• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version 11.8
• NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
• Issue Type( questions, new requirements, bugs) questions
I executed the sample code. source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
As a result, there were four fps, but are each fps corresponding to four models excluding tracker?
If not, what do the 4 fps correspond to?
And what should I do if I want to measure fps with batch size 1 for the entire sample code?
I’d appreciate it if you could answer.
Thank you
