Hi
I use the following command to clone, Two files, original.img and original.img.raw, are generated.
sudo ./flash.sh -r -k APP -G original.img jetson-xavier-nx-devkit-emmc nvme0n1p1
Then replace /bootloader/system.img.
and I want to flash APP partiton to orthers SSD nvme0n1p1 . How to use flash.sh to write ?
Thanks !
I don’t believe this is going to work.
Maybe you just dumped the partition in the eMMC instead of the NVMe drive.
Please use our backup/restore tool instead.
Refer to Linux_for_Tegra/tools/backup_restore for the README.
DaveYYY:
Thank you for your reply。
But it doesn’t say anything about how to clone SSD
If you are using 35.3.1 or older releases, then you need to replace every instance of mmcblk0 with nvme0n1 in Linux_for_Tegra/tools/backup_restore/nvbackup_partitions.sh and Linux_for_Tegra/tools/backup_restore/nvrestore_partitions.sh. Then run like:
sudo ./sudo ./tools/backup_restore/l4t_backup_restore.sh -b jetson-xavier-nx-devkit-emmc
sudo ./sudo ./tools/backup_restore/l4t_backup_restore.sh -r jetson-xavier-nx-devkit-emmc
If you are using 35.4.1, then just do:
sudo ./sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-xavier-nx-devkit-emmc
sudo ./sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-xavier-nx-devkit-emmc
