Installing jetpack on nvme with larger root size
I installed a 1Tb nvme drive into my jetson agx. when I use the GUI to flash the drive I end up with a root directory of only 11ish GB. I want to use the entire 1Tb drive for my home directory. I read around on the forums: About Adjust App size - #23 by WayneWWW
I am running the following command and an error with the output on the size of a partition.
what is the best way to flash the nvme drive and use the entire disk?
sudo ./flash.sh -S 950GiB  jetson-agx-xavier-devkit  nvme0n1p1
# L4T BSP Information:
# R35 , REVISION: 4.1
# User release: 0.0
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0141 ] Generating RCM messages
[   0.0158 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[   0.0164 ] Header already present for /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[   0.0215 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0216 ] Assuming zero filled SBK key
[   0.0234 ] tegrasign_v3.py --file /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0235 ] Assuming zero filled SBK key
[   0.0251 ] Warning: pub_key.key is not found
[   0.0257 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0303 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0327 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0332 ] RCM 0 is saved as rcm_0.rcm
[   0.0354 ] RCM 1 is saved as rcm_1.rcm
[   0.0355 ] RCM 2 is saved as rcm_2.rcm
[   0.0356 ] List of rcm files are saved in rcm_list.xml
[   0.0356 ]
[   0.0356 ] Signing RCM messages
[   0.0383 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0384 ] Assuming zero filled SBK key
[   0.0411 ] Warning: pub_key.key is not found
[   0.0400 ] Copying signature to RCM mesages
[   0.0416 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0428 ] Boot Rom communication
[   0.0445 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0451 ] RCM version 0X190001
[   0.4854 ] Boot Rom communication completed
[   2.5028 ] tegrarcm_v2 --isapplet
[   2.5034 ] Applet version 01.00.0000
[   3.3923 ] tegrarcm_v2 --ismb2
[   4.2981 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[   4.3001 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[   4.3006 ] adding BCH for nvtboot_applet_t194_aligned.bin
[   4.3058 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   4.3059 ] Assuming zero filled SBK key
[   4.3072 ] Warning: pub_key.key is not found
[   4.3079 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[   4.3117 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   4.3123 ] Applet version 01.00.0000
[   5.1984 ] Sending mb2
[   5.1984 ] [................................................] 100%
[   5.2151 ] tegrarcm_v2 --boot recovery
[   5.2157 ] Applet version 01.00.0000
[   7.1054 ] tegrarcm_v2 --isapplet
[   7.9887 ] tegrarcm_v2 --ismb2
[   7.9894 ] MB2 Applet version 01.00.0000
[   8.8766 ] tegrarcm_v2 --ismb2
[   8.8772 ] MB2 Applet version 01.00.0000
[   9.7645 ] Retrieving board information
[   9.7663 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   9.7669 ] MB2 Applet version 01.00.0000
[  10.6484 ] Saved platform info in chip_info.bin
[  10.6524 ] Chip minor revision: 2
[  10.6524 ] Bootrom revision: 0xf
[  10.6525 ] Ram code: 0x2
[  10.6526 ] Chip sku: 0xd0
[  10.6526 ] Chip Sample: non es
[  10.6532 ] Retrieving EEPROM data
[  10.6532 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[  10.6539 ] MB2 Applet version 01.00.0000
[  11.5404 ] Saved platform info in /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[  11.5794 ] Rebooting to recovery mode
[  11.5813 ] tegrarcm_v2 --ismb2
[  11.5820 ] MB2 Applet version 01.00.0000
[  12.4748 ] Rebooting to recovery mode
[  12.4767 ] tegrarcm_v2 --reboot recovery
[  12.4773 ] MB2 Applet version 01.00.0000
Board ID(2888) FAB(400) sku(0004) revision(L.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb ...
Copy /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
copying dev_params_b(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-sdmmc.cfg)... done.
Existing bootloader(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/ramdisk_tmp /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra
42010 blocks
gzip: /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.120-tegra
58247 blocks
Making Recovery image...
copying recdtbfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000101911 s, 196 kB/s
Existing sosfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p2888-a04_lz4.dtb) reused.
Existing scefile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/eks_t194.img) reused.
copying dtbfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
generating system.img for booting...
Making system.img...
	Setting "FDT /boot/dtb/kernel_tegra194-p2888-0001-p2822-0000.dtb" successfully in the extlinux.conf...done.
	populating rootfs from /tmp/tmp.ZrzhGUkLms ... 	populating /boot/extlinux/extlinux.conf ... done.
	Sync'ing system.img ... done.
	Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.163785 s, 410 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
done.
Existing flasher(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-dual-imx274-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3326-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3331-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-e3333-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-imx185-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2822-camera-imx390-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0005-overlay.dtbo)... done.
copying overlay_dtb(/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000-overlay.dtbo)... done.
/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg  --odmdata 0x9190000  --overlay_dtb L4TConfiguration.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3326-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo,  --bldtb tegra194-p2888-0001-p2822-0000.dtb --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg,tegra194-br-bct_b-sdmmc.cfg  --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"   --secondary_gpt_backup  --bct_backup  --boot_chain A
saving flash command in /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0203 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0204 ] Assuming zero filled SBK key
[   0.0018 ] Generating RCM messages
[   0.0036 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0042 ] Header already present for mb1_t194_prod.bin
[   0.0273 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0274 ] Assuming zero filled SBK key
[   0.0292 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0293 ] Assuming zero filled SBK key
[   0.0314 ] Warning: pub_key.key is not found
[   0.0144 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0190 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0217 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0223 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0226 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0226 ]
[   0.0245 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0251 ] RCM 0 is saved as rcm_0.rcm
[   0.0274 ] RCM 1 is saved as rcm_1.rcm
[   0.0275 ] RCM 2 is saved as rcm_2.rcm
[   0.0276 ] List of rcm files are saved in rcm_list.xml
[   0.0276 ]
[   0.0276 ] Signing RCM messages
[   0.0479 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   0.0480 ] Assuming zero filled SBK key
[   0.0510 ] Warning: pub_key.key is not found
[   0.0323 ] Copying signature to RCM mesages
[   0.0340 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0349 ] odmdata (to decode) = 152633344
[   0.0350 ] Odmdata strings: PCIE_XBAR_4_1_0_1_2,UFS_x1_L1,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[   0.0350 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_4_1_0_1_2'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_x1_L1'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[   0.0361 ] bpmp_dtb is compressed; decompressing...
[   0.0361 ] lz4c -df tegra194-a02-bpmp-p2888-a04_lz4.dtb tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb
[   0.0380 ] tegra194-a02-bpmp-p2 : decoded 989312 bytes
[   0.0380 ]
[   0.1635 ] Re-compressing updated bpmp_dtb
[   0.1635 ] lz4c -zf tegra194-a02-bpmp-p2888-a04_lz4_with_odm.dtb tegra194-a02-bpmp-p2888-a04_lz4.dtb
[   0.1657 ] Compressed 989271 bytes into 86508 bytes ==> 8.74%
[   0.1657 ]
[   0.4308 ] Concatenating L4TConfiguration.dtbo,tegra194-p2822-camera-dual-imx274-overlay.dtbo,tegra194-p2822-camera-e3326-overlay.dtbo,tegra194-p2822-camera-e3331-overlay.dtbo,tegra194-p2822-camera-e3333-overlay.dtbo,tegra194-p2822-camera-imx185-overlay.dtbo,tegra194-p2822-camera-imx390-overlay.dtbo,tegra194-p2888-0005-overlay.dtbo,tegra194-p2888-0001-p2822-0000-overlay.dtbo to tegra194-p2888-0001-p2822-0000_with_odm_overlay.dtb
[   0.4313 ] Parsing partition layout
[   0.4335 ] tegraparser_v2 --pt flash.xml.tmp
[   0.4358 ] Reading ramcode from backup chip_info.bin file
[   0.4359 ] RAMCODE Read from Device: 2
[   0.4360 ] Disable BPMP dtb trim, using default dtb
[   0.4360 ]
[   0.4360 ] Creating list of images to be signed
[   0.4379 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   0.4386 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[   0.4392 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[   0.4394 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[   0.4415 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[   0.4417 ] adding BCH for spe_t194_aligned.bin
[   0.4438 ] adding BCH for nvtboot_t194_aligned.bin
[   0.4456 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   0.4489 ] adding BCH for spe_t194_aligned.bin
[   0.4491 ] adding BCH for nvtboot_t194_aligned.bin
[   0.4508 ] Header already present for preboot_c10_prod_cr_aligned.bin
[   0.4541 ] Header already present for mce_c10_prod_cr_aligned.bin
[   0.4546 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   0.4618 ] adding BCH for nvdisp-init_aligned.bin
[   0.5199 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   0.5665 ] adding BCH for tos-optee_t194_aligned.img
[   0.5756 ] adding BCH for eks_t194_aligned.img
[   0.5908 ] adding BCH for bpmp-2_t194_aligned.bin
[   0.5925 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[   0.6082 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   0.6101 ] adding BCH for adsp-fw_aligned.bin
[   0.6188 ] Header already present for warmboot_t194_prod_aligned.bin
[   0.6249 ] Header already present for mce_c10_prod_cr_aligned.bin
[   0.6255 ] adding BCH for mts_c10_prod_cr_aligned.bin
[   0.6328 ] adding BCH for nvdisp-init_aligned.bin
[   0.6920 ] adding BCH for tegra194-p2888-0001-p2822-0000_aligned.dtb
[   0.7389 ] adding BCH for tos-optee_t194_aligned.img
[   0.7480 ] adding BCH for eks_t194_aligned.img
[   0.7633 ] adding BCH for bpmp-2_t194_aligned.bin
[   0.7650 ] adding BCH for tegra194-a02-bpmp-p2888-a04_lz4_aligned.dtb
[   0.7810 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[   0.7834 ] adding BCH for adsp-fw_aligned.bin
[   0.7920 ] Header already present for warmboot_t194_prod_aligned.bin
[   0.7988 ] Filling MB1 storage info
[   0.7988 ] Parsing dev params for multi chains
[   0.7988 ] Generating br-bct
[   0.8008 ] Performing cfg overlay
[   0.8008 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   0.8009 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg
[   0.8450 ] Updating dev and MSS params in BR BCT
[   0.8450 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   0.9000 ] Updating bl info
[   0.9020 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   0.9034 ] Generating br-bct
[   0.9051 ] Performing cfg overlay
[   0.9051 ] ['/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg']
[   0.9051 ] Updating dev and MSS params in BR BCT
[   0.9051 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   0.9596 ] Updating bl info
[   0.9614 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   0.9629 ] Generating BCT backup image
[   0.9629 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   0.9637 ] 32768+0 records in
[   0.9932 ] 32768+0 records out
[   0.9932 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0292914 s, 1.1 MB/s
[   0.9932 ]
[   0.9932 ] Concatenating BCT for chain A to bct_backup.img
[   0.9932 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   0.9938 ] 2888+0 records in
[   0.9957 ] 2888+0 records out
[   0.9957 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00170306 s, 1.7 MB/s
[   0.9957 ]
[   0.9957 ] Concatenating BCT for chain B to bct_backup.img
[   0.9957 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   0.9963 ] 2888+0 records in
[   0.9982 ] 2888+0 records out
[   0.9982 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00170198 s, 1.7 MB/s
[   0.9982 ]
[   0.9982 ] Generating signatures
[   1.0186 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   1.0187 ] Assuming zero filled SBK key
[   1.0745 ] Warning: pub_key.key is not found
[   1.0559 ] Parsing dev params for multi chains
[   1.0559 ] Generating br-bct
[   1.0578 ] Performing cfg overlay
[   1.0578 ] ['/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg']
[   1.0578 ] Updating dev and MSS params in BR BCT
[   1.0578 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   1.1133 ] Updating bl info
[   1.1152 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.1175 ] Updating smd info
[   1.1193 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   1.1202 ] Updating Odmdata
[   1.1221 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   1.1230 ] Signing BCT
[   1.1230 ] Get Signed section of bct
[   1.1249 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   1.1464 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   1.1465 ] Assuming zero filled SBK key
[   1.1477 ] Warning: pub_key.key is not found
[   1.1291 ] Updating BCT with signature
[   1.1309 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   1.1318 ] Generating br-bct
[   1.1337 ] Performing cfg overlay
[   1.1338 ] ['/home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg']
[   1.1338 ] Updating dev and MSS params in BR BCT
[   1.1338 ] tegrabct_v2 --dev_param tegra194-br-bct_b-sdmmc.cfg --sdram /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   1.1890 ] Updating bl info
[   1.1908 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   1.1926 ] Updating smd info
[   1.1944 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   1.1953 ] Updating Odmdata
[   1.1972 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   1.1980 ] Signing BCT
[   1.1980 ] Get Signed section of bct
[   1.1999 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   1.2213 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[   1.2214 ] Assuming zero filled SBK key
[   1.2227 ] Warning: pub_key.key is not found
[   1.2040 ] Updating BCT with signature
[   1.2059 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   1.2068 ] Generating BCT backup image
[   1.2069 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   1.2076 ] 32768+0 records in
[   1.2374 ] 32768+0 records out
[   1.2374 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0294811 s, 1.1 MB/s
[   1.2374 ]
[   1.2374 ] Concatenating BCT for chain A to bct_backup.img
[   1.2374 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   1.2381 ] 2888+0 records in
[   1.2401 ] 2888+0 records out
[   1.2401 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00173337 s, 1.7 MB/s
[   1.2401 ]
[   1.2402 ] Concatenating BCT for chain B to bct_backup.img
[   1.2402 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   1.2410 ] 2888+0 records in
[   1.2429 ] 2888+0 records out
[   1.2429 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00171277 s, 1.7 MB/s
[   1.2429 ]
[   1.2430 ] Generating coldboot mb1-bct
[   1.2451 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/nathaniel/nvidia/nvidia_sdk/JetPack_5.1.2_Linux_JETSON_AGX_XAVIER_TARGETS/Linux_for_Tegra/bootloader/32484/tmp2br2pu171.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   1.2459 ] MB1-BCT version: 0x1
[   1.2461 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   1.2462 ] Added Platform Config 0 data with size :- 3168
[   1.2472 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   1.2473 ] Added Platform Config 1 data with size :- 19640
[   1.2542 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   1.2544 ] Added Platform Config 2 data with size :- 24
[   1.2545 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   1.2547 ] File read failed
[   1.2548 ] Added Platform Config 4 data with size :- 348
[   1.2549 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   1.2550 ] Added Platform Config 3 data with size :- 92
[   1.2551 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   1.2553 ] Added Platform Config 5 data with size :- 68
[   1.2554 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   1.2556 ] Added Platform Config 7 data with size :- 392
[   1.2557 ]
[   1.2557 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   1.2557 ] Added Platform Config 8 data with size :- 12
[   1.2557 ]
[   1.2557 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   1.2557 ] Added Platform Config 9 data with size :- 32
[   1.2557 ]
[   1.2557 ] Updating mb1-bct with firmware information
[   1.2574 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.2579 ] Start sector for mts-mce_b, expected >= 1992563752, actual 0
Error: Return value 4
Command tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
Failed flashing t186ref.
What L4T version do you use?
If your GUI means SDK Manager, and you are using 35.4.1 (JetPack 5.1.2), then the issue is here:
If you want to use flashing scripts instead, flash.sh does not support flashing into NVMe, and you have to use initrd flash instead:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml --showlogs --network usb0 jetson-agx-xavier-devkit nvme0n1p1
