I have been using nvivafilter gstreamer plugin with TX2 on various L4T releases up to R28.2.0.
However, on Xavier running R31.1, I am unable to get it working.
Even using the default version /usr/lib/aarch64-linux-gnu/libnvsample_cudaprocess.so, even without activating nor pre/post/cuda processing, it fails after 4 frames:
gst-launch-1.0 -v videotestsrc is-live=true ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvivafilter ! 'video/x-raw(memory:NVMM), format=RGBA' ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = video/x-raw, format=(string)I420, width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)I420
/GstPipeline:pipeline0/Gstnvivafilter:nvivafilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstNvEglTransform:nvegltransform0.GstPad:src: caps = video/x-raw(memory:EGLImage), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstEglGlesSink:eglglessink0.GstPad:sink: caps = video/x-raw(memory:EGLImage), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstNvEglTransform:nvegltransform0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvivafilter:nvivafilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)I420
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, format=(string)I420, width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
nvbuf_utils: dmabuf_fd 1056 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.200772524
Setting pipeline to READY ...
nvbuf_utils: dmabuf_fd 1057 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1058 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1059 mapped entry NOT found
Setting pipeline to NULL ...
XIO: fatal IO error 9 (Bad file descriptor) on X server "�!�"
after 18 requests (18 known processed) with 0 events remaining.
Using YUV420_SEMIPLANAR format doesn’t improve:
gst-launch-1.0 -v videotestsrc is-live=true ! nvvidconv ! 'video/x-raw(memory:NVMM), format=I420' ! nvivafilter ! 'video/x-raw(memory:NVMM), format=NV12' ! nvoverlaysink
/GstPipeline:pipeline0/Gstnvivafilter:nvivafilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstNvOverlaySink-nvoverlaysink:nvoverlaysink-nvoverlaysink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)320, height=(int)240, framerate=(fraction)30/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)NV12
nvbuf_utils: dmabuf_fd 1030 mapped entry NOT found
Execution ended after 0:00:00.141727296
nvbuf_utils: dmabuf_fd 1031 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1032 mapped entry NOT found
nvbuf_utils: dmabuf_fd 1033 mapped entry NOT found
Freeing pipeline ...
Using NV12 or I420 as input doesn’t improve.
On a custom version of the library, I can see that the first four frames are processed, but then it get fooled. It happens out of the gpu_process (or any user defined function).
Is there a new way to use nvivafilter, or is it deprecated ?
