I am using a Jetson Xavier NX production module (16GB emmc) with Seeedstudio A302 carrier board. I have successfully flashed the emmc to Jetpack 5.1.2 with SDK manager. But I failed to flash and boot it from 128GB Twinmos NVME SSD.
Disk /dev/nvme0n1: 119.25 GiB, 128035676160 bytes, 250069680 sectors
Disk model: TwinMOS SSD
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Here is my attempts:
- This command successfully flashed the NX and booted from Nvme SSD.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-only -c ./tools/kernel_flash/flash_l4t_nvme.xml --external-device nvme0n1 --showlogs jetson-xavier-nx-devkit-emmc external
- But the APP partition (rootfs) is only 12GB which is not enough for me. Thus I tried to flash with larger APP partition with this command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-only -c ./tools/kernel_flash/flash_l4t_nvme.xml --external-device nvme0n1 -S 100GiB --showlogs jetson-xavier-nx-devkit-emmc external
But it fails to flash with no space left message
tar: ./etc/ssl/certs/HARICA_TLS_RSA_Root_CA_2021.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/HARICA_TLS_RSA_Root_CA_2021.crt’: No space left on device
tar: ./etc/ssl/certs/SSL.com_EV_Root_Certification_Authority_RSA_R2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/SSL.com_EV_Root_Certification_Authority_RSA_R2.crt’: No space left on device
tar: ./etc/ssl/certs/Entrust_Root_Certification_Authority_-_G4.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority_-_G4.crt’: No space left on device
tar: ./etc/ssl/certs/Go_Daddy_Root_Certificate_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Go_Daddy_Root_Certificate_Authority_-_G2.crt’: No space left on device
tar: ./etc/ssl/certs/Entrust_Root_Certification_Authority_-_G2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Entrust_Root_Certification_Authority_-_G2.crt’: No space left on device
tar: ./etc/ssl/certs/Atos_TrustedRoot_2011.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Atos_TrustedRoot_2011.crt’: No space left on device
tar: ./etc/ssl/certs/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Autoridad_de_Certificacion_Firmaprofesional_CIF_A62634068.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Global_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/GlobalSign_Root_CA_-_R3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/GlobalSign_Root_CA_-_R3.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Assured_ID_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Assured_ID_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/T-TeleSec_GlobalRoot_Class_2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/T-TeleSec_GlobalRoot_Class_2.crt’: No space left on device
tar: ./etc/ssl/certs/OISTE_WISeKey_Global_Root_GB_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/OISTE_WISeKey_Global_Root_GB_CA.crt’: No space left on device
tar: ./etc/ssl/certs/E-Tugra_Global_Root_CA_ECC_v3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/E-Tugra_Global_Root_CA_ECC_v3.crt’: No space left on device
tar: ./etc/ssl/certs/Comodo_AAA_Services_root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Comodo_AAA_Services_root.crt’: No space left on device
tar: ./etc/ssl/certs/DigiCert_Global_Root_G3.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/DigiCert_Global_Root_G3.crt’: No space left on device
tar: ./etc/ssl/certs/TWCA_Root_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/TWCA_Root_Certification_Authority.crt’: No space left on device
tar: ./etc/ssl/certs/Certum_Trusted_Network_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Network_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Certum_Trusted_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Certum_Trusted_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/NetLock_Arany_=Class_Gold=_Főtanúsítvány.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/NetLock_Arany_=Class_Gold=_Főtanúsítvány.crt’: No space left on device
tar: ./etc/ssl/certs/Actalis_Authentication_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Actalis_Authentication_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/Baltimore_CyberTrust_Root.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Baltimore_CyberTrust_Root.crt’: No space left on device
tar: ./etc/ssl/certs/Security_Communication_RootCA2.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Security_Communication_RootCA2.crt’: No space left on device
tar: ./etc/ssl/certs/IdenTrust_Commercial_Root_CA_1.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/IdenTrust_Commercial_Root_CA_1.crt’: No space left on device
tar: ./etc/ssl/certs/Buypass_Class_2_Root_CA.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/Buypass_Class_2_Root_CA.crt’: No space left on device
tar: ./etc/ssl/certs/COMODO_Certification_Authority.pem: Cannot create symlink to ‘/usr/share/ca-certificates/mozilla/COMODO_Certification_Authority.crt’: No space left on device
tar: Exiting with failure status due to previous errors
[ 16]: l4t_flash_from_kernel: Failed to decompress APP image into /dev/sdi1
[ 16]: l4t_flash_from_kernel: Failed to write to APP
[ 16]: l4t_flash_from_kernel: Error flashing external device
Error flashing non-qspi storage
Cleaning up...
- I also tried to set the partition size from the
flash_l4t_nvme.xmllike this :
<partition_layout version="01.00.0000">
<device type="external" instance="0" sector_size="512" num_sectors="250069680">
<partition name="master_boot_record" type="protective_master_boot_record">
<allocation_policy> sequential </allocation_policy>
<filesystem_type> basic </filesystem_type>
<size> 512 </size>
<file_system_attribute> 0 </file_system_attribute>
<allocation_attribute> 8 </allocation_attribute>
<percent_reserved> 0 </percent_reserved>
<description> **Required.** Contains protective MBR. </description>
</partition>
<partition name="primary_gpt" type="primary_gpt">
<size> 19968 </size>
<description> **Required.** Contains primary GPT of the `nvme` device. All
partitions defined after this entry are configured in the kernel, and are
accessible by standard partition tools such as gdisk and parted. </description>
</partition>
<partition name="APP" type="data">
<size> 200000000 </size> <!-- 100 GiB in sectors -->
<allocation_attribute> 0x8 </allocation_attribute>
<align_boundary> 4096 </align_boundary>
<filename> APPFILE </filename>
<unique_guid> APPUUID </unique_guid>
<description> **Required.** Contains the rootfs. This partition must be defined
after `primary_GPT` so that it can be accessed as the fixed known special device
`/dev/nvme0n1p1`. </description>
<partition name="UDA" type="data">
<size> -0 </size> <!-- Automatically takes all remaining space -->
<allocation_attribute> 0x808 </allocation_attribute>
<description> **Required.** Automatically takes all remaining space on the device except that
occupied by the `secondary_gpt` partition. Allocation attribute must be set to 0x808.
May be mounted and used to store user data. </description>
</partition>
<partition name="secondary_gpt" type="secondary_gpt">
<size> 0xFFFFFFFFFFFFFFFF </size>
<description> **Required.** Contains secondary GPT of the `sdcard`
device. </description>
</partition>
</device>
</partition_layout>
I made change to the APP partition and UDA partition so that the APP partition takes 100GB space. But still no way it’s flashing.
Please help me overcoming this frustrating situation.
