_relu"
top: "res_4_block2_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block2_conv_dw_conv2d"
top: "res_4_block2_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block2_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block2_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block2_conv_dw_relu"
top: "res_4_block2_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block2_conv_proj_conv2d"
top: "res_4_block2_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block2_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus5"
top: "_plus6"
layer {
bottom: "_plus6"
top: "res_4_block3_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block3_conv_sep_conv2d"
top: "res_4_block3_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block3_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block3_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block3_conv_sep_relu"
top: "res_4_block3_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block3_conv_dw_conv2d"
top: "res_4_block3_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block3_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block3_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block3_conv_dw_relu"
top: "res_4_block3_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block3_conv_proj_conv2d"
top: "res_4_block3_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block3_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus6"
top: "_plus7"
layer {
bottom: "_plus7"
top: "res_4_block4_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block4_conv_sep_conv2d"
top: "res_4_block4_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block4_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block4_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block4_conv_sep_relu"
top: "res_4_block4_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block4_conv_dw_conv2d"
top: "res_4_block4_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block4_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block4_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block4_conv_dw_relu"
top: "res_4_block4_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block4_conv_proj_conv2d"
top: "res_4_block4_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block4_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus7"
top: "_plus8"
layer {
bottom: "_plus8"
top: "res_4_block5_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block5_conv_sep_conv2d"
top: "res_4_block5_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block5_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_4_block5_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_4_block5_conv_sep_relu"
top: "res_4_block5_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_4_block5_conv_dw_conv2d"
top: "res_4_block5_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block5_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_4_block5_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_4_block5_conv_dw_relu"
top: "res_4_block5_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_4_block5_conv_proj_conv2d"
top: "res_4_block5_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_4_block5_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus8"
top: "_plus9"
layer {
bottom: "_plus9"
top: "dconv_45_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 512
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_45_conv_sep_conv2d"
top: "dconv_45_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_45_conv_sep_batchnorm"
type: "Scale"
layer {
top: "dconv_45_conv_sep_relu"
type: "ReLU"
layer {
bottom: "dconv_45_conv_sep_relu"
top: "dconv_45_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 512
kernel_size: 3
pad: 1
group: 512
engine:CAFFE
stride: 2
bias_term: false
layer {
bottom: "dconv_45_conv_dw_conv2d"
top: "dconv_45_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_45_conv_dw_batchnorm"
type: "Scale"
layer {
top: "dconv_45_conv_dw_relu"
type: "ReLU"
layer {
bottom: "dconv_45_conv_dw_relu"
top: "dconv_45_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "dconv_45_conv_proj_conv2d"
top: "dconv_45_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "dconv_45_conv_proj_batchnorm"
type: "Scale"
layer {
top: "res_5_block0_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_5_block0_conv_sep_conv2d"
top: "res_5_block0_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block0_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_5_block0_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_5_block0_conv_sep_relu"
top: "res_5_block0_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_5_block0_conv_dw_conv2d"
top: "res_5_block0_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block0_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_5_block0_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_5_block0_conv_dw_relu"
top: "res_5_block0_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_5_block0_conv_proj_conv2d"
top: "res_5_block0_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block0_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
top: "_plus10"
layer {
bottom: "_plus10"
top: "res_5_block1_conv_sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_5_block1_conv_sep_conv2d"
top: "res_5_block1_conv_sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block1_conv_sep_batchnorm"
type: "Scale"
layer {
top: "res_5_block1_conv_sep_relu"
type: "ReLU"
layer {
bottom: "res_5_block1_conv_sep_relu"
top: "res_5_block1_conv_dw_conv2d"
type: "Convolution"
convolution_param {
num_output: 256
kernel_size: 3
pad: 1
group: 256
engine:CAFFE
stride: 1
bias_term: false
layer {
bottom: "res_5_block1_conv_dw_conv2d"
top: "res_5_block1_conv_dw_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block1_conv_dw_batchnorm"
type: "Scale"
layer {
top: "res_5_block1_conv_dw_relu"
type: "ReLU"
layer {
bottom: "res_5_block1_conv_dw_relu"
top: "res_5_block1_conv_proj_conv2d"
type: "Convolution"
convolution_param {
num_output: 128
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "res_5_block1_conv_proj_conv2d"
top: "res_5_block1_conv_proj_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "res_5_block1_conv_proj_batchnorm"
type: "Scale"
layer {
type: "Eltwise"
bottom: "_plus10"
top: "_plus11"
layer {
bottom: "_plus11"
top: "conv_6sep_conv2d"
type: "Convolution"
convolution_param {
num_output: 512
kernel_size: 1
pad: 0
stride: 1
bias_term: false
layer {
bottom: "conv_6sep_conv2d"
top: "conv_6sep_batchnorm"
type: "BatchNorm"
batch_norm_param {
eps: 0.001
layer {
bottom: "conv_6sep_batchnorm"
type: "Scale"
layer {
top: "conv_6sep_relu"
type: "ReLU"
layer {
bottom: "conv_6sep_relu"
top: "bn6f"
type: "BatchNorm"
batch_norm_param {
eps: 2e-05
layer {
bottom: "bn6f"
top: "bn6f"
type: "Scale"
layer {
bottom: "bn6f"
top: "pooling0"
type: "Pooling"
pooling_param {
pool: AVE
kernel_size: 7
layer {
bottom: "pooling0"
top: "bn6w"
type: "BatchNorm"
batch_norm_param {
eps: 2e-05
layer {
bottom: "bn6w"
top: "bn6w"
type: "Scale"
layer {
bottom: "bn6w"
top: "pre_fc1"
type: "InnerProduct"
inner_product_param {
num_output: 128
layer {
bottom: "pre_fc1"
top: "fc1"
type: "BatchNorm"
batch_norm_param {
eps: 2e-05
layer {
bottom: "fc1"
top: "fc1"
type: "Scale"
