I am currently trying to implement accelerated chroma keying on the jetson xavier nx in order to remove some blue pixel on a desktop stream and replace them with a PAL video stream. I use the v4l2src plugin form gstreamer to stream the videos.
I tried to use the alpha plugin from gstreamer. It worked but I have less than one fps.
I am thinking about using nvivafilter but I don’t know how to get 2 inputs with this plugin.
I have already seen all the previous discussions on this forum but I can’t really distinguish any lasting solution in those.
But the alpha plugins’s performance is poor since it doesn’t seem to be GPU accelerated. I am looking for a more efficient solution to perform chroma keying.
The queues might help with frame-rate, just be aware that you might see a bit more latency.
That being said, you are correct.
By having a pipe optimized for the NVIDIA HW you will get the best performance.
That would require a bit more work though.
If you need help with that, please do not hesitate to reach out, we would love to give you a hand. There are a couple of options we can try:
Modifying the nvivafilter to support more inputs.
Creating a custom GStreamer element with HW optimized chroma keying.
Hit us up if you want to get that pipe optimized ASAP.
best regards,
Andrew
For the use-case, there is no existing implementation with hardware acceleration. A possible solution is to implement it through jetson_multimedia_api like:
Thank you for your answer.
I am trying to display the stream of a PAL camera with this sample but it seems that the video is not deinterlaced.
Is it possible to perform deinterlacing ? If yes, what modifications do I need to operate in the code ?
There is no hardware acceleration for deinterlacing in the use-case. You would need to use software solution. So your solution looks to be optimal on Xavier NX. One more thing to try is to run $ sudo jetson_clocks to fix CPU cores at maximum clock.
