Hello,all
I unzipped the file.
tx1-Tegra210_Linux_R28.3.0_aarch64.tbz2
tx1-Tegra_Linux_Sample-Root-Filesystem_R28.3.0_aarch64.tbz2
Then run the instructions sudo ./flash.sh -r -k kernel-dtb jetson-tx1 mmcblk0p1.
But the following mistakes occurred.
210-jetson-tx1-p2597-2180-a01-devkit.dtb to rootfs... done.
done.
Making Boot image... done.
copying bcffile(/home/wf/SQ01DEMO/enviroment/Linux_for_Tegra/bootloader/t210ref/cfg/board_config_p2597-devkit.xml)... done.
Existing sosfile(/home/enviroment/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
copying tegraboot(/home/enviroment/Linux_for_Tegra/bootloader/t210ref/nvtboot.bin)... done.
Existing bpffile(/home/enviroment/Linux_for_Tegra/bootloader/sc7entry-firmware.bin) reused.
copying wb0boot(/home/enviroment/Linux_for_Tegra/bootloader/t210ref/warmboot.bin)... done.
Existing tosfile(/home/enviroment/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/enviroment/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/enviroment/Linux_for_Tegra/kernel/dtb/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb)... done.
Reusing existing system.img...
file does not exist.
I’m not using JETPACK. compared with JETPACK bootloader under this file and found that system. img was missing. What should I do?
