hi all ,now i test 06_jpeg_decode use the decode-fd option to decode jpeg file ,i found some resolution jpeg file can not be decoded ,so why ? my resolution si 600*605,the width is not Multiple of 16 ,so how can i fix it ?the following is the error:
[ERROR] (NvJpegDecoder.cpp:124) decodeToFd() failed, please run decodeToBuffer()
Could not decode image
App run failed
Calling decodeToFd() puts data in NvBuffer which is a hardware buffer and has limitation in data alignment. Special resolutions are not supported. The JPEG is with special resolution 600x605.
